Suspension torques
Discussion in 'Suspension' started by csuviper, Apr 15, 2016.
  1. Apr 15, 2016 at 1:05 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2012 Rock Warrior 5.7L 4X4
    Tie rod end: 51 ft lbs
    Top coilover bolts: 33 ft lbs
    Bottom coilover bolt: 144 ft lbs
    Upper control arm ball joint: 81 ft lbs
    Steering knuckle: 81 ft lbs
    Sway bar bolt: 89 ft lbs
    Top stabilizer bolt: 111 ft lbs
    Lower control arm ball joint attachment(2 bolts): 221 ft lbs
    Lower ball joint: 123 ft lbs
    Control sensor wire A: 10 ft lbs on UCA
    Control sensor wire B: 21 ft lbs on spindle
    Sway bar brackets bracket (4 bolts): 51 ft lbs
    UCA through bolt for Total Chaos UCA: 173 ft lbs
    Total Chaos Uniball: 100 ft lbs
    Rear spring: 77 ft lbs
    Rear Ubolt: 74 ft lbs
    Rear shock upper: 21 ft lbs
    Rear shock lower: 66 ft lbs
    Aluminum wheel: 97 ft lbs
    Steel wheel: 154 ft lbs
