Truck seats
Discussion in 'Detailing' started by Franco4x4, Aug 9, 2020.
  1. Aug 9, 2020 at 8:11 AM
    Franco4x4
    Franco4x4 [OP] New Member
    2019 tundra CM
    Any recommendations on how to clean stains on the seats and some seat covers. 250 is what I'm looking to spend on the covers.20200808_083651.jpg
    CardiacNole likes this.
  2. Aug 9, 2020 at 8:13 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Everythng I use is a temp solution, stains seem to come back, I like these cloth seats my tundra have but face it they are stain magnets.
    Franco4x4[OP] likes this.
  3. Aug 9, 2020 at 8:14 AM
    CardiacNole
    CardiacNole New Member
    Mark
    Tallahassee, Florida
    2020 Tundra CM 4x4
    I’m interested in this as well. I have a ‘20 and am finding if any water gets on my seats it leaves a water ring. My seats already look terrible. So if you get a stain and try to remove it with water or a cleaner your left with a water stain.
  4. Aug 9, 2020 at 9:08 AM
    biebs96
    PA
    A damn microfiber cloth, blot the stain then use a dry microfiber cloth.. stain gone.
    My seats looked horrible after getting in after a bad rain storm. All marks are gone.
  5. Aug 9, 2020 at 10:30 AM
    briarpatch
    briarpatch New Member
    Stains that 'return' are usually the result of something that got into the padding and now wicks back up after you get rid of the superficial stain. Biebs96 said the secret word.....blot. Use as little water as possible to lift the stain from the material without reactivating a stain that might be hiding underneath.
    Your other option, which is more time consuming, is attacking the stain with cleaning solution, a drill brush, and then an extractor. Dozens of YouTube detailers are using this method with success. I used it on my daughters Hyundai and it does work very well.
    As far as seat covers go, I've not been able to justify pulling the trigger on good ones that are actually custom fit to the truck. The seats in my 2013 do not seem all that susceptible to staining, and I only have one 'universal fit' cover on the drivers seat...there's a small tear on the bolster nearest the door that I did not want to get any worse.
  6. Aug 9, 2020 at 10:34 AM
    briarpatch
  7. Aug 9, 2020 at 10:41 AM
    Franco4x4
    2019 tundra CM
  8. Aug 10, 2020 at 6:50 AM
    owb2gp
    owb2gp New Member
    ID
    I sprayed my seats this spring with 3M scotch guard after I cleaned my seats. Water beads right off. Will probably do it again this fall. Sick of water staining my seats.
  9. Aug 10, 2020 at 7:05 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    Had similar stain last year - took mine to my local detail shop.
    He told me you have to clean the whole seat, not just one spot.
    Charged me a hundo to do the whole inside. Front and back, floors and all trim.
    No more stains.
  10. Aug 24, 2020 at 5:14 PM
    Buckeye1977
    Buckeye1977 New Member
    For any stains I use Folex.
