Trim & Plastic Restorer
Discussion in 'Detailing' started by BigArt, May 2, 2020.
  1. May 2, 2020 at 10:15 PM
    BigArt
    BigArt [OP] New Member
    2008 Tundra Crewmax Limited
    What is the latest and best option? Looking for something that last at least six months or so.
  2. May 2, 2020 at 10:23 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  3. May 2, 2020 at 10:28 PM
    BigArt
    I was looking at that too. this is the first time i've seen it on sale too.
    I'm hoping someone can comment on it that has used it.
  4. May 2, 2020 at 11:30 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
  5. May 3, 2020 at 1:04 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Solutions Finish trim restore
    RitcheyRch and ToyoMafia like this.
  6. May 3, 2020 at 3:46 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    @Pudge turned me on to this and it is an AWESOME product !!
    Pudge[QUOTED] and ToyoMafia like this.
  7. May 3, 2020 at 11:36 AM
    briarpatch
    briarpatch New Member
    Solution finish is probably the longest lasting of the products out there.....but it's main use is restoring older, faded plastic trim. Keep in mind, it's basically a dye and will need to be reapplied at some point. The results that I've seen are pretty impressive. If your trim is not that bad, and you just need a coating, Cquartz Dlux. Wolfgang Exterior Trim Seal is decent, but I've never gotten six months out of it.
    Pudge and War Machine like this.
  8. May 3, 2020 at 12:03 PM
    owb2gp
    owb2gp New Member
    ID
  9. May 3, 2020 at 2:10 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I’m putting in a order from shine supply so trim shield is in the cart along with clean and shine. Has anyone used the
    Pinnacle Black Label Ceramic Trim Defense Kit
  10. May 3, 2020 at 2:12 PM
    ToyoMafia
    Magic carpet.
    My solution finish will be here tomorrow.
    Pudge likes this.
  11. May 3, 2020 at 8:54 PM
    Istvank11
    Istvank11 Shine On
    AZ
    2016 CM
    I’ve only washed my truck a couple of times since I first applied this product. The gloss is outstanding without the greasy feeling. I ended up ordering a second kit because I like it so much.
    I feel like I should give you a heads up as far as the application goes. You want to make sure the plastic is clean and totally dry before applying. Put the product on liberally, let sit and gently wipe with microfiber cloth. Enjoy!
  12. May 3, 2020 at 11:02 PM
    BigArt
    okay, tried this stuff today. i'll report back after washing and time has passed.
    So far it looks great. my rear bumper was so faded and grey. it's back to black. i'll post some pics tomorrow.
    https://ruggedrestore.com/products/trim-renew
  13. May 4, 2020 at 3:38 AM
    War Machine
    War Machine SSEM # 5 3MW
    Solution Finish for restoration, Shine Supply Trim Shield for plastic that’s not faded yet.
    ToyoMafia likes this.
  14. May 4, 2020 at 4:22 AM
    War Machine
    If you’re ordering from them, I highly recommend Wise Guy tire cleaner and Spiked Punch waterless wash. Those are both head and shoulders above their competition.
    ToyoMafia[QUOTED] and owb2gp like this.
  15. May 4, 2020 at 4:52 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I have used 303 Aerospace Protectant for years now with very good results. It leaves a decent shine and takes a while to completely disappear. My vehicles are outside so I see how durable these products really are. It still needs reapplying but I never seen any trim product that doesn’t need reapplying.
    CMB, ToyoMafia and War Machine like this.
  16. May 5, 2020 at 5:31 PM
    BigArt
    I did my nerf steps and this stuff looks great. it is a dye so be careful and mask off painted surfaces.
    Pudge, War Machine and Istvank11 like this.
  17. May 5, 2020 at 6:07 PM
    Wallygator
    Do you use the 303 on the rubber around the windows or on your dash board? If so how is it on those surfaces?
    Oey12[QUOTED] likes this.
  18. May 5, 2020 at 7:41 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    I have used on both those areas with good success. However applying it can be a little tedious there. I find it’s very streaky and noticeable when on glass. I like it on the dashboard but you have to get every little crevice to make it look right.
    Wallygator[QUOTED] likes this.
  19. Jun 1, 2020 at 11:36 AM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
  20. Jun 9, 2020 at 9:10 PM
    SoCalTecHead
    SoCalTecHead New Member
    Tony
    Orange County California
    2020 Cement CM Limited
    I just put this on the Wife's FJ a few days ago as the bumpers and spare time cover were all badly faded (2011). It was easy to do, clean surface, apply with siupplied applicators, wait a few mins and buff off with a Microfibre towel. As of now they look like new! I had a guy that does detailing for a living recommend it. Time will tell how it holds up.
    Gtechniq C4 Permanent Trim Restorer
  21. Jul 18, 2020 at 9:49 PM
    SteyrM40A1
    SteyrM40A1 New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    Had anyone tried transmission fluid on trim? There is a really good YouTube channel by the name of Sweet Project Cars. He has a video showing how to use it on trim. Basically clean really good, let vehicle set out in the sun and get hot, apply transmission fluid let soak in.
  22. Jul 25, 2020 at 5:22 AM
    TH1776
    TH1776 New Member
    FL
    040 PRO
  23. Jul 25, 2020 at 6:07 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I use an old sock, put it on like a glove and spray the product on the sock, not the trim. I have several Microfiber Applicator Gloves too but they're used with Car Guys Sealant for my wheels.....yes, I have a problem:D
  24. Jul 30, 2020 at 1:10 PM
    turk
    turk New Member
    greg
    millersville pa
    2011 platinum
    aero space 303 on everything but leather inside and out.and for the engine after a de grease pig spit on entire engine compartment. i used both for well over 20yrs.
  25. Jul 30, 2020 at 2:25 PM
    BigArt
    Great, thanks it' sin my cart now!
  26. Jul 30, 2020 at 2:26 PM
    Pudge
    CT
    303 is good but is far from a restoration product. It lasts a week or so for exterior use. While I have it and use it for some stuff, it's not what you're looking for.
    Rocko9999, StephenTexas and ToyoMafia like this.
  27. Jul 30, 2020 at 3:31 PM
    ToyoMafia
    Magic carpet.
  28. Jul 30, 2020 at 5:53 PM
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    The cerakote is an awesome product very impressed with it
    War Machine and ToyoMafia like this.
  29. Jul 31, 2020 at 7:15 AM
    briarpatch
    What have you used it on? In your experience, how well does it hold up?
  30. Jul 31, 2020 at 9:51 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    owb2gp[QUOTED] and Pudge like this.
