Transmission slipping?
Discussion in '3rd Gen Tundras (2022+)' started by Max713, Jan 21, 2023.
  1. Jan 26, 2023 at 6:18 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I understand tc lockup, but during acceleration in low gears? Never noticed anything like this on my 2019. Thought lockup only occurred in like 4th - 6th.
  2. Jan 26, 2023 at 6:32 AM
    My 1992 BMW did this. Vehicles with electronic locking torque converters can do this at any time, typically locks quicker in low load situations when no torque multiplication is needed.
  3. Jan 26, 2023 at 1:01 PM
    xc_tc
    xc_tc New Member
    Old Tundra is very old school. It almost never locks the torque converter. Many modern vehicles will lock the converter from very low gears, 2nd and some even in 1st depending on load.
  4. Jan 26, 2023 at 2:35 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    This is good to know. Thank you both. Makes me feel at ease a little more.
  5. Jan 27, 2023 at 5:48 AM
    blanchard7684
    blanchard7684 New Member
    I would look into this symptom here:
    Throttle lag/surge | Toyota Tundra Forum (tundras.com)
    There is alot of systems that are likely calibrated together that could lead to this symptom. Pedal tuning, TC clutch tuning, waste gate tuning, throttle tuning, valve body tuning...
  6. Jan 27, 2023 at 5:51 AM
    blanchard7684
    on 2019+ the TC lock up is aggressive and almost the opposite of your statement. That is how they were able to get away with removing the aux cooler.
    Toyota also has a TC lock up schedule that is unlocked, locked, and in between. All depending on several inputs from the vehicle.
  7. Jan 27, 2023 at 7:56 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Maybe that's why I didn't notice it. That and I had a B.A. Muffler exhaust and I loved hearing it, so I rarely putted a long.
  8. Jan 27, 2023 at 8:33 AM
    motojunkie
    motojunkie New Member
    South Florida
    2022 Tundra TRD OR 2023 Supra GR
    I did that TSB update myself yesterday. I think it does drive much better. Also fixes the clunk on start up too.
    Buildn[QUOTED] likes this.
  9. Jan 27, 2023 at 10:43 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    How did you go about doing the update?
  10. Jan 27, 2023 at 11:00 AM
    motojunkie
    South Florida
    I'm a ASM for Lexus Service dept. I can do any Toyota/Lexus TSB or recall that's software related with our TIS Techstream scantool.
  11. Jan 27, 2023 at 11:02 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Oh, so not just anyone can do their own. I have a PC version of TIS. Would I have to connect to their network to get the software?
  12. Jan 27, 2023 at 12:46 PM
    motojunkie
    South Florida
    I would say it's highly unlikely. You have to have a master Tech login to gain access to the updates in TIS. You can run a health check on the vehicle and see what updates or recalls are available. But once you try to select a download you have to have a master login to proceed.
  13. Jan 27, 2023 at 12:48 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Ok. Thanks. This should be a free update at the dealer correct?
  14. Jan 27, 2023 at 12:52 PM
    motojunkie
    South Florida
    Yes, just say the vehicle has a hesitation/lag when accelerating. They will perform the update for free .
  15. Jan 27, 2023 at 2:26 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Just got off the phone with service and the said they don't show any updates for my truck. My f-ing dealer ALWAYS seems to be behind. Motojunkie, would you have a TSB number or something?
  16. Jan 27, 2023 at 3:27 PM
    motojunkie
    South Florida
    They won't be able to tell you that on the phone just speaking to a Service Writer probably would not know. Just take it in have them write the truck up for the concern. When the tech runs a health check it will show a update for the transmission available. Quote the TSB
  17. Jan 27, 2023 at 3:35 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Well the service kept hanging up on me when I called back with the TSB #'s for them. So I contacted my salesman. He said those were for the certified Toyota techs to use for given issues. So I said make me an appointment. I've mentioned both of these things before the TSB came out and no one made notes or really acknowledged my issues. I have in our text messages where I tell him. Also he said that symptoms have to be replicated for them to do something about it. The clunking on cold start probably won't get replicated though. Thank you.
  18. Jan 27, 2023 at 3:44 PM
    motojunkie
    South Florida
    Anything done before the TSB came out for that issue the tech would have nothing to go on. Now that the new transmission logic update is available different story. If they give you any shit just ask to speak to the tech directly about it. The clunk on start up is part of that update as well.
    Kap1 likes this.
  19. Jan 27, 2023 at 3:46 PM
    #49
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Ok. I seen both issues had different TSB #'s. But 1 update resolves them both. That'll be good so maybe I won't have to leave it overnight.
  20. Jan 27, 2023 at 6:58 PM
    #50
    Duke_962
    Duke_962 New Member
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    Don’t compare different models and years. Manufactures will change things year to year with same equipment to see how it works out.
  21. Jan 30, 2023 at 9:33 AM
    #51
    Tundra9271
    Tundra9271 New Member
    2023 Tundra SR5 4x4 DC Lunar Rock TRD Sport
    Hmmm… is it not a valid approach with Toyota to have them proactively apply the TSB to a Tundra before I drive it off the lot if I specifically request it? Reading the experiences here it sounds like I have to encounter the issue first (regardless of how critical it is) and then after they perform diagnostic they use the computer to tell the technician whether or not the TSB should be applied. I would prefer to have mitigation for all currently known issues before I drive the truck off the lot. My build date is in February, do they apply all currently known updates for the issues during build phase perhaps?
    RickyBobbysTundra likes this.
  22. Jan 30, 2023 at 10:43 AM
    #52
    motojunkie
    South Florida
    Yes you will be fine, any trucks built now will have the most current updated calibration from the factory.
  23. Feb 1, 2023 at 7:55 AM
    #53
    lsb628
    lsb628 New Member
    2022 Tundra Limited CM
    I had all the symptoms described in this thread. Trans was really frustrating sounding like it's struggling or slipping up to 2.2k rpms until I hammer it on low speed hills tring to slowly accelerate. Truck is an April 22 build. Just had the reccomended software update posted here and all I can say is wow! Truck is night and day different. No clunk on cold starts so far either. I was told by the dealer first update was for the clunk. After that software install then the trans update was indicated so it sounded I needed two software updates. Why Toyota doesn't let people know about this one is strange. It really changed the way it drives.
    Kap1, Rockgate and motojunkie like this.
  24. Feb 1, 2023 at 8:35 AM
    #54
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    This is good to hear. I take mine in today to hopefully get these same updates. I was getting pissed at the service dept because they were telling me there were no updates for my truck. Like was said before, you have to "have" an issue, take in in, then they have to replicate the issue. At least what my salesman told me too.
  25. Feb 1, 2023 at 2:39 PM
    #55
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Just venting but I fu@&ing HATE going to the dealer service. Had an appointment. Got there on time. 45min before they attempt to diagnose. Tech drives it and confirms the hesitation and says "that's how all the new Tundras are" . Lady says he hooked it up but said there's no fix cause there was no cel on. Says there may be a recall down the road. Showed her the TSB and said tech showed her too and there's no fix. Waste of my GD time. Motojunkie, on my copy, it says basic diagnostic on both lines of work. Would that be any indication that they actually hooked it up? Also , service said it may be a slow roll out on the update. When was your truck built Motojunkie? Mine was May .
  26. Feb 1, 2023 at 3:11 PM
    #56
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I read through the last few pages of the TSB. Everyone who's replied having the issues say they're getting updated. My truck is a non hybrid. Is there anywhere I can check what vin is affected? Shouldn't a short term subscription of TIS allow me to do this? Thanks!
  27. Feb 1, 2023 at 3:25 PM
    #57
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Well somebody finally hit the nail on the head, normally aspirated or not a 3.4 don't cut it.
  28. Feb 1, 2023 at 8:08 PM
    #58
    Max713
    Max713 [OP] New Member
    Even though it makes more peak power, and more low end torque than your 5.7? Ok buddy...
    Tfbaker99, Skidmarcx and motojunkie like this.
  29. Feb 2, 2023 at 12:06 AM
    #59
    Roborob70
    Robert
    Let me throw on a supercharger and then we will talk then... ok buddy.
  30. Feb 2, 2023 at 1:54 AM
    #60
    Kap1
    Kap1 New Member
    San Francisco, CA
    Your dealer is just not good, try to go to another dealer. I just had TSB done yesterday without any pushback or test drives
    Buildn likes this.
