Tugging tow
Discussion in 'Towing & Hauling' started by tlakeTundra, Aug 15, 2020.
  1. Aug 17, 2020 at 12:15 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Find out where the water tank is first on the chassis. My trailer is same gvwr. I just put a 40lb toolbox and a bunch of kettlebells in the storage for testing and hitch adjustment
    tlakeTundra[OP] likes this.
  2. Aug 17, 2020 at 7:24 PM
    tlakeTundra
    tlakeTundra [OP] Flying Pig 2.0 aka "Porkasus"
    Robert
    Torrance
    TSS 4x4 Off Road White
    20" Wheels, TSS package, tint, flow master exhaust, TRD sway bars Front and Rear, Tow mirrors. Husky mats, X liner chrome delete, Carhart seat covers, Transfer Flow 46-gallon gas tank, Driver side hand grab
    The hitch receiver I checked and it has a bit of side to side play in it, may be another culprit. I can attach photo. Thinking I need to fill water tank only 25%, full also. May take it for a neighbor loop with no electric plug into trailer and see if the brakes may or may not be part of the equation.
    Hbjeff likes this.
  3. Aug 17, 2020 at 7:50 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The ball mount portion is moving on the post portion?
  4. Aug 17, 2020 at 8:03 PM
    tlakeTundra
    Robert
    Torrance
    It is solid on the ball mount except for some side to side slop
  5. Aug 17, 2020 at 8:14 PM
    Maadcaap
    Maadcaap White Tundys
    Rancho Cucamonga, Ca.
    2019 Trd Pro
    275/70/18 KO2
    On a side note.. you can rotate your smart jack 180° and then you can lower your tailgate without it getting in the way.. (when parked for loading/unloading)
    JC303 likes this.
  6. Aug 17, 2020 at 10:39 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I forgot to ask this, did you up your rear tire pressure? If it is too low youll get bounce
  7. Aug 18, 2020 at 2:01 PM
    tlakeTundra
    Robert
    Torrance
    I have a gauge and will report back ! Yet ....... they put nitrogen in the tires, could this be part of it? Plus when one needs air there would only be a few places to go for nitrogen. Hhhhhhmmmmmm
  8. Aug 18, 2020 at 2:02 PM
    tlakeTundra
    Robert
    Torrance
    Or was that Tundra rear tire pressure?
    Hbjeff likes this.
  9. Aug 18, 2020 at 2:04 PM
    18" TRD Off Road Wheels
    Nitrogen in your tires would not cause this. The whole benefit of Nitrogen is that it bleeds pressure more slowly and is moisture resistant. You can just add regular air (mostly nitrogen anyway) with out hurting anything.
    He meant the truck's rear tires.
    Hbjeff likes this.
  10. Aug 18, 2020 at 2:10 PM
    When you say your hitch has side to side play, where is the play? Option 1, or 2?
  11. Aug 18, 2020 at 2:24 PM
    tlakeTundra
    Robert
    Torrance
    That would be option 2 and thx
  12. Aug 18, 2020 at 2:30 PM
    Ok, a little movement there is pretty standard. Nothing to worry about.
  13. Aug 18, 2020 at 2:31 PM
    tlakeTundra
    Robert
    Torrance
  14. Aug 18, 2020 at 2:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Very normal
  15. Aug 18, 2020 at 2:49 PM
    NHPig
    NHPig Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    Subb'ed, dealing with the same issues. More weight on tongue and less weight distribution (3 links of chain as opposed to 4) seemed to help a little.
    I am going to try the tire pressure thing. I run my LTs at 42, normally.
  16. Aug 18, 2020 at 2:50 PM
    Yeah, generally if you are going to tow you need to bump the pressure up more than the daily driving pressures.
  17. Aug 18, 2020 at 2:51 PM
    NHPig
    New Hampshire
    Where should I start, 5 or 10 pounds more?
  18. Aug 18, 2020 at 2:52 PM
    I'd go to 50 PSI to see if there is an improvement.
    tlakeTundra[OP] and NHPig like this.
  19. Aug 18, 2020 at 2:58 PM
    #49
    13TundraRW
    13TundraRW New Member
    Kyle
    San Diego, CA
    2013 White Tundra CM RW
    MCM UCA, MCM Shackles, 2.5 ADS C/O, Durobumps Front, Deaver U748, 2.5 ADS Bypasses, Wheelers/Timbren bumps rear, SoftTop
    I would recommend loading the trailer with all your gear, water. Take it to a flat street and make sure the truck and trailer are level. If not adjust the WD bars and hitch as needed. Then adjust the break controller. Take for test drive and see if it still has the issue.
  20. Aug 18, 2020 at 3:06 PM
    #50
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    @Scuba has a very good write up regarding LT tires and pressure. Look uo his threads.
    LT tires may need closer to 60-65 psi depending on the load. 50psi in my P rated tires is going to act different and hold less weight than 50psi in an LT
    also a good idea to take a baseline measurement before adjusting the hitch. Measure your front wheel wells without and with the WD bars on. This will let you know if you have it set properly or too tight. You want tongue weight, but you also want weight distribution for steering. The trailer load is easier to play with. Keeping ice chests and easy ups for example ahead of the axles.
  21. Aug 18, 2020 at 3:13 PM
    #51
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    i use to have this same issue. Then i just got rid of my Reese Trunnion Bar Hitch and I purchased a Hensley Cub Hitch. Problem was solved. No more tugging, no more sagging, no more trailer sway.
  22. Aug 19, 2020 at 11:43 AM
    #52
    tlakeTundra
    Robert
    Torrance
    So apparently my payload is 1500 lbs or a touch higher. Tires are supposed to be P255's but I do not know if the TSS 20inch wheels are in that equation. Wife has truck at work.
  23. Aug 19, 2020 at 11:47 AM
    #53
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    On my 2020 TRD Sport DC my tires are 275/55/20 and pay load is 1320# and towing cap is 9600# all according to the manual and the code on the drivers door jam. What is your truck again?
  24. Aug 19, 2020 at 3:40 PM
    #54
    tlakeTundra
    Robert
    Torrance
    1,440 – 1,560 lbs payload , 9,800 lbs tow capacity but ... Tire is a 275 55R20 Goodyear wrangler ck images that are coming soon
  25. Aug 19, 2020 at 3:53 PM
    #55
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Its a matter of preference, I prefer my trailer brakes to be a bit fast or heavy depending on how you look at it.
    Load your trailer fully, tanks, gear etc. and then set your brakes.
  26. Aug 19, 2020 at 5:32 PM
    #56
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    I don't think your tires will be an issue at all.
  27. Aug 19, 2020 at 6:37 PM
    #57
    tlakeTundra
    Robert
    Torrance
    Process of elimination contiunes
  28. Aug 19, 2020 at 6:43 PM
    #58
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Whats the pressure at? Some tss trucks had bfg at tires, which may be LT?
  29. Aug 19, 2020 at 7:20 PM
    #59
    Maadcaap
    2019 Trd Pro
    275/70/18 KO2
    When the trailer hits the rough patches of road it will bounce and flex.. you will feel feedback inside the truck.. southern cali roads are not the best.. i feel my trailer hitting the freeway overpasses and concrete expansion joints.. but when i am on smooth pavement like hwy395 its a very smooth ride..
    I do like to drive a few miles with the windows open to listen to the trailer.. dont laugh, but i am listening for anything metal to metal, or sqeaking excessively.. I do a walk around when re-fueling.. looking at tires, and wheels and tow hitch... etc..
    If you had slop in your ball hitch setup you would hear and fewl it every start/stop.. I do put a wrench on all bolts on the hitch setup just to mke sure nothing has worked loose..
    Sounds like a lot of work, but it only tkes a few minutes and gives you peace of mind...
  30. Aug 19, 2020 at 9:51 PM
    #60
    Only to tow AS
    Only to tow AS New Member
    2020 Limited CM 4x4
    Read, and then reread the the thread, but still confused.
    Tugging when towing at constants speed would be indicate you feel a pull backwards (trailer tugging on Tundra). Is this what you are experiencing?
    If so, this means the trailer is slowing and pulling against the truck.
    Based on the picture, I can't see where your emergency brake is attached to the truck. Could you be engaging the brakes on the trailer during rough roads?
    Boucning (up, down and side to side) and a little movement backwards is somewhat normal on rough roads.
