Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Aug 5, 2024 at 4:32 AM
    #691
    WNY PAT
    WNY PAT New Member
    C
    Armchair QB for sure and only time will tell. I remember when Toyota announced they had identified the source of the debris and that they had addressed that issue. Then motors kept failing. Then there was a quiet change in the part numbers for the number 1 and 4 main bearings. Still seeing reports of new failures tho. Now they’re recalling 100K trucks to install complete brand new long blocks. Folks are free to draw their own conclusions I suppose. My conclusion is that what is arguably the best motor maker in the world could resolve machining issues on an assembly line quickly. The fact that these failures continue, and that oil analysis seemingly points to the main bearings (the ones with the new part numbers) shedding their silver plating, is too much of a coincidence for me to believe anything else at this point. Let’s hope for zero failures on the replacement long blocks. Toyota needs that right now more than anything IMO.
  2. Aug 5, 2024 at 4:48 AM
    #692
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    The same Toyota falling on its sword in Japan for cheering?
  3. Aug 5, 2024 at 7:01 AM
    #693
    Mannra
    Mannra New Member
    2022 SR5 TRD OR 4WD
    I haven't followed everything beyond tundra news, but are they experiencing engine issues in the Sequoia or the GX 550 or just in the Tundra/LX?
  4. Aug 5, 2024 at 7:06 AM
    #694
    WNY PAT
    WNY PAT New Member
    From what I understand, every platform that uses this block has had failures. I haven’t followed Lexus at all, but I assume even the flagship LX (Land Cruiser) is included.
  5. Aug 5, 2024 at 7:07 AM
    #695
    Mannra
    Mannra New Member
    2022 SR5 TRD OR 4WD
    The LX is included in the recall
    The Sequoia and GX have not been.
  6. Aug 5, 2024 at 8:18 AM
    #696
    Fatone
    Fatone New Member
    Sequoia is interesting because one with think the same engine would have same failure rate and recall basis. But the LX is included so not just a Tundra or doing truck things issues.
    Maybe just prioritization of highest failure rates to manage engine pipeline
  7. Aug 5, 2024 at 8:26 AM
    #697
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    It could be that the Sequoia missed the date range for the first round on the recall. I don't recall seeing any around here in 2022. So like the other Tundras in 2023 and 24 that aren't included (yet?). I think I have heard of a few failures with the Sequoia as well but not too sure where those reports would be at this point.
  8. Aug 5, 2024 at 8:27 AM
    #698
    Jaxyaks
    Jaxyaks New Member
    All Sequoia's are Hybrids, I would imagine since none of the Hybrid models were recalled that would be the reason. The LX's are NA like the Tundras that were recalled.
  9. Aug 5, 2024 at 8:28 AM
    #699
    40man
    40man New Member
    Sequoias are all hybrids. Hybrids not recalled currently...
  10. Aug 5, 2024 at 8:33 AM
    #700
    Fatone
    Fatone New Member
    You are correct. I was thinking the SR5s were not
  11. Aug 5, 2024 at 8:39 AM
    #701
    lapoolboy
    lapoolboy New Member
    I don't know about y'all, but there is no way the hybrid system alone is going to get you out of a jam at highway speeds if the engine let's go. I've intentionally tried to ease down the road on just battery, but it loses speed quickly and the slightest touch of the accelerator pedal causes the engine to fire back up.
  12. Aug 5, 2024 at 8:42 AM
    #702
    Hobbes
    Hobbes New Member
    2023 Tundra Hybrid Ltd
    FWIW, I have tried, really tried, to find documented end to end account(s) of 2024 engine failures that may in anyway relate to the issues in the recall. Given the degree of speculation swirling on the drivetrain, it would be cool if there were well documented cases to cite. If they exist and I can't find them. please post links or refrain from citing it as an issue. Thank you.
  13. Aug 5, 2024 at 8:53 AM
    #703
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    I’m with you. I see the Sequoia that isn’t verified and one there was supposedly gas contamination. Other than that, where are the reports? I don’t do fb or Reddit so I could have missed some.?.
    24’s have been sold since 9/23… coming up on a year.
    Tundrastruck91 likes this.
  14. Aug 5, 2024 at 8:57 AM
    #704
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    2022 Tundra SR5 , blueprint
    Tonneau cover
    I have been following this since the beginning. My 22 has 45K on it now. Lots of posts about this issue. Great to analyze things from many angles.
    I , in the beginning of all this believed the Toyota statement that it was a cleaning debris left behind in the production.
    OK. If that’s true, then it should have been resolved within a year. But now we are pushing 24’s and the issue persists.
    I no longer believe this theory or statement by Toyota. I believe they have a parts issue. I am not sure yet of which one . Maybe the bearing , maybe something else is disintegrating in the engine. THAT could also explain the debris.
    If it is a part or component failure then YES, they must replace the engine in its entirety. Since everyone drives differently and engines are just like anything else. It will not fail at the exact time or mileage , but it will fail under its intended life span.
    Changing oil frequently will not hurt your truck, it may prolong the failure.
    I think Toyota is lying to us.
    However, they are going to replace the engines so I will deal with it. It’s fine with me. Nothing is perfect in life. Other manufactures have failing engines too and they are not doing anything for the customer at all.
    22whatwedo and WNY PAT like this.
  15. Aug 5, 2024 at 8:59 AM
    #705
    Mannra
    Mannra New Member
    2022 SR5 TRD OR 4WD
    Ah yes, it seems that date + hybrid is likely the reason?
    Tundra/LX - 2022, non hybrid models
    Sequoia - 2023, all hybrids
    GX - 2024, non hybrid models
    That being said, are there still a similar volume/rate of failure reports, especially of the Sequoia? Many Tundra failures happened very early on.
  16. Aug 5, 2024 at 9:02 AM
    #706
    Really? There's two in here
    https://www.tundras.com/threads/3-4-i-force-engine-failures.121107/
  17. Aug 5, 2024 at 9:19 AM
    #707
    WNY PAT
    WNY PAT New Member
    There are 2024 failure reports here and on FB, documented well enough for me. I don’t Reddit either tho, maybe there are even more reports there. But this problem doesn’t seem to be going away.
    I”m honestly more interested in seeing if any of the newly installed long blocks fail versus the blocks installed during assembly. We know for a fact that 2022/2023 motors are failing at a high enough rate for Toyota to issue a recall of over 100K trucks, and at least some of those trucks/blocks were manufactured after Toyota announced the fix. After that first fix, the bearing part numbers were quietly changed and there continued to be failures. If there are ultimately changes to the engine internals, we will know soon enough I’m sure. If there are no internal changes to the motor, and reports of failures dry up, that’ll be great too.
  18. Aug 5, 2024 at 9:21 AM
    #708
    sudobash
    sudobash New Member
    The Sequoia HV started production in September 2022.
  19. Aug 5, 2024 at 9:22 AM
    #709
    A man in the know.
  20. Aug 5, 2024 at 9:24 AM
    #710
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    For Toyota to exclude Tundra Hybrids it tells me.
    That if the Gas engine failed 100%, the hybrid takes over completely.
    Asssuming it is not something you can simulate in normal driving.
    This would safisfy the safety issue and the reason for the recall.
    Am I giving Toyota too much credit for this type of design ?
    Would the Toyota Service Dept be able to confirm this ?
    Teddyk1 likes this.
  21. Aug 5, 2024 at 9:26 AM
    #711
    AZBoatHauler
    So.Arizona
    Ryan Gregg alluded to a date in late June saying it’s an important date but then was told by his lawyer to shut up. If I were a betting man - something changed 6 weeks ago that has Toyota believing they’ve resolved the issue. That would mean nearly every engine made before July 2024 is subject to the same failure.
  22. Aug 5, 2024 at 9:27 AM
    #712
    sudobash
    sudobash New Member
    Lexus LX600 - Production began December 2021
    Tundra - Production began November 2021
    Tundra HV - Production began April/May 2022
    Sequoia - Production began September 2022
    GX550 - Production began December 2023
    PermaFrostTRD, kirkb and AZBoatHauler like this.
  23. Aug 5, 2024 at 9:46 AM
    #713
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Send it!
    Mr Badwrench and 4genRunner like this.
  24. Aug 5, 2024 at 9:49 AM
    #714
    brtnstrns
    brtnstrns New Member
    2024 Tundra Platinum HV; 2022 Polestar 2
  25. Aug 5, 2024 at 9:53 AM
    #715
    AZBoatHauler
    So.Arizona
  26. Aug 5, 2024 at 9:54 AM
    #716
    AZBoatHauler
    So.Arizona
  27. Aug 5, 2024 at 9:54 AM
    #717
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    So if the gas engine blows up, the truck magically transforms to a plug in EV? :D
    PermaFrostTRD and PBNB like this.
  28. Aug 5, 2024 at 9:55 AM
    #718
    AZBoatHauler
    So.Arizona
  29. Aug 5, 2024 at 9:56 AM
    #719
    AZBoatHauler
    So.Arizona
    Should we keep going?
  30. Aug 5, 2024 at 10:03 AM
    #720
    Breathing Borla
    AZ
    interesting, why does he have a lawyer ? sorry not on FB
