Transmission cooler or not Thread
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mad Max, Oct 12, 2020.
  1. Oct 7, 2021 at 6:26 PM
    #751
    pursuit2550
    pursuit2550 New Member
    I agree but it’s not that easy. If the dealer tells you no warranty, what would be your next move? Just because Toyota decided to remove it, which I don’t agree with, doesn’t mean they can’t void your trans warranty if it fails. We all know manufacturers are always looking for an escape to deny warranty work. If I still had my boat I would put one. For me since it’s just daily driving I don’t worry about it.
  2. Oct 7, 2021 at 6:27 PM
    #752
    pursuit2550
    Lol, topical response. If your exhausted after some internet discussion then you have other issues, bud.
    Tundraman479 likes this.
  3. Oct 7, 2021 at 6:30 PM
    #753
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Aside from what I stated above, there is another thing to keep in mind with dealerships. They make more money charging the customer than they do the manufacturers. When you sense that they are denying the warranty fraudulently, find another dealership or talk to the general manager.
    Years ago I was asked to leave a review for a Ford service center. I left a poor review since they tried to rip me off. A week later I received a call from the manager asking why. I explained the entire situation. He even verified what I told him by looking in the service manual. His response was that he would take care of it. I never went back there again.
  4. Oct 7, 2021 at 6:33 PM
    #754
    Chip_Tundra
    Chip_Tundra New Member
    Sure thing, speed racer.
  5. Oct 7, 2021 at 6:42 PM
    #755
    pursuit2550
    LOL, Ok service department worker guy.
  6. Oct 7, 2021 at 6:53 PM
    #756
    pursuit2550
    Dealerships are scammers for the most part. The oil issue I had was I bought the car used. 1 year old Acura TSX with 5500 miles. The dealer I bought it from did a service to it. They over filled it by one quart. It developed a leak in the rear main seal. I can’t remember if this was an issue with the TSX but none the less I took it to another dealer for warranty, it was way closer, about 30 miles closer. They looked at it and saw the oil was high. They proceeded to tell me if I get an oil change with them that they would warranty it, if not no warranty. To it back to the dealer I bought it from and they fixed it. Contrary to what the dealer said, 1 quart doesn’t cause that. I use to run 1 extra quart on my Tarilblazer SS because it was a know issue that on a hard launch the oil went to the back of the pan, pick tube is in the front, and starve the rear bearings. I actually run 5w-30 on my tundra because 0w-20 makes the whole valve train sound like Diesel engine. Can they void my warranty, yes, but the 5.7 hasn’t changed and 5w-30 was the oil the used before. All I was saying was that the Magnson Act isn’t so clear cut. If I towed a lot I would definitely put one. I don’t tow anymore so it’s not a concern to me. I will just change my trans oil and filter sooner and more often. As for your Tow Package, as far as I know, no truck from 19 on has a cooler, period. And as far as I know from all the tundras I have owned, 4 now, they all had a Tow Package and a cooler, 08, 10, 15 and 20(no cooler)
  7. Oct 7, 2021 at 9:45 PM
    #757
    DoublePro
    DoublePro New Member
    Currently my 2008 with 198k miles, I’m thinking about buying the same cooler OEM parts and put it on my 21. Do you guys think it would bolt right up ?
  8. Oct 8, 2021 at 2:57 AM
    #758
    pursuit2550
    If I am not mistaken someone did a post on this. They bought all the OEM parts from a 14+ and added it to their truck that didn’t have any cooler.
  9. Oct 8, 2021 at 3:22 AM
    #759
    timsp8
    NY
    No. It’s the same thermostat and maybe the lines, but that cooler won’t fit. They changed the style where the grill doesn’t raise with the hood so it won’t fit.
    DoublePro[QUOTED] and SSPey like this.
  10. Oct 8, 2021 at 3:25 AM
    #760
    timsp8
    NY
    This kit uses most of the oem parts, just a different cooler. The cooler was integrated with the ac condenser. That part is almost $1000 and people speculated the cooler was removed because of a freon change so ac condenser needed to be bigger.
    https://www.tundras.com/threads/tundra-transmission-cooler-kit.60550/
    DoublePro likes this.
  11. Oct 8, 2021 at 3:41 AM
    #761
    pursuit2550
    Yeah I have seen that one. I have seen some threads similar to that one. I guess I must be mixing them up with the previous gen that had an actual cooler.
  12. Oct 8, 2021 at 3:56 AM
    #762
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I would put on my wizard robe and hat, climb upon the service counter and with a mighty roar declare, "I summon all my mana and cast Magnussen-Moss: LEVEL VII!!"
    Then they hafta do whatevs you want. You've got em cornered.
  13. Oct 8, 2021 at 4:16 AM
    #763
    pursuit2550
    A little magic never hurt anyone. :D
    hagrid[QUOTED] likes this.
  14. Oct 8, 2021 at 4:55 AM
    #764
    ezdog
    ezdog New Member
    Gateway To The West
    At long last the Voice of Reason!
  15. Oct 8, 2021 at 5:51 AM
    #765
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I learned that from a tv show called The Offive. The protagonist, Michael Gary Scott, had his bank account sucked dry by his wife Jan Levinson-Gould. He saw on the interwebs you could declare bankruptcy and everything would be peachy keen.
    So he stood in the middle of the offive and yelled, "I DECLARE BANKRUPTCY!!"
    Then everything was moar betterer.
  16. Aug 15, 2022 at 4:23 PM
    #766
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    hows that supercharger holding up? I want one. really really bad. Im just a scaredy cat about reliability.
  17. Aug 15, 2022 at 5:18 PM
    #767
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Some guys have lots of miles on their SC’d Tundras… @snivilous is over 270k I believe. Not sure who else…
    snivilous and FrenchToasty like this.
  18. Aug 15, 2022 at 6:07 PM
    #768
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    Excuse me what?! 270k that’s fk awesome.
    snivilous likes this.
  19. Aug 15, 2022 at 9:28 PM
    #769
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    276k right now, but to be fair it only got the blower on at 214k :D there's people that have had more miles being supercharged, though mine might be one of the older ones in terms of total miles on the truck plus having a blower.
    I have had zero reliability issues from the supercharger.
  20. Aug 16, 2022 at 4:35 AM
    #770
    timsp8
    NY
    I put one on my 2010 at around 10k miles and traded it in at about 95k. I drove it hard and the only SC related issue was the coupler kept rattling. I replaced it with the supposed upgraded one, but that one rattled too. And my transmission went out at 59k.
  21. Aug 16, 2022 at 4:40 AM
    #771
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    What happened with the transmission going out at 59k??:confused:
  22. Aug 16, 2022 at 4:52 AM
    #772
    timsp8
    NY
    The CEL was for solonoid d. Toyota just replaced it under warranty and didn’t say why it went out. They did say there were metal shavings in the fluid. I don’t blame the SC. Maybe the way I drove it. I could tell it was going out - hesitating to shift, holding gears - but it still pulled a 3k lb uhaul from MO to TX and didn’t leave me stranded before I got it replaced.
    FISHN43[QUOTED] likes this.
  23. Aug 16, 2022 at 5:15 AM
    #773
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'll jump in on this one...The S/C is transparent when you drive normal. like it isn't there. it's only giving boost when you want it to. heavy pedal.
    now, when you do stomp it...just make sure you have a VERY reliable tune. I verified my AFR's during the tuning phase. all is well.
    more intouch folks will tell you to put in an AFR gauge. I watch mine via the scangauge 3. and am in the process of putting in a innovate AFR/Boost gauge
    just keep it under ~600hp @ crank.
    My installer has an older Tundra (09?) with ~300k miles. nearly all with the Magnuson.
    Life is short. get a S/C.
  24. Aug 16, 2022 at 10:44 AM
    #774
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    My guess is when you add a sc you like to hit the gas pretty hard and that extra toque on the tranny doesnt play well maybe?
  25. Aug 16, 2022 at 11:11 AM
    #775
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    They only had three transmission coolers instead of the recommended six.
    Arranged radially.
    On a mast.
  26. Aug 16, 2022 at 11:20 AM
    #776
    Joe333x
    Joe333x Member
    Boston
    Even if you don't tow the fluid temps can get really high compared to the trucks built with a cooler. The OEM thermostat opens around 180° for trucks with a cooler. Before I added a cooler to my 2019 it would be normal to see temps if 220+ with just normal driving. Now i stay around 185°. Its no secret that the higher the fluid temps the faster it degrades.
    Terndrerrr, Mike59 and ColoradoTJ like this.
  27. Aug 16, 2022 at 3:26 PM
    #777
    We have had members that have had the high transmission temp warning come on in 4H.
    If you monitor your temps and don’t see the need for it, I wouldn’t spend the money either. Hard to say, but I work my trucks so it isn’t even an option not to have one.
  28. Aug 16, 2022 at 3:44 PM
    #778
    I would have a hard time with lemon law and a warning light. It didn’t break…
    Now if the transmission failed, different story.
    The members that where getting high temps in 4H were off-road and going up steep grades. Regardless, I agree with you that is ridiculous even if you are at payload capacity.
    Sierradevil likes this.
  29. Aug 16, 2022 at 3:45 PM
    #779
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I was on the fence about the cooler, even when towing, until I took a trip, unloaded (not towing) across the state and hit 230 in D on a 75 degree day at about 75 mph. Made me concerned that I could never drag my trailer over to that part of the state, which I would like to do, without hitting something even higher.
    Maybe those temps (230...240...250) won't be detrimental to the transmission. I honestly don't know. But I am just a lot more comfortable now with the cooler and no longer very concerned.
    FISHN43 and ColoradoTJ like this.
  30. Aug 16, 2022 at 3:54 PM
    #780
    I have been getting a little nervous at 190* on my Allison. I need to do some more research on what it can take for heat or start saving up for a built transmission.
    I shouldn’t complain though…that is two 5 yard scoops.
