Tundra down....
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTU19, Mar 21, 2021.
  1. Mar 23, 2021 at 3:11 PM
    #61
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Two sides to this accident. If not totaled you get diminished value which usually exceeds repair cost. bottom line truck not worth as much after wreck. Continue to reject any aftermarket parts by showing body shop where they don't fit right, and they won't. gaps won't be the same on each side, there will be high spots / low spots along the body lines. No worries auto shops love it. they get paid to use the crap aftermarket parts and they get paid to install the new OEM parts which are usually 5% more. That good for you also the higher the repair bill the bigger the diminished value.
  2. Mar 23, 2021 at 3:50 PM
    #62
    Ellis42sbgtf
    Ellis42sbgtf New Member
    Kyle
    Houghton, MI
    2018 Crewmax TRD Sport 4x4
    Won't the other driver's insurance company be paying for it? I would definitely fight them to cover enough to buy a year newer Tundra. You probably have some leverage to negotiate. This could more than easily become a lawsuit and I'd be willing to bet they'll jump a little to avoid one. Maybe that's not the best line of thinking, but, take it with a grain of salt.
  3. Mar 23, 2021 at 4:03 PM
    #63
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    I live in TX - some of the worst drivers I've ever seen here. Glad you're ok.
    chickunfut and Astom22 like this.
  4. Mar 23, 2021 at 4:06 PM
    #64
    Tom_Tundra_TN
    Tom_Tundra_TN New Member
    Tom
    2016 TRD CM
    TRD Exhaust, TRD Front&Rear Sway Bar, TRD Shifter Knob, BFG TAKO2, Toyota GBS, 3/1 Leveling Kit, K&N CAI, Leer 100XQ Topper, Tinted Windows, Tacotunes Upgrade, Bed LED Lights, Mirror Caps & Door Handle Color Match, BedRug, LED Interior Lighting, Tailgate Tundra fill, Toyota Step Rail, Katzkin Leather Seats, Leather Console, FRAC Harness, Stubby Antenna, Power Folding Mirrors, Autoloc One-Touch Window Mod, TRD Pro Wheels w/ Lug Nut Covers, Color Match Bumper Ends
    Glad you're Okay. Stay safe.
  5. Mar 24, 2021 at 9:56 AM
    #65
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    First off -very happy that you are both okay. The truck can be replaced if not repairable.
    Secondly - I think your crash was the "offset front collision" crash test that got the Tundra the bad NTSB crash rating on that test. It also inspired Toyota to remove the driver's side grab handle to prevent it from hitting the driver in a collision that collapsed the A pillar.
    For the OP - It would be great to know a few things if you are willing to share:
    What did the inside of the vehicle look like after the collision?
    Did it collapse to anywhere near where you were sitting - either your head or lower body?
    And what speeds were both you and the other driver traveling at the moment of the collision?
  6. Mar 24, 2021 at 10:02 AM
    #66
    BluegrassPro
    BluegrassPro New Member
    Jeff
    2021 TRD Pro
    I think it’s totaled then if that’s the value before. That’s $15-20k of damage easily. Like I mentioned before my wife’s was 18k but hers was newer and worth $34k at the time so it didn’t total.
  7. Mar 24, 2021 at 12:28 PM
    #67
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited *sold*
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    To us, no but to the industry standard
    Exactly to us , never will meet the quality, to them though as long as it meets "industry standard" which is a low bar its fine. Keep fighting it. Also given the circumstances of the wreck I'd hire an accident attorney
  8. Mar 24, 2021 at 12:45 PM
    #68
    Wallygator
    So glad you and yours are ok! The truck is nothing compared to you all. I vote it's totaled
  9. Mar 24, 2021 at 1:17 PM
    #69
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    -Inside was perfect as far as I could tell. My door was a little off when opening.
    -No
    -I was going 35-40, think he was doing 50-55.
  10. Mar 24, 2021 at 1:28 PM
    #70
    18" TRD Off Road Wheels
    The Tundra definitely did it's job keeping you guys safe. I'm glad for that, but it always sucks when you lose a vehicle you've loved. I hope you are made whole with as little hassle as possible, and that no one has any kind of lasting injuries. Always best to get checked out after an accident. A fellow I knew had 3 broken vertebrae after an accident, and didn't feel it for 2 days. Make sure you guys are both completely ok and everything is on record before you accept any kind of insurance agreement.
  11. Mar 25, 2021 at 12:15 PM
    #71
    CreekDweller
    Thanks for sharing that. It's incredible that you had a combined closing speed that high and were not injured. And that the truck isn't damaged much more than it is. Should give us all additional confidence in the ability of this truck to absorb an offset front collision when you were able to walk away uninjured. At least when the other vehicle is a smaller car, though even the Mitsubitchy did pretty well.
    I'm pretty sure that it was in the NHTSA front partial overlap test that the Tundra tested worse than newer designed pickups. But in your case, it performed like a champ.
    TTU19[QUOTED][OP] likes this.
  12. Mar 25, 2021 at 12:21 PM
    #72
    AZBoatHauler
    So.Arizona
    I’m pretty sure the front-end offset crash test is done with the impact inside the frame rail. Here - it appears the impact was outside the frame rail. I believe this is the reason his airbag didn’t deploy - those sensors sit just a few inches outside each side of the radiator.
    Wallygator likes this.
  13. Mar 25, 2021 at 12:49 PM
    #73
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    @TTU19 glad everyone is OK, I feel your pain on that one. I had a similar accident, except airbags deployed. The other driver was going 60+ MPH when she hit us though.
    Accidents just plain suck. These Tundras do take a hit pretty well though, I was very impressed.
    YotaBro, GODZILLA and TTU19[OP] like this.
  14. Mar 25, 2021 at 8:31 PM
    #74
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Ouch.. hope everyone was ok. Yeah, Tundra absorbed it pretty well. This past week has sucked though. Dealing with insurance and rental cars, blah...
    sf319[QUOTED] likes this.
  15. Mar 25, 2021 at 9:38 PM
    #75
    sf319
    sf319 New Member
    Utah
    Everyone survived, my wife and I had to go through some physical therapy etc. The kids walked away pretty much unscathed. I was told that no matter how big the settlement is after an accident, it will never make up for the loss. Good luck with insurance, they will nickel and dime you that's for sure.
    Astom22 likes this.
  16. Mar 26, 2021 at 7:21 AM
    #76
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    And sadly, almost half of the cars on the road down here are uninsured!
  17. Mar 26, 2021 at 7:26 AM
    #77
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    I have been lucky enough to never be in an accident where airbags deployed, what is the sensation as the driver? Does the steering airbag blow your hands off the wheel? Just curious and if you don't want to share, I totally understand. I have watched videos on it, but never heard from an actual person what the experience was like inside the vehicle at that moment.
  18. Mar 26, 2021 at 8:01 AM
    #78
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Glad y’all are OK, that’s the most important thing. Hopefully they’ll total it and you can get a new ride. If they try to fix it, make sure you consider a diminished value claim, I believe you have to get an attorney involved but a quick Google search should help with more info.
  19. Mar 26, 2021 at 9:01 AM
    #79
    The Towse Tundra 2.0
    The Towse Tundra 2.0 New Member
    Loy
    2021 Lunar Rock Tundra TRD Pro Crewmax
    TRD Inlay Package, Spray-in Bedliner, Cargo LED Light, Power Tailgate Lock, Center Console Safe, MX4 Bakflip Tonneau Cover, CaliRaised LED Rock Sliders, Nitto Ridge Grapplers 275/70/18, Rigid Industries Amber Fog Light Covers, Coachbuilder TRD Pro lift kit
    That’s terrible. I’m happy you guys are ok. That’s my biggest worry when driving my Tundra is other drivers....
  20. Mar 26, 2021 at 9:05 AM
    #80
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    No airbag?
  21. Mar 26, 2021 at 10:00 AM
    #81
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Nope.. it didn't pop.
    sf319 likes this.
  22. Mar 27, 2021 at 10:40 PM
    #82
    sf319
    sf319 New Member
    Utah
    Airbags are weird, I didn't even realize I had hit mine, but I had the burns on my face and arms to prove it. The seat belt bruising from holding me in the seat was more painful than the airbag burns. I posted on here after it happened. Post 29 has the dash cam of the accident.
    https://www.tundras.com/threads/tundras-save-lives.49006/
    Astom22[QUOTED] likes this.
  23. Mar 28, 2021 at 9:01 AM
    #83
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The best way I can describe it is to have taken a blow to the face while in a pillow fight with Chuck Norris. I was bracing against the wheel with a death grip at about the 3:00 and 9:00 positions (probably the worst thing you can do, but a very natural response), and no, my hands weren’t blown off the wheel. My glasses were sent flying, and I had slight cut on my forehead from that. I did have some very minor abrasion on my inner forearms from the bag, but that was minimal. I do think my whiplash injury would have been much worse without the airbag.
    That was an angled T-bone into a Sonata when doing about 50 mph in my Tacoma. I spun 180 degrees on impact and was still moving for what seemed like an eternity.
    joonbug likes this.
  24. Mar 28, 2021 at 9:25 AM
    #84
    ATCinfantry
    ATCinfantry Pot Stirrer
    Trey
    Memphis, TN
    2017 Toyota Tundra MGM SR5 TSS Off Road Package
    Running Boards. AJT YEET Chrome interior kit. Tonneau cover. More Mods Coming SOON!
    USAA tried to screw me one time. My wife was driving a Honda S2000 and someone hit it at her work in the parking lot. Guy was driving a F150 and basically ran over the front of the car. We both had USAA insurance and they tried to put "refurbished" parts on it. They basically said "take us to court". So I came out of pocket to get OEM parts replaced. I then cancelled all of my insurance policies and moved all of my bank accounts. I'll never do business with USAA again and regardless of what they say, they don't give a shit about veterans.
  25. Mar 28, 2021 at 9:31 AM
    #85
    RRR1C0
    RRR1C0 New Member
    2014 SR5 TRD CrewMax
    Riding on 275/70R18 Toyo AT3s w/ 1.75” RC leveling kit.
    Glad you guys are ok, stay safe out there!
  26. Mar 28, 2021 at 9:56 AM
    #86
    sf319
    sf319 New Member
    Utah
    Also the pillow is made of heavy canvas. This is a really good explanation!
    landphil[QUOTED] likes this.
  27. Mar 28, 2021 at 10:27 AM
    #87
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    Thanks for sharing and glad you are both good coming out of it. I hope to never know airbags for myself, I wear glasses and they have always worried me, since I have been cut in other incidents where I was hit in the face various times. I always assumed an airbag would be worse.
  28. Mar 28, 2021 at 10:31 AM
    #88
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    Was the guy that hit you drunk? That's crazy how he just crossed over into you.
  29. Mar 28, 2021 at 5:31 PM
    #89
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Video says DUI, so I'd assume so.
    sf319 and Astom22[QUOTED] like this.
  30. Mar 28, 2021 at 5:48 PM
    #90
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    I graduated in Oklahoma.... My reading skills are suspect at best...
    BTBAKER, sf319 and TTU19[QUOTED][OP] like this.
