Traction control issues
Discussion in 'Suspension' started by Joeshaker, Mar 10, 2017.
  1. Mar 11, 2017 at 4:07 PM
    Joeshaker
    Joeshaker [OP] New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I was wondering if I should get the zpc done again. I'll ask Lotsoftoys about that to.
  2. Mar 11, 2017 at 4:10 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Gino, what made you think trying a zpc again and again would fix it?
    Edit. Meaning was there something that told you it wasn't done right the first two times?
  3. Mar 11, 2017 at 4:10 PM
    I think we covered this before, but wheel width? Stock UCA's?
  4. Mar 11, 2017 at 4:22 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Factory +60 offset, factory ucas. Tires are 33.98 x 11.5 so only 2" taller and.5" wider than stock. About .25" closer to the ucas, close to.75" clearance. Guy from hypertech thinks alignment causes it. Alignment seems fine, Jace got it within spec. Everything points to the computer sensing that the wheel speed difference is outside the parameters. Wouldn't that be about the same as long as all four tires are the same size?
  5. Mar 11, 2017 at 4:24 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I'll check out bullydog.
    GNTundra likes this.
  6. Mar 11, 2017 at 4:26 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Did the dealership charge you for each zpc or did they redo it since they didn't get it right?
  7. Mar 11, 2017 at 4:32 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I've been contemplating trying wheel spacers. Slim chance that widening the stance would reduce body roll and inside rear lifting up? Maybe at that certain angle I am rubbing the ucas just enough to set off the trac, but not enough to make noise or marks with nannies off?:annoyed:
  8. Mar 11, 2017 at 4:37 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Haven't asked my local guy Dave if he can do the zpc. He has Techstream, so Probably, right? Nothing against Jace, but taking it to Dave is a lot easier and hell, he lives right up the road from me.
  9. Mar 11, 2017 at 4:39 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Ok, I'm going to check out the bullydog now. But wait, didn't you just say that the first time you did it you made it worse?
  10. Mar 11, 2017 at 4:47 PM
    Replace stock UCA's and wheels. I bet if you had a +18/+20 and after market UCA's this wouldn't be occurring
  11. Mar 11, 2017 at 5:03 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Sean, you think the ucas are the problem because they're at the limit of alignability? Even though Jace got it within spec and I'm only at 2.5inch. I've got 1.5 in the back. So, I'm not that far off from factory rake. Caster is the relationship between the upper and lower ball joints frt to back. From what I understand that is where the need to get ucas comes into play. Seems like with my lift and only a one inch difference in rake I'd be fine. I'm afraid that pushing the wheels out will cause other issues, like the need for a cmc. More strain on the wheel bearings. I like the look with the wheels out a little more. But then you have the rocks flying up. Then I'd have to think about flares to. That's leading down the rabbit hole!!
  12. Mar 11, 2017 at 5:06 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bully dog does have a feature to just turn off the trac. Guess I could live without it, none of my other vehicles have ever had it. But there's another $400, wife will kill me.
  13. Mar 11, 2017 at 5:06 PM
    I think your tire is hitting the UCA's causing the lights, imo.
  14. Mar 11, 2017 at 5:10 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    That's what I keep thinking, just no visible sign of rubbing and everyone that has looked at it doesn't think it's hitting there. Anybody here in Denver that has a go pro I can stick in the wheel well to get some video of what is going on under there?
  15. Mar 11, 2017 at 5:12 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Guess I might try spacers. Bora makes 1", that'll be like a +35 offset. Shouldn't throw to many rocks or increase the scrub radius to much. I can always sell them.
  16. Mar 11, 2017 at 7:01 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yeah, I'm probably going to take it back in and have Jace look at it again. We already talked about it a while ago. Impossible for him to diagnose without having his hands on it. I just can't afford the dealership prices right now. My busy season will be happening soon. Then I can actually do something about it.
  17. Mar 11, 2017 at 9:45 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    What about doing the sequoia front sway bar swap to reduce body roll. It only does it when the nose dives at a certain angle. If it doesn't work it'll still make the truck Take corners better.
  18. Mar 11, 2017 at 9:47 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Oh yeah, not supposed to be buying anything else for the truck. Dang, convince her that it's a must have item!
  19. Mar 11, 2017 at 10:49 PM
    #49
    Jace does side work
  20. Mar 12, 2017 at 7:17 AM
    #50
    beech monkey
    beech monkey New Member
    Brentwood TN
    2016 TRD Pro FFV and 2001 Tundra on 35s with too much custom to name here
    readylift 4in with 35 inch Toyos on LRG 20s, retrax cargo cover, front and rear fab four bumpers, audio amp and sub, viper alarm, stock under hood for now
    nannies off means you just pushed the switch on the dash turning off trac control?
  21. Mar 12, 2017 at 8:37 AM
    #51
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Good to know Sean, I'll check with him and try to set up a time for him to check out what's up with my truck.
    T-Rex266[QUOTED] likes this.
  22. Mar 12, 2017 at 11:07 AM
    #52
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  23. Mar 14, 2017 at 8:10 PM
    #53
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Well, after playing with tire and airbag pressure to adjust the rake. As well as rebalancing the tires. I put the stock wheels and tires back on. The good news is the tpms light stayed off and it's not just my expensive new tires. Unless they jacked something up. That's the bad news, still freakin doing it.
  24. Mar 14, 2017 at 8:50 PM
    #54
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Waiting to hear back from him now.
  25. Mar 14, 2017 at 8:52 PM
    #55
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    One of the things I've just asked Jace about.
  26. Mar 15, 2017 at 8:00 PM
    #56
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    So, I just goofed up. Made a new thread over in wheels and tires. Ridge grappler. Check it out and let me know your thoughts. Going to 275/70/18
  27. Mar 15, 2017 at 8:18 PM
    #57
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Well, after putting the stock P275/70/18 back on the trac seems to be working as it should. So far anyway, will drive it again tomorrow. Then put the Nittos back on and try the one thing that I hadn't yet. Which is putting them at 50 psi. The guy at discount thinks maybe they've got to much traction. Next logical step looks like going a little smaller and different compound.
  28. Jan 27, 2019 at 7:30 PM
    #58
    slylaws
    slylaws New Member
    Pacific Northwest
    2018 Tundra SR 4x4
    Wonder what ever happened?
  29. Apr 20, 2020 at 12:56 PM
    #59
    Prezidentredz
    Prezidentredz New Member
    Ryan
    15 TRD Pro - Inferno
    I'm having this issue now with a 15 pro crew cab just installed a 275 70r18 and haven't tried any on or off ramps but when I accelerate the slip light flashes and I loose power. This is driving me crazy.
    Zpre2116 likes this.
  30. Apr 18, 2021 at 8:32 PM
    #60
    Zpre2116
    Zpre2116 New Member
    Zack
    2010 Tundra
    5100s all the way around
    Prezidentredz did you ever fix your issue I am having the same atm.
