Transmission Fluid change (135,000 mi.); yes or no and if yes how often please.
Discussion in '2nd Gen Tundras (2007-2013)' started by chickamaw, Jul 4, 2020.
  1. Jul 22, 2020 at 12:13 PM
    tundrainsc
    tundrainsc Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    Just returned from Toyota service department. Had the drain and fill Service adviser said not to replace screen because not needed. just as you advised. The invoice shows they put 5 qts back in. Cost $131.25. Also had rear end gear oil replaced with 4 qts 75w140. Cost $192.16. Oil and filter change with conventional 5w30 cost $54.21. Tech advised that middle ujoint shwing signs of wear but no a concern for now. I have had a randomly occurring clunking sound when i come to a stop in the rear i think is coming from the rr brake drum area. This only happens occasionally and the tech could not get the noise to occur during test drive. I was in and out of the shop in 1 1/2 hours. The truck had 161,570 miles on the original atf and gear oil. Atf was a little dark. I had the tech save some of the fluid
  2. Jul 22, 2020 at 1:32 PM
    timsp8
    NY
    $192.16 for rear end gear oil change? Damn. Gear oil is $10-$15 a quart and it takes 15 minutes to do.
    I think the trans service was a good price though. Especially since I’m sure they were charging you labor to stand around and wait on it to be at the correct temp.
    08TXTundra, YardBird and Trooper2 like this.
  3. Jul 22, 2020 at 2:09 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The dealer performed a drain & fill on my transmission yesterday morning... I agreed with their recommendation NOT to drop the pan. Drop the pan only if / when you absolutely have to because you know something is wrong inside.
    My transmission performs smoother than ever, and I will continue with the AT drain & fill every 20K with every 5th oil & filter change.
    camillethetoy and YardBird like this.
  4. Jul 22, 2020 at 2:15 PM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I did a flush at the dealer last year on my 2007 with 90K. I definitely noticed smoother shifting afterward.
    Rex Kramer and YardBird like this.
  5. Jul 30, 2020 at 12:50 PM
    drkbrent
    drkbrent New Member
    I’d be curious to know if anyone here knows of a Tundra transmission failure of an original owner transmission that never had it’s fluid changed. I posted the same question on a Lexus forum about a year ago (regarding the LS460) and no replies.
    camillethetoy likes this.
  6. Jul 30, 2020 at 1:01 PM
    Rex Kramer
    Georgia
    Similar results here after a drain & fill... most notable is how it downshifts when in drive.
  7. Jul 30, 2020 at 1:24 PM
    timsp8
    NY
    Yes. My 2010 failed just under 60k miles. Got a remanufactured one. It was replaced 8 months after I traded it in according to carfax at 105k. But I guess technically the fluid was changed when they replaced the first one.
  8. Jul 30, 2020 at 7:20 PM
    drkbrent
    drkbrent New Member
    You were the original owner?
  9. Jul 31, 2020 at 4:16 AM
    timsp8
    NY
    Yes.
    1rooster likes this.
  10. Jul 31, 2020 at 9:56 AM
    drkbrent
    drkbrent New Member
    Wow, that sucks. I'm literally on a plane flying to pick up my 2010 with 170,000. The tranny is the only thing I'm uncertain about...
  11. Jul 31, 2020 at 9:57 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I wish there was an easy way to check the fluid level in these trucks. I would assume there is enough fluid if there anent any leaks. Where would it go otherwise?
    I have about the same mileage as the OP and I'm sure it's never been changed. I've read too much about problems afterward that I would not consider changing it. It works fine and why mess with it if it isn't broken.
  12. Jul 31, 2020 at 10:28 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    That is the rear drive line compressing on 'hard' stops, you define hard but its not a slow stop when this happens. As you keep the brakes on, the driveline compression remains until brakes are let go to begin accelerating, clunk as driveline expands. Lubing it helps some....sometimes eliminates it altogether, don't overfill - 3 pumps max...
    Asmith2945 and Rex Kramer like this.
  13. Aug 5, 2020 at 5:14 AM
    Toyfosi
    Toyfosi New Member
    Tom
    Calvin, KY
    2010 Tundra
    Trailer brake,
    I just bought a 2010 SR5 with the 5.7 with 77K miles on it and the tranny is the only thing that concerns me. I bought the truck used in Kentucky and it has a gooseneck hitch so I don't know if it had been hauling horses, hay or bulldozers. I am going to go with the drain and fill from what I have read here. Should I have any other concerns? It pulled my 24 foot camper 2 1/2 hours with no problems.
  14. Aug 5, 2020 at 5:25 AM
    timsp8
    NY
    Not if it’s shifting ok. You can’t ever tell. It could go out in 1k miles or 100k miles or never for as long as you have it. Might want to change all fluids.
  15. Aug 6, 2020 at 11:37 AM
    Should the AT fluid be changed out with 89,000 miles? No hard shifting or slipping, just maintenance
  16. Aug 6, 2020 at 11:48 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I think the manual says drain and fill at 90k miles. I think most would just recommend a drain and fill. Drain out the pan 3-4 quarts (it varies) and replace with the exact amount. There is like 14-16 quarts total. The idea is to freshen up the fluid with 20-25% changed.
    This is what I did recently. Re-filling with the exact amount is key. There is no dip stick to check level. Too much or not enough fluid can cause issues.
  17. Aug 6, 2020 at 11:50 AM
    Ok dealer just told me I needed 5 quarts
    Place I'm taking to to change out says I need 8
    I'm also changing out the filter too which I got from dealer
  18. Aug 6, 2020 at 11:52 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Mine seemed to be hard shifting occasionally if it was lugging up an incline at slow speeds(i live on a hilly portion of the city). It would “bang” grabbing a lower gear.
    I did a complete fluid exchange at 160k and it hasnt done it since.
    Not real sure why the drain and fill is pushed so hard when the exchange take 10 more minutes and you get a trans full of fresh stuff.
    :duel:
  19. Aug 6, 2020 at 12:03 PM
    #49
    Trooper2
    JR
    The amount varies; dealer prolly just charging for 5. I would question the other place, maybe just want to charge more.
    The filter is more like a screen. It also means dropping the pan. Many choose not to go this route.
  20. Aug 6, 2020 at 12:06 PM
    #50
    Trooper2
    JR
    I don't believe Toyota recommends a complete change. If a few drain and fills had been done earlier then perhaps the shifting issues may have been avoided.
    :duel:
  21. Aug 6, 2020 at 12:14 PM
    #51
    In your op would the filter need changing at that many miles? 89, bout to hit 90
    Items were paid cash, so we can get money back, gasket, drain plug gasket and filter
  22. Aug 6, 2020 at 12:41 PM
    #52
    Trooper2
    JR
    I don't think its required at 90k. May want to refer to manual.
    I wouldn't think it's necessary.
  23. Aug 6, 2020 at 12:44 PM
    #53
    They want it done
  24. Aug 6, 2020 at 1:52 PM
    #54
    Larly5000
    NV
    07 Crewmax
    K&N’s are better when dirty tooo_O
    Trooper2[QUOTED] likes this.
  25. Aug 6, 2020 at 3:46 PM
    #55
    timsp8
    NY
    Filter is just a screen. There is a thread on here where a guy cut his open at over 100k I think and it was clean. It’s a waste of money and you take a chance on the bolts breaking off when dropping the pan.
  26. Aug 6, 2020 at 3:49 PM
    #56
    I'm not doing
    Transmission shop is
    Filter was bought at dealer
    As well as fluid and gasket n drain bolt gasket
  27. Aug 6, 2020 at 4:31 PM
    #57
    timsp8
    NY
  28. Aug 6, 2020 at 6:28 PM
    #58
    1rooster
    1rooster New Member
    Tony
    2007 crewmax
    As you can tell from my post #30 even at 120k mine looks new. Only reason I was replacing my filter was because I was doing a valve body rebuild so why not!
    But I would recommend at least dropping the pan and cleaning all the sediment out. so it don’t get mixed back in when the new detergents in the new fluid dissolve it.
  29. Aug 6, 2020 at 6:38 PM
    #59
    timsp8
    NY
    I knew I saw that somewhere. Just forgot that it was this thread it was in.
  30. Aug 11, 2020 at 12:45 PM
    #60
    Johnnyquad
    Johnnyquad New Member
    21 Pro double cab MGM
    Tint, clear bra, OEM stereo upgrade, tonneau cover, line x, 285/65/18 Toyo AT3
    I drained and filled my 09 warrior at 64000 miles after I purchased it and it shifts like butter now. I always drain and fill when I buy used. It is cheap and the truck or car always runs better.
    Trooper2 and Rex Kramer like this.
