Transmission cooler or not Thread
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mad Max, Oct 12, 2020.
  1. Oct 23, 2020 at 2:59 PM
    #211
    Well there you have it. That is one tough pull with any weight, let alone 8k lbs in a 1/2 ton. I would like to see them pull it when ambient is 70+*F or more. Right now on Vail Pass the ambient temperatures have been rather cool. Vail, CO this past couple weeks was ~52*F and the summit of Vail Pass was ~38*F(and some dipping into freezing). On my many trips over this pass, I have seen 70+*F at 10000 ft elevation.
    What did people think of the review (except you @Mad Max..:D)? Tundra did pretty damn good and was complimented a lot in the review except for transmission temps.
    I was a little shocked/disappointed that little 5.3L beat the Tundra up the pass in every category.
    2022 Tundra...I have big expectations out of you and better not disappoint.
    hagrid and Cpl_Punishment like this.
  2. Oct 23, 2020 at 2:59 PM
    #212
    WesternFlyer
    WesternFlyer New Member
    2019 4x4 CrewMax, SR5, TSS
    Made it 1/2 way through and now it says video unavailable? No warning lights on Tundra though. 246 degrees at the top.
    ColoradoTJ likes this.
  3. Oct 23, 2020 at 3:02 PM
    #213
    Probably doing additional editing. I’ll have to watch it again to see.
  4. Oct 23, 2020 at 3:12 PM
    #214
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    You can hear it haunting for gears , looks like he was towing on D , wonder if he kept it on s4 or maybe s3 if it was gonna make a difference
  5. Oct 23, 2020 at 3:17 PM
    #215
    That was shifting from 4-3, and I’ve done it both ways. No difference other than shifting yourself.
    Jtundra81[QUOTED] likes this.
  6. Oct 23, 2020 at 3:20 PM
    #216
    Jtundra81
    Joe
    It is a little disappointing for sure to see these high temps , however , I would imagine keeping it at s3 and at 45mph , It wouldn't heat up as much. Wish they showed how long it took to cool down after they reached the top
  7. Oct 23, 2020 at 3:26 PM
    #217
    Jtundra81
    Joe
    Also it would be good if they test the f150 since no external cooler starting 2018 model
    Cpl_Punishment and ColoradoTJ like this.
  8. Oct 23, 2020 at 3:28 PM
    #218
    Probably 5-10min at standstill and less if moving.
  9. Oct 23, 2020 at 3:30 PM
    #219
    Just waiting on @14burrito and his results with the external transmission cooler.
  10. Oct 23, 2020 at 3:32 PM
    #220
    Jtundra81
    Joe
    Does putting it in P or N makes any difference to cool it down when you're still ? Or doesn't matter as long as you remove it from D or S mode ?
  11. Oct 23, 2020 at 3:37 PM
    #221
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
  12. Oct 23, 2020 at 3:47 PM
    #222
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    H
    Yeah, I got the 2019 pid's, don't have what you listed, my list is much smaller.
  13. Oct 23, 2020 at 3:51 PM
    #223
    Doxiedad
    James
    Charleston, SC
    Did you connect it to truck and let it search for PID? When making a new gauge you select PID then select Toyota,Lexus, Scion then select engine and electronic controlled transmission
    Bammer[QUOTED] likes this.
  14. Oct 23, 2020 at 3:54 PM
    #224
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I'm supposed to do something when an external cooler???
  15. Oct 23, 2020 at 3:56 PM
    #225
    Fearthisbeard
    Fearthisbeard New Member
    Gilbert AZ
    2019 - 1794 TRD Offroad
    Looks like they took the video down for some reason
    Doxiedad[QUOTED] likes this.
  16. Oct 23, 2020 at 4:04 PM
    #226
    Bammer
    Monroe, CT
    I did that I believe, but will again tomorrow. Thank you
  17. Oct 23, 2020 at 4:21 PM
    #227
    It depends on how the valve body is set up, but neutral is normally the better selection.
  18. Oct 23, 2020 at 4:23 PM
    #228
    No, just wanted to see your differences compared to other members 2019 or newer.
  19. Oct 23, 2020 at 4:27 PM
    #229
    14burrito
    2014 SR5 CM 4x4 5.7
    Ahh
    So the tech wasnt able to pull the degradation value this morning, so trying to figure out someway to grab it.
    Sample should be getting sent out sometime next week, just waiting for my prepaid shipping label from Blackstone.
  20. Oct 23, 2020 at 4:29 PM
    #230
    Thanks for doing that. Be interested seeing your results on a truck that is used off-road that is set up really nice (read heavier, but still awesome).
  21. Oct 23, 2020 at 4:42 PM
    #231
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    OK, I haven't done any farkles to my truck in 2 years, and this APP you are all referencing has my attention. I'm assuming that this is an OBD Dongle and APP? Help a luddite out! ;-)
  22. Oct 23, 2020 at 4:44 PM
    #232
    Jtundra81
    Joe
    Obd reader and obd fusion app and purchase the extra Toyota pids for your truck and customize what you want to monitor , you will be surprised with the tons of sensors you can customize, totally worth the 10$
  23. Oct 23, 2020 at 4:56 PM
    #233
    Bulldog9
    NOVA
    Recommended OBD bluetooth device?
  24. Oct 23, 2020 at 5:20 PM
    #234
    Doxiedad
    James
    Charleston, SC
    I’m able to read it using OBD fusion and a Bluetooth adapter. Have to have the advanced diagnostic pack for your year though
  25. Oct 23, 2020 at 5:21 PM
    #235
    Doxiedad
    James
    Charleston, SC
  26. Oct 23, 2020 at 5:25 PM
    #236
    Jtundra81
    Joe
  27. Oct 23, 2020 at 7:31 PM
    #237
    Mad Max
    Mad Max [OP] New Member
    Max
    2021 Tundra Limited
    So how did the 5.3 beat it? Better time, Fuel mileage? Looks like from video post (I didn't see video) temps 246F at top at 45f ambient, torque converter must been 270F? I would never pull more than 8,000lb with any 1/2 ton. I usually go to Florida last week of June, Houston to Destin, temps are 95F, probably 100F heat coming off highway lol. Truth be told I stopped looking at this thread after I installed cooler, mine pegs at 188F around town and 194F Highway (80mph). I Pulled by 5,500lb boat yesterday as test but it was only 74F and trans temps with cooler were still 194F what a bore, need a 90F day to really test. Obviously that is flat ground at 74mph. I kept in drive but S5 would been right gear. I was just messing around for only about 15 miles, I forgot to use tow haul mode, although that is twitchy to me. I had zero issues pulling boat, no sway, good acceleration, no braking issues. Cant wait to see video. I saw another on Youtube where Toyota gave a farmer a Tundra for two years. He beat hell out of and put 100K miles, overloaded constantly. Toyota took apart, most components should zero wear. I saw that I knew I had right truck.
    Bammer and Saltyhero13 like this.
  28. Oct 23, 2020 at 9:57 PM
    #238
    14burrito
    2014 SR5 CM 4x4 5.7
    Thanks, but I'm already spending time and money on something that doesn't affect me - not really interested in spending more lol - curiosity has the best of me
    I'll reach out to some locals, see if anyone has Fusion and go from there. Thanks for the insight.
  29. Oct 25, 2020 at 10:34 AM
    #239
    Jwjeffy905
    Jwjeffy905 New Member
    Where's the TFL video, why did they pull it down so suddenly? Something is up.
  30. Oct 25, 2020 at 11:01 AM
    #240
    Mad Max
    Max
    2021 Tundra Limited
    i scared
    hagrid likes this.
