Truck does not accelerate, need help
Discussion in 'General Tundra Discussion' started by pdiddy, Nov 28, 2018.
  1. Dec 4, 2018 at 11:56 AM
    pdiddy
    pdiddy [OP] New Member
    2017 platinum
    Icon 17 rebounds, total chaos UCA's, general grapplers 35's, corsa exhaust chopped, fox 2.5 DSC coilovers, DAP, white knuckle sliders, voodoo bed rack, baja lights everywhere, VLEDS, bedslide, C4 front bumper, warn winch, victory high hitch with dual swing out rear bumper
    Thanks @iHacker I will do exactly as you recommend and let you know what happens. Probably can't get to till the weekend, thanks.
    iHacker[QUOTED] likes this.
  2. Dec 4, 2018 at 11:58 AM
    pdiddy
    2017 platinum
    Thank you sir this is why I don't like messing with electrical because I know jack crap about it lol.
    15whtrd[QUOTED] likes this.
  3. Dec 4, 2018 at 12:00 PM
    15whtrd
    15whtrd Mr. Blonde
    I can do basic wiring but when it comes to adding diode‘s and relays I call it quits without a proper diagram. That’s why my tail lights are stock LOL. I like plug and play shit.
    pdiddy[QUOTED][OP] and landphil like this.
  4. Dec 4, 2018 at 12:30 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    This was the key phrase in making me think it was something with the brake light circuit, since that is how the accelerator interlock programming is designed. Throttle pedal input gets ignored when the ECU sees a brake application after the throttle is depressed, and the engine defaults to idle.
    Throttle input after the brake is applied gets recognised, example: if you were starting up a steep hill, like a boat launch, and need throttle before releasing the brakes fully.
    The whole thing was in response to the “unintended acceleration” complaints with Toyotas almost 10 years ago, along with the shortened throttle pedals and floor matt securement.
    Voltage feedback on the brake light circuit was also likely the cause of the ABS / VSC fault. I’m guessing you don’t use cruise control much, since you didn’t mention it kicking out for seemingly no reason.
    And yup, some weird and wacky things happen when electronics and relatively simple electrical faults get mixed together. Glad one part of the puzzle is solved, good luck with the headlight issue.
  5. Dec 4, 2018 at 1:59 PM
    pdiddy
    2017 platinum
    Thanks I don't get shutter and I will try tonight
  6. Dec 4, 2018 at 2:02 PM
    pdiddy
    2017 platinum
    Thank you again, I can live with the headlights turning off for a second I will test what ihacker wants me to switch the harnesses. My truck was sketchy to drive in LA traffic trying to make left turns with on coming traffic and truck not moving not good lol.
    landphil[QUOTED] likes this.
  7. Dec 4, 2018 at 2:29 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    Glad to hear no more stutter on acceleration.
    pdiddy[OP] likes this.
  8. Dec 4, 2018 at 5:56 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Wondering what does @Headlight Revolution have to say about your problem with their bulbs
    pdiddy[QUOTED][OP] and 15whtrd like this.
  9. Dec 5, 2018 at 8:48 AM
    pdiddy
    2017 platinum
    When I called and explained the problem of the bulb being loose and constantly falling out. They told me that's an issue they knew about and even if they sent me a replacement it would do the same thing. I explained to them that currently I had taped the bulb with electrical tape and they said that's something they would do and it's perfectly fine and recommended I do that lol. Pretty crappy how they would sell expensive ass bulbs that don't fit correctly. I don't remember how many times the bulb fell out and I had to remove the tail light housing and tape again and again. I researched the VLEDS designs and they have done their R&D and this won't be an issue with their products. I should receive today, thanks.
    landphil likes this.
  10. Dec 5, 2018 at 9:27 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    I have heard nothing but good things about vled. I was just curious if @Headlight Revolution would comment on here since they are I believe a vendor here and this isn’t good for their name.
    15whtrd likes this.
  11. Dec 5, 2018 at 9:41 AM
    TheBeast The Beach
    yep very happy with VLEDS. all my LEDs stuff is from them.
  12. Dec 5, 2018 at 9:55 AM
    pdiddy
    2017 platinum
    As will mine once UPS delivers my rear VLEDS today. Very happy with the VLEDS interior lights
  13. Dec 5, 2018 at 10:00 AM
    gm125800
    gm125800 New Member
    2018 GMC Sierra Denali
    Glad to hear i wasn't the only one dealing with that strange headlight issue.. I would occasionally hit the left turn signal and the cluster lights would shut off. (OEM headlamps)
    pdiddy[OP] and iHacker[QUOTED] like this.
  14. Dec 5, 2018 at 10:14 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Guys dealing with this problem (headlights or blinkers acting weird), I recommend you to carefully inspect your turn signal sockets, check everything and try to detect any water intrusion, clean every terminal and seal with alcohol and apply dielectric grease to terminals and seals to solve the problem if it’s a water related issue.
    If problem persists definitely have to find professional help to inspect the electrical system to detect what’s causing a short or feedback in the headlight/blinker circuitry (this could be caused in some cases by a loose or damaged connector, chewed wire, etc)
  15. Dec 5, 2018 at 3:26 PM
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Hey There!
    Super sorry for the delayed reply! We have been DESTROYED over here due to Black Friday, so I haven't had the chance to check up on my favorite truck crew! :(
    @pdiddy Can you PM me so I can help get this sorted out for yah? Or even better, reach me directly Via Email so I can get notified whenever you reply. We'll get you patched up, my man, no worries!
    Email: Caleb@Toplinegroupllc.com
  16. Dec 5, 2018 at 3:29 PM
    pdiddy
    2017 platinum
    Got it Caleb emailing you now
