Transmission shudder '15 5.7 in first gear
Discussion in '2.5 Gen Tundras (2014-2021)' started by rt_tundra_co, Dec 5, 2018.
  1. Mar 9, 2020 at 5:51 PM
    #61
    rt_tundra_co
    rt_tundra_co [OP] I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    I changed the fluid at the dealer 10k ago. Same symptoms before and after.
  2. Mar 9, 2020 at 5:52 PM
    #62
    rt_tundra_co
    '15 SR5 CM TRD
    Smart move. Did you by chance try and measure the angle change before and after? I'd be curious to know.
  3. Mar 9, 2020 at 9:03 PM
    #63
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I didn't.
  4. Mar 10, 2020 at 4:25 AM
    #64
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    So, I finally got around to flipping my bearing as displayed the way it “should be.” Sure enough, there were washer imprints in the other side. I also installed 3/4” CB drop and the drive shaft appears much more straight but not inverted. There was a slight pre-existing shimmy at a launch-like take off that seems to be gone. I don’t drive it hard very often so I’ll have to pull up to a few more Prius’ at a stop light to know for sure.
    rt_tundra_co[OP] likes this.
  5. Nov 16, 2020 at 8:17 AM
    #65
    FSTsink
    FSTsink New Member
    Amazon or ebay will have carrier bearing. Spicer is the company to look for. I just replaced my 2006 Tacoma and it used Spicer from OEM.
    #65
  6. Nov 16, 2020 at 12:41 PM
    #66
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I'm curious about when and how much CB drop is needed under different circumstances.
    When I first lifted my truck, I used a 1" block and 2" shackle. The vibration was pretty bad... so I used a CB spacer kit (1.25") for a 2-4" lift. The vibration got better but was still pretty noticeable... so I went with the shorter 3/4" spacers. It's better... but I STILL have a vibration.
    Now I'm wondering if I just need to use a 1/4" or 1/2" thick washers instead.
    I never imagined the driveshaft angle would be so damn sensitive.
    I only notice it under hard acceleration when the leaf springs are twisting. If I pull out slowly, it won't vibrate at all.
    It seems like the pinion needs to be rotated down a couple degrees.
  7. Nov 16, 2020 at 4:48 PM
    #67
    19TurdPro
    2019 Tundra TRD Pro
    Take a pic of your carrier bearing and post it here. I can't count the number of times I've seen these installed upside down.
  8. Nov 16, 2020 at 4:52 PM
    #68
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Its never been off. Exactly as it left the factory.
    This pic is with the taller (1.250") spacers.
    Ive since swapped to the .750" spacers.
  9. Nov 16, 2020 at 4:55 PM
    #69
    19TurdPro
    2019 Tundra TRD Pro
    Yup, that's on right.
    Dragracer_Art[QUOTED] likes this.
  10. Nov 2, 2021 at 5:31 AM
    #70
    Audiolust
    Audiolust New Member
    2010 Tundra Limited
    Wanting to revive this as I am currently shopping a drop kit for my lift and am having issues on the correct drop spacer size. Wanted to go with Coachbuilder but they only have 0-2" lift and 3-5" lift. I should be right around the 2.75-3" mark. Shopping on some of the other drop bracket kits they dont provide the actual spacer length. Anyone have suggestions for the 2.75"-3" lift range, looking like it needs to be right around .75"-1" of drop?
  11. Nov 2, 2021 at 1:49 PM
    #71
    19TurdPro
    2019 Tundra TRD Pro
    There's no easy answer for you. Some people get a lift and don't need a shim at all. I didn't even buy an actual shim, I just stacked heavy duty washers until the shudder went away, then added one more for good measure. I intended to replace it with an actual shim, but never did because the washers worked. If I were you, I'd do the same, measure, then order the appropriate size.
  12. Nov 2, 2021 at 1:51 PM
    #72
    Audiolust
    2010 Tundra Limited
    Perfect, great explanation, thank you.
  13. Dec 21, 2021 at 6:57 AM
    #73
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Just following up on this thread. Did the CB drop resolve the shudder from stop issue completely? My 16 seems to do the same thing. Not really noticeable unless I'm really paying attention. Currently have no drop installed on mine but it is oriented properly and I have a decent ProComp lift. Is installing the spacer kit as easy as taking the bolts out and throwing the spacers in?
  14. Dec 21, 2021 at 7:17 AM
    #74
    Fergie
    Fergie New Member
    Literally as easy as you describe. The slight shudder I had in my 14 w an OME lift went away entirely w a 1/2” spacer.
    I went w a solid spacer from the hardware store rather than washers.
  15. May 7, 2022 at 7:33 PM
    #75
    Mallon3194
    Mallon3194 New Member
    Conor
    Tundra2020
    Jumping in on this late…
    I just fitted Deaver U748 leafs to my tundra, and I have a small shudder from what I think is coming from the drive shaft! I have Fox 2.5s up front and the leaf pack along with a coachbuilder +1 shackle (0.75) of actual lift! The rear is at least 1” 1/2 higher than the front since the leaf install! My drive angle looks steep, has anyone any pictures of theirs, I’ll happily buy a bearing drop kit but I’d rather get the drive in perfect alignment than guess it with a spacer!
