Tundra Bed to Axle alignment?
Discussion in 'General Tundra Discussion' started by 1794TRD, May 9, 2018.
What would you do to address the bed issue?
  1. Contact the factory, complain, and see if they will make this right (I have 44,000 miles on truck, s
    1 vote(s)
    8.3%
  2. Call the dealership and inquire if they can assist with the issue?
    8 vote(s)
    66.7%
  3. Knock the bed coating off the bed bolts and try to adjust myself, and then respray with some ra
    3 vote(s)
    25.0%
  1. Mar 12, 2019 at 7:54 PM
    tundraforme
    tundraforme New Member
    Em
    Vancouver, BC
    2018 Tundra TRD Off Road Quicksand
    I'm using a general alignment shop which came highly recommended and where all the shops that do lifts on 4x4s take the vehicles before handing the keys back to the owners - we talked about tire pressure and my lift and future plans for a locker/4" lift and different tires etc as well way before the headache got worse. SUPER knowledgeable. Like, I'd marry this guy for his brains and mechanical ability if he was single!! ha ha! not kidding!!! :D
    I will definitely be in better shape next time so should remember everything that happens. Kiddo gave me the sinus infection ugh
  2. Mar 14, 2019 at 2:12 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    So you finally found a guy to loosen the U-bolts and knock your axle over. :amen::bananadance:
  3. Mar 14, 2019 at 2:17 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    BTW, the ones who voted on the 3rd line will have results.................how's those phone calls going with the dealerships and manufacturer.
  4. Mar 24, 2020 at 7:38 AM
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    I hope we’ve all learned this has nothing to do with the bed. Measure the distance from frame to wheel. Mine is 1” further out on passenger side. If I could move my axle 1/2” to the left, that would center it. But I don’t think the alignment pins on the springs allow any movement in any direction. It’s a fault that Toyota isn’t bothering to correct. That’s shitty engineering.
  5. Mar 24, 2020 at 10:10 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Do you have a rear lift?
  6. Mar 24, 2020 at 12:05 PM
    Keithbickford
    Keith
    Seattle
    I do. I have Toytec shackles providing 1.5" lift. It was the same when I used block spacers for the lift.
  7. Mar 24, 2020 at 12:28 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    If you messed with the u bolts I'd say there is a specific sequence to tighten those down to prevent this issue from being accentuated
  8. Mar 25, 2020 at 8:57 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Leave well enough alone. It’s even the same on other manufacturers.
  9. Mar 26, 2020 at 5:07 AM
    Spoony1
    Spoony1 New Member
    2016 tundra platinum crewmax
    Trd pro grill color match door handles and mirror. 4 1/2 bds lift
    I put 3/4” spacers on my 3 other wheels problem solved.
  10. Dec 28, 2020 at 11:04 PM
    JRP
    JRP New Member
    Any updates about this, OP?
  11. Dec 28, 2020 at 11:19 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    I would have never noticed it myself.
    As for my wife on the other hand, she could detect a 3/4 inch difference easily (said with tongue in cheek of course).
    Sorry, couldn't help myself..........I'll go back to reading the forum.
