Transfer case fluid after 59k w/pics
Discussion in 'General Tundra Discussion' started by Sumo91, Feb 11, 2022.
  1. May 8, 2022 at 7:59 PM
    AZBoatHauler
    So.Arizona
    Mine looks good at 71k. :notsure:
    texasrho83 likes this.
  2. May 8, 2022 at 8:21 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
  3. May 8, 2022 at 9:04 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Ravenol has lots of calcium, which washes internals of the t-case. Could it be that Ravenol just picked up all the dirt left by past lubricants? What UOA did show? Any significant metal wear?
    Example. I've been using Red Line oil in turbo engines for years. It is very rich in calcium. It also turns dark pretty quickly, but manages to keep mechanical wear at minimal levels. I took the engine apart due to blown exhaust valve, it had 1/3 of wear of similar engine (same model) with similar miles that I took apart some time ago. So Red Line did quite well protecting the internals, but it was always dark in like 2k miles. Factory-filled and dealer replaced Castrol wasn't turning dark till 5k miles, but it was responsible for all the gunk and varnish in the engine when I bought that car.
  4. May 8, 2022 at 9:13 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Could be the cleaning action. I just don't see how the transfer case could get dirty, it's a sealed system. But oil can get dark as it degrades and falls out of spec, my diff fluid was changed out at the same time and looked great (Schaeffers) and I know it has more calcium and cleaning agents than the Ravenol. The oil I just put in it has tons of esters and alkylated naphthalene, so it going to clean like crazy if there is any varnish or build up.
    I'll try to send the UOA off in the next week or two, along with the rear diff fluid. It'll be a fun comparison
    Terndrerrr likes this.
  5. May 9, 2022 at 4:19 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Exactly.
    This is from my car after ~200k miles, serviced regularly.
    Direct comparison is a bit unfair: in this application the transfer case sits below exhaust manifold and turbo. But anyways, gunking still happens in transfer cases.
    What I saw, Red Line (esters) didn't do much to hard varnish in my engine. Nothing did, I've tried a few engine cleaners as well. I was cleaning oil sump with dimethyl sulfoxide, washed it thoroughly with kerosene before installing it back, but it still had traces of DMSO. The next time I was there in a few thousand miles, varnish softened and begun to come off.
    Sumo91[QUOTED][OP] likes this.
  6. May 9, 2022 at 6:04 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    I have the 75w-85 https://www.redlineoil.com/75w85-gl-5-gear-oil however I haven't made the time to get everything change yet.
    I have a bunch of Red Line products ready to be used, 75-85 for the transfer case, the 75w-90 for the diffs and some ATF D6 for the transmission. Right now I have about 42k in the truck with factory fluids, I'll do a post when I finally get it changed.
  7. May 9, 2022 at 6:19 AM
    Sumo91
    TN
  8. May 9, 2022 at 6:46 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Ya see...
    If the forum were to band together, for the low price of a nickle per month, we could get pictures, oil analysis, and maybe even new product reviews regarding drivetrain fluids and how they hold up.
  9. May 9, 2022 at 7:13 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It is clean... Well, where it is better be clean. I was lazy and didn't take out and boil the cylinder block and lower tower, only rehoned cylinder sleeves in place. The rest was thoroughly cleaned.
    Also a few months before the engine died I had to address leaking RMS that gave up after using SeaFoam and BG109. Pain.
  10. May 9, 2022 at 7:24 AM
    Sumo91
    TN
    Looked like a fun project!
    vtl[QUOTED] likes this.
  11. May 9, 2022 at 8:36 AM
    Blue Thunder
    Washington
    Following and waiting for the UOA. I’m not convinced oil color is the best way to tell the condition of the oil or how well it performed.
    Having staff that, I’m glad I paid the nuts for the Toyota oil. I’m about to do mine and almost went for the Ravenol…
  12. May 10, 2022 at 7:42 AM
    Wallygator
    Bammer and Terndrerrr like this.
  13. May 11, 2022 at 6:43 AM
    Sumo91
    TN
    Samples for the transfer case and rear diff have been mailed off this morning with priority mail. Should be seeing results by the end of next week depending on the lab.
    @14burrito
  14. May 11, 2022 at 7:07 AM
    Blue Thunder
    Washington
    Thanks for doing that and footing the bill!
  15. May 11, 2022 at 7:42 AM
    Sumo91
    TN
    I'm curious too! Maybe next time I'll start a go fund me :rofl:
    Blue Thunder[QUOTED] likes this.
  16. May 11, 2022 at 7:45 AM
    Sumo91
    TN
    That's why you have oil analysis, to see how your oil is wearing and if you need to change it or not :thumbsup:
    And if you wanna come drop my skids to change my transfer case oil, feel free. It's a bitch and half to drop my homemade skid. I made it a little too theft proof.
    Blue Thunder likes this.
  17. May 11, 2022 at 8:37 AM
    AZBoatHauler
    So.Arizona
    I’ve used the “oil is cheap” line a ton but in this case - it’s not. My t-case oil continues to look good at 71k miles. I’ll change it later this year and run it another 5 years or 75k miles. If the 2.5 gens used regular gear oil I would change it more often but since we use unicorn tears I’ll monitor and stretch it.
  18. May 11, 2022 at 8:49 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Mine looked like lightly colored honey at 30k. I am definitely in the severe use category, but that oil looked perfect. Kinda wish I had drained it into its own oil catch pan so I could’ve put it back in :rofl:
    I wonder if Ravenol makes a conventional 75W as well. Mine is definitely fully synthetic, and there are lots of Toyota drivers who pack on the miles with Ravenol (thinking of this forum and T4R.org) and have no issues. Almost all of the Amazon reviews are 5 stars from Toyota drivers specifically buying it instead of OEM 75W.
  19. May 11, 2022 at 12:51 PM
    #49
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Just sent off an ATF myself from our mom-mobile
    Wallygator likes this.
  20. May 20, 2022 at 2:21 PM
    #50
    Sumo91
    TN
    "Insert crow eating gif here because I don't know how to do it"
    Well, I was wrong. Fluid is just fine. Here's the report.
    How the hell do you post a gif from mobile? This post woulda been way better with a gif
    MedCityMoto, Wallygator, vtl and 5 others like this.
  21. May 20, 2022 at 4:58 PM
    #51
    Blue Thunder
    Washington
    Nah, no crow eating. Just nice to have facts and data. Given what you posted from BITOG it looks like the Ravenol held up great. Especially for being basically the break-in oil.
    If you are just looking at the additive packs, Toyota is obviously better. But for your use the Ravenol is fine.
    Thanks again for posting!
  22. May 20, 2022 at 5:10 PM
    #52
    Sumo91
    TN
    Well I did talk some major shit about Ravenol when I started this thread :bananadead:
    But thank you for the feedback. I also have my UOA for the rear end. Blackstone said the wear metals were high. But they're actually not when you compare it to the averages. And the TAN is exactly same as the VOA sample :eek:
  23. May 20, 2022 at 8:04 PM
    #53
    Blue Thunder
    Washington
    Did you post it? I’m about to change mine out and would love to have a reference point
  24. May 20, 2022 at 8:16 PM
    #54
    Sumo91
    TN
    I'll post it up tomorrow
  25. May 23, 2022 at 4:12 AM
    #55
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    So, it is Ravenol's cleaning action. All that dirt is in fact sediments from Toyota's lubricant. Very interesting! Thanks for doing that!
    Ravenol kit now seems to be an even better alternative to OE fluids.
  26. May 23, 2022 at 6:56 AM
    #56
    Blue Thunder
    Washington
    What dirt? Other than price what makes Ravenol better?
    Sumo91[OP] likes this.
  27. May 23, 2022 at 7:08 AM
    #57
    Sumo91
    TN
    It had bulk fill 75w90 in it when I got the truck. It was still clear and had maybe a few thousand miles on it when I drained it.
  28. May 23, 2022 at 7:35 AM
    #58
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Metal wear and oil oxidation form a relatively thick layer of sludge on the inner surfaces of the diff/t-case.
    Better as is in "price is better, yet UOA looks very good".
  29. Dec 20, 2022 at 7:52 AM
    #59
    Dirtytruck
    Dirtytruck Overkill it
    2021 SR5
  30. Dec 22, 2022 at 1:46 PM
    #60
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    In reading on this debate, it also looks like Redline MT-LV is an option. What say the collective?
    Plug gaskets: anyone have a preferred place to buy? Looks like for the TC and differentials I need
    1215710010
    9043024003
    90430-A0003
