Traction and ABS light lit up
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ely010606, Oct 7, 2021.
  1. Oct 10, 2021 at 3:59 PM
    #61
    Ely010606
    Ely010606 [OP] New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Thanks for the ideas, im not technically savvy on putting a harness together. I will stick with the Oem if it doesn’t give me anymore problem. Most of my mod are plug and play, except for the shock etch. I basically can manage with wrench and sockets.
    2mchfun likes this.
  2. Oct 11, 2021 at 5:03 PM
    #62
    TTund16
    TTund16 New Member
    so the footwell lights dont impact the warning lights as far as you know. Is that correct?
    I Also have vled footwell lights. I see the warning lights I posted about once in a while and wanted to make sure the footwell lights are not the cause.
    Ely010606[QUOTED][OP] likes this.
  3. Oct 11, 2021 at 5:27 PM
    #63
    Ely010606
    SPARKS, NV
    Yes, that i know, I still have it on my truck. All I did was swap the led from my brake light to the oem. And its been 3 days and the traction and abs light hasn’t popped up.
    TTund16[QUOTED] likes this.
  4. Oct 11, 2021 at 6:00 PM
    #64
    2mchfun
    Footwell lights would not be on the brake system circuits. They would also not require any computer for their function. Pretty much, battery, fuse block, switch, bulb, ground. Hope that helps.
    TTund16 and Ely010606[OP] like this.
