Transmission Filter or Screen. Drop Pan or No Need?
Discussion in '2nd Gen Tundras (2007-2013)' started by Jarrell, Mar 8, 2020.
  1. Mar 8, 2020 at 8:47 AM
    Jarrell
    Jarrell [OP] New Member
    Jerry
    I own a 08 Tundra 5.7 Dbl Cab that came with a Tow Package and temp gauge..I have no transmission dip stick as I know this is a sealed transmission. I have been told by my dealer that they have to drop the pan and replace my fluid, filter and gasket which costs $647.00 out the door. I was told by another Toyota dealer I have no filter but I do have a screen and no need to drop pan just flush and replace fluid. Firestone said they could tell by my transmission number. How I hate to have my truck on a lift for them to say you have this or you have that. does anyone know?
  2. Mar 8, 2020 at 10:35 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Forget Firestone. Your transmission has a "strainer", but it typically will not need to be changed. Owners here that remove the pan usually find the strainer clean, but maybe some settlement in the pan.
    I'm highly surprised that your dealer even offered to drop the pan. Most dealers will not touch them, because it is likely that one or more pan bolts will be snapped off in the hole during the pan removal. Nature of the beast. In that case, I guess he expects to simply increase proportionately the $647 he already wants to charge.
    Drain and replace is a pretty simple DIY procedure. The only semi-tricky part is setting proper fluid level afterward. Use Search to read owner experiences, and determine if this is something you can or want to do.
    JackBlue, Chadwicktr, WFD473 and 4 others like this.
  3. Mar 8, 2020 at 8:54 PM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    :amen:, What he said.
  4. Mar 9, 2020 at 5:31 AM
    JohnLakeman
    Current Tundra owner literature calls for inspection of transmission every 30K miles for leaks, but does not recommend any ATF change for "normal" operating conditions. Experience with this "lifetime" ATF recommendation varies, but some owners here have reported 200K-400K on their Tundras with no fluid change and no transmission problems. My opinion on this has evolved, and I will probably change my ATF after 100K-120K miles. Change method TBD.
    For "Special Operating Conditions", including towing or "heavy vehicle loading", current owner literature recommends fluid change at 120K miles.
  5. Mar 9, 2020 at 11:43 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I do drain and fills every 45-50k. Get right about 4 qts out every time with the front on ramps. Usually time it to match an oil change.
    Chadwicktr, YardBird and koditten like this.
  6. Mar 9, 2020 at 12:34 PM
    koditten
    Kirk
    Midland of the Mitten
    This. Simple drain and replace exactly what came out. You will need a pump to get the new fluid in.
    YardBird likes this.
  7. Mar 9, 2020 at 12:43 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I was able to snake a 5/8" clear hose from driver's side wheel well to the fill port and gravity fill with a funnel. Have seen where others snake a fill hose up thru engine bay under hood.
    Measured 4.5 quarts drained, put 4.5 quarts back in. I recommend drain / fill with vehicle cold. Measuring warm fluid could be slightly different than ambient.
  8. Mar 9, 2020 at 12:44 PM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    I dropped the pan and replaced the "screen and o-ring" once a year or about every 15k miles in my 08 no issues for 125k. I know it's overkill but I'm neurotic about maintenance and I tow quite a bit. I'll be following the same schedule as before with the new one. I typically do this with all my toys, fresh fluid every year, excluding engine oil.
  9. Mar 9, 2020 at 2:54 PM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    I just did my "08" (126K miles) with a Strainer, o-ring, pan gasket and both drain and check crush washers (all OEM). The two front corner bolts snapped right off and I had to drill and tap the excess bolt out of both holes, very time consuming. All four magnets were extremely clean and since I can not see inside the strainer, changing it was a no-brainer for me. I can not tell if the fluid had been changed prior to me owning the truck (but it did appear over full), it did need changing. It was not burnt, but was pretty dark. I plan on doing a drain and fill in two to three months since I do not drive it a lot. After that I will probably do another drain and fill at 150k. I put silicone on top of the two new bolts were they protrude.
    If I towed a lot I would do a drain and fill every 30k miles. Remember, the transmission temperature must be between 115F and 130F to get an accurate amount dribbling (small stream) out of the "Check" plug.
  10. Mar 11, 2020 at 3:17 PM
    Failure2comply
    VA
    Be sure to read this Toyota paper before performing a drain/flush and fill. If you have the tow package on your truck you "MUST" follow the steps to open the Cooler Thermostat to get an accurate level when you reach check able temperatures.
  11. May 10, 2021 at 6:26 AM
    Zap.Workshop
    Zap.Workshop New Member
    2008 Tundra SR5
    Hi can you tell me where you found that PDF, and if it does not have tow package, can I ignore the termostat step?
  12. May 16, 2021 at 5:58 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    If no tow package, there is no thermostat to pin open. So yes, the step can be skipped.
  13. May 21, 2021 at 9:15 AM
    Zap.Workshop
    2008 Tundra SR5
    Thanks!
