TRD Pro ReadyLift +2
Discussion in 'Suspension' started by jamesmro, Apr 21, 2020.
  1. May 18, 2020 at 1:22 PM
    Mark73
    Mark73 New Member
    MGM 2020 Tundra TRD PRO
    ReadyLift SST 2” plus 2 Lift Kit, Coach builder +3 shackles & drop kit, Nitto RG 295/70/18
    No problem you’re welcome bud.
  2. May 29, 2020 at 10:28 PM
    Mark73
    Mark73 New Member
    Hey Murf which one of the coachbuilder carrier bearing drop kit did you install to correct the vibration on rear axle after you installed the ReadyLift 2 plus 2” lift kit. 0”-2” or 3”-5” ?? which one should I order. Is it based on the 2” before lift or the +2” After ReadyLift install. Maybe david@coachbuilder.com will chime in for his recommendations.
  3. May 30, 2020 at 7:37 AM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    I went with the 0-2” because it was only a 2” lift in the back.
    Mark73[QUOTED] likes this.
  4. May 30, 2020 at 11:34 PM
    Mark73
    Mark73 New Member
    Thank You, I got a quick response from David a Coachbuilder and recommend the 0-2” .75 kit as well.
    MaxYota likes this.
  5. Jun 4, 2020 at 10:51 AM
    TRDmedicPRO
    TRDmedicPRO New Member
    2020 Tundra TRD Pro
    Me
    Thanks for this thread. Just ordered the 2" SST + for my 2020 TRD PRO. Cant wait!!
    GarTX526, Mark73 and MaxYota like this.
  6. Jun 4, 2020 at 4:21 PM
    Mark73
    Mark73 New Member
    I just installed the Coachbuilder carrier bearing drop spacer to correct the shutter and vibration from rear axle/ drive shaft. The .75 spacer made all the difference and I installed it with zero issues. David at Coachbuilder shipped it out same day and with a great price of $20.25 total. Now looking to fix front end vibrations which run up the steering column when running over baby bumps on the road. I didn’t have this issue with stock UCA. I would recommend the carrier bearing drop kit spacers with the ReadyLift SST 2” +2 lift kit. I will post solution the vibration in front end when I find it. Hopefully someone might chime in?
  7. Nov 28, 2020 at 1:34 PM
    Fern
    Fern New Member
    2017 Cement TRD Pro
    How has the pro plus 2 treated you so far? Thinking about doing that or the CB but have a hard time justifying 1k for 1” of lift with the cb.....I’m now torn between leaving stock with the trd pro suspension and bigger tires vs the readylift pro plus 2
  8. Nov 28, 2020 at 1:40 PM
    Fern
    Fern New Member
    2017 Cement TRD Pro
    how has this lift worked for you?? Any complaints?
  9. Nov 29, 2020 at 8:05 PM
    MaxYota
    Murf
    MS Gulfcoast
    Great so far. The only part of the kit I used was the front. I have a 1.5” shackle and a 1” block for the rear. For me it’s the perfect height and look.
    Fern[QUOTED] likes this.
  10. Jan 15, 2021 at 9:24 AM
    434oldtrail
    434oldtrail New Member
    2018 Tundra
    jamesmro, is your truck a 2018. Is it lifted?
  11. Feb 25, 2021 at 10:53 PM
    JJ_TNDRA20
    JJ_TNDRA20 JJ
    SOCAL
    2020 TUNDRA TRD PRO SW
    *Wheels/Suspension -ReadyLIFT Plus 2 -ReadyLIFT skid plate adapter -Method MR701 18 x 8 + 25 -BFG KO2 305/70/18 *Exterior -BakFlip MX4 hard cover -Rigid Industries foglight caps *Audio -2 AudioMobile 10 in subs -Sealed dual 10 enclosure -Helix Class D 1 channel amp -Helix 4 channel amp -5 channel Line Out Converter -BLAM audio 6.5s/6x9s/tweeters
    good info on this thread...just backed out of the Plus 4 setup and opted for this one instead...gonna do the 305/70s as well...seems like a perfect height and not too big of a wheel...
  12. Oct 20, 2021 at 5:12 AM
    GWHunter79
    GWHunter79 New Member
    2007 N Blue Tundra
    I really like your setup! Thanks for sharing the pics. Best I can tell...you have good clearance on your UCAs. Are you running any type of spacer in these pics? Tires are 285/65s or 295/70s? It was hard for me to tell in the pics. Do the UCAs with the kit help with clearance at all or about the same? I'm a noob here but I've had Tundras since '07 and bought a 2021 Pro last year. It's time to give it a better stance. I'm not overly thrilled about running spacers is why I'm asking. Thanks!
  13. Oct 20, 2021 at 8:43 PM
    Mark73
    Mark73 New Member
    I’m running 295/70/18 with Borra 1.25 spacers. My stance improved and looks better. I think borra 1.50 spacers would give you a wider stance if your ok with the wheels sticking out more.
  14. Dec 16, 2021 at 2:58 PM
    Voodoo blue tundra
    Voodoo blue tundra New Member
    Corbin
    19 trd pro tundra
    Dual 40” led light bars behind the grill Dual 10” subwoofers
    I just ordered the ready lift 2+2 for my 19 pro and the instructions say you need to notch the lower control arm for the strut pocket. Wondering if anyone could get a picture of it to get an idea how much needs to be cut back.
    Mark73 likes this.
  15. Dec 16, 2021 at 3:20 PM
    Mark73
    Mark73 New Member
    I’m not sure. My local 4x4 shop installed mine.
  16. Dec 17, 2021 at 2:49 AM
    Voodoo blue tundra
    Corbin
    19 trd pro tundra
    I took this picture real quick last night so it’s kind of blurry but that is what it looks like factory. Those control arms are pretty pricy and don’t want anything to bind up if I don’t take enough off. And taking to much off and compromising the structure of it.
  17. Dec 17, 2021 at 3:57 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    @MaxYota do you have any pics of just the CB shin in the front, cb carrier and shackle?
  18. Dec 19, 2021 at 2:02 PM
    Voodoo blue tundra
    Corbin
    19 trd pro tundra
    I don’t have any pictures of those. I got in there to instal the lift and found a promenade fox strut spring and they are on back order for the drivers side which is what broke.
  19. May 2, 2022 at 7:01 AM
    #49
    Veritas
    Veritas New Member
    2020 Army Green TRD Pro
    I'm thinking of getting this lift and wondered if anyone knew why the TRD Pro version uses a replacement top hat and not a strut extender? Isn't changing the top hat the same as changing the pre-load? I like this lift because it comes with a diff drop to keep the drive shaft angles close to stock, but don't love the idea of changing the spring compression. Thanks.
  20. May 2, 2022 at 4:00 PM
    #50
    MaxYota
    Murf
    MS Gulfcoast
    It's not a pre-load the silver top hat is the two inches of lift so it should be the same spring rate. He ride quality stayed the same after lift. Been running it for about two years now.
  21. May 2, 2022 at 9:22 PM
    #51
    Veritas
    Veritas New Member
    I know the top hat pushes the spring down to create the lift, but it doesn't push the shock down. The shock still sits in the factory position. Thus, the spring sits lower than the shock (pre-load) and would lose the down travel equal to the height of the top hat, right? or am I missing something. I also noticed that the equivalent lift for a non-TRD Pro truck uses a strut extender which pushed the entire assembly down, thus not affecting travel.
    I wonder why the PRO version uses a different mechanism to create lift? All I can think is that the PRO model already has more travel than stock, and they do not want damage to the ball joints, so they use the shock to limit downward travel?
  22. Jun 8, 2022 at 7:34 PM
    #52
    Veritas
    Veritas New Member
    I went ahead and installed the TRD Pro ReadyLift +2. I'm super happy with the look. I have KO2s on the stock rim, 275/70R18. I think the size looks fine, maybe a touch small, but overall looks great. The ride quality of the truck is the same. I did notice that I lost some steering, I can't turn as tightly as I could before, but it's pretty minor. I've also noticed some creaking when turning hard and driving over and uneven surface. I hope that will go away with time once everything wears in, in the new position.
    I drove around some Forestry Service roads near Denver and it did great.
    I measured my droop before and after, as feared I lost about 1.3" of droop (downward articulation). Certainly not ideal, but so far I haven't noticed. Pics Below:
    Droop Pics
    Before:
    After:
    ready lift side.jpg ready lift front detail.jpg ready lift front quarter.jpg
  23. Jun 8, 2022 at 8:16 PM
    #53
    Mark73
    Mark73 New Member
    Looks good, 285/70/18 KO2 or even better 295/70/18 KO2 blackout for the next set.
    First Picture is with 285/70/18 KO2 & Second picture is with 295/70/18 Nitto RG.
    ackthresher likes this.
  24. Jun 9, 2022 at 8:27 AM
    #54
    Veritas
    Veritas New Member
    I would like to move up to a 285/70R18, but A) I just bought my current set of tires 5k miles ago and B) I worry about the hit I'd take to fuel economy and torque. I tow a trailer in the mountains and don't want to lose any more power than I have to.
    That being said, your 285s and 295s look great. Have you had any rubbing? I know with the 295s on stock the worry is that inside of the tire rubs on the UCAs or the sway bar. Have you had any signs of that happening with the ReadyLift UCAs?
  25. Jun 9, 2022 at 9:21 PM
    #55
    Mark73
    Mark73 New Member
    I have no rubbing after I removed the small mud flap up front. I didn’t see any power loss with either tire size. Gas mileage is no difference but I don’t really do any towing to give you that feed back.
