Truck Bed
Discussion in '1st Gen Tundras (2000-2006)' started by James7x1, Jan 19, 2025.
  1. Jan 19, 2025 at 9:08 AM
    James7x1
    James7x1 [OP] New Member
    James
    2006 Toyota Tundra, Limited extended cab
    2006 Blue Tundra Limited
    I have a 2006 Toyota Tundra, Limited, 4.7L, Extended Cab. Searching for bed rail molding for the truck to replace the factory molding as they have faded badly. Can anyone point me in the direction of locating the molding?
  2. Jan 19, 2025 at 11:02 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The Black Mamba likes this.
  3. Jan 19, 2025 at 12:44 PM
    shifty` I'm having daydreams about night things
    The price on replacements for the original - which are not black, they're charcoal grey - is expensive. I know Bak had some alternate products, as did Westin, but they're in short supply, or being sold out of warehouses that managed to snag up old stock.
    I had great luck getting mine back to the original dark-dark grey color using Griot's products. That came after testing a shedload of other typical products from Mothers and others, which didn't work with a damn.
    PNW15 likes this.
  4. Jan 20, 2025 at 7:25 PM
    DBombs
    DBombs I Like Old Trucks
    NE Atlanta
    2006 Tundra DC SR5 V8 4x4 TRD
    If you end up refurbishing and not replacing, I’ve had good results and longevity spray painting them. You can do original grays or more black color. I’ve used normal spray paint and also more specialized like SEM Trim Black. I can send pictures if you want. Can’t get a good one now in the dark.
    A lot of detailers will tell you Solution Finish is a good trim restorer. You will see a lot of people recommend Cerakote. I’m wary of that one (despite good reviews) because if prep or application has any issues, you can end up with a finish that is difficult to remove.
