Trac Control off + Tow Haul = BEAST MODE -> Confirmed
Discussion in '2nd Gen Tundras (2007-2013)' started by Nor7, Oct 28, 2016.
  1. Jul 18, 2020 at 8:11 AM
    #271
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Use caution on tight onramps and highway merges. Took the outside lane on a highway merge and pretty sure I was at the limit right before losing it- adrenaline rush but felt very risky.
    BGoodiE likes this.
  2. Jul 31, 2020 at 12:11 PM
    #272
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Has anyone relocated the Tow/Haul or Traction Control buttons so they're next to each other? I tried searching and couldn't find anything.
  3. Jul 31, 2020 at 7:19 PM
    #273
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'd initially think that it would simply be a matter of peeling back the loom on the wiring harness to see if enough slack could be freed up. The next option that comes to mind if that didn't work, would to be to lengthen the harness to move the T/C button over to where the T/H button is located, assuming that'd be where you'd want the T/C to be. I know that for me, the T/C button can't be seen without craning my neck. Then there'd be the essentially non-issue of trimming the button of the little tabs so it fits the opening.
  4. Aug 17, 2020 at 10:42 PM
    #274
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    don't remember if i posted in this already. i'll have to try it out , but i dont see how tow haul mode would help if your trying to go raw. speaking of 2nd gen 5.7L - since it seems tow haul puts some sort of VSC and ABS on to help stabilize a trailer.
    if while stopped you hold the trac button till trac , auto lsd and VSC is off (its around 10 seconds of holding) that should be the rawest form use manaul shift for more fun.
    ps if your getting good mpg and not 4mpg your using it wrong:rofl:
  5. Aug 18, 2020 at 9:40 PM
    #275
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Tow/Haul switch changes the shift pattern to a more aggressive shift pattern. More sensitive to throttle position and drops down in gear a lot sooner. That is why it is a great function for towing. I have tried both on and off during a tow and it makes a big difference just for towing. So if it works so good for towing when turn all the other crap off it turns into a power house. So if you like your tires you won't have them for long if you stay in that mode. :burnrubber:
    Cpl_Punishment likes this.
  6. Aug 18, 2020 at 9:52 PM
    #276
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    TRDblvd likes this.
  7. Sep 2, 2020 at 12:04 AM
    #277
    prsrcokr
    prsrcokr New Member
    06 DC, 18 CM
    The buttons are next to each other on my truck. I guess Toyota changed the button layout at some point?
  8. Sep 4, 2020 at 8:54 AM
    #278
    calisparky
    calisparky New Member
    chris
    2011 tundra crew cab
    Hey now... .be careful there princess about that "dodge smacking" talk. I do enjoy the 11 Tundra and will be giving this whole "beast mode" thing a damn joy ride the next time the wife lets me drive her truck but the difference I've noticed with the tow mode on her toy and on my Ram is the tow mode assists in the down shifting and using the exhaust braking as well.
    I haven't a clue about any that use gasoline but to say bad things about my precious little 3500 crew/long/Cummins is hurting her feelings until I put another 35,000 pound trailer behind her and pass another someone in another branded truck going up grade.
    Now... to talk about breaking down, I've got to shop around for the damn oil filter housing on this damn great running and fun as hell to drive tundra.
    Happy day to all!
  9. Sep 4, 2020 at 10:13 AM
    #279
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I stuck to my original statement, princess. Look like butt and fall apart fast.
    Have a great day!
  10. Sep 4, 2020 at 11:37 AM
    #280
    prsrcokr
    prsrcokr New Member
    06 DC, 18 CM
    Was that trailer loaded with 35,000 lb of Rams you had to tow that were on the losing end of the quality control checks?
    :spending:
    I know the split feeling, didn’t like my wife going from Toyota to a Ford but it’s grown on me. Other than the little details like suspension pieces needing replacement at 62k miles.
  11. Sep 5, 2020 at 2:25 PM
    #281
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I have experimented with this for the past 3 years and I've decided that the best setting for me while driving around town is to turn the LSD off, and shift into S-4. The truck is quick off the line & powerful from 1st to 4th, and I can manually shift into 5th to cruise a length of open road... and manually shifting back into 4th at a stop. I don't use the Tow Haul feature because I am not towing anything.
  12. Sep 8, 2020 at 8:56 AM
    #282
    calisparky
    chris
    Alrighty then....
    Firstly, yeah.. I do miss my Duramax but the Cummins was the only option I could purchase in a jam and stuck on the road with a 40ft toy hauler to move in the middle of no where.
    Now lets talk about this "beast mode".
    The wife's truck is the 2011 5.7 tundra. I tried what is spoken of here. First counted the 0-60 time with the truck in "D" and no other change.
    Conclusion after the "one-onethousand,two one thousand" kind of counting was just about 10 seconds.
    Tried the 'beast mode' of traction control off and haul mode on. The count was identical.
    What am I missing?
    Traction control "off" says LSD on the dash. I don't know if I need to be on LSD to experience the change or what????
  13. Sep 8, 2020 at 9:01 AM
    #283
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If you just tap the traction control button, it turns the LSD on. You have to hold it for 3 seconds to turn traction control off then another 3 seconds to turn VSC off. (On a 2014+, anyway. Not sure about a 2011.)
    Tow/haul mode makes the accelerator more responsive but you won't notice a difference at WOT.
  14. Dec 20, 2020 at 8:45 PM
    #284
    Merkopac661
    Merkopac661 New Member
    White 2018 Tundra Sport 4x4
    Damn Im so glad I searched tow\haul mode and came across this thread. I had never heard of this. This is exactly what my truck was missing. Since my lift and 35's I was looking for more pull. Just did the test 100ft burnout and smoked up the area just stomping on it from dead stop. I want 5.29s and my bam 10' is on the way. Will using beast mode with 529s be reving to hard or will it be ok to go beast mode? any input from guys with lifts,35s,529s driving frequently in beast mode.
    Trooper2 likes this.
  15. Mar 24, 2021 at 5:47 AM
    #285
    BGoodiE
    BGoodiE New Member
    Ben
    19 TRD SR5 OR
    NONE! Lasted about a month, Firestone bags, Decked system, ARE CX HD, WeatherTech mats/rainguards, TRD RSB...
    You guys are a**holes! I stumbled upon this thread in some rabbit hole and HOLY HANNAH! Jeckyl and Hyde! This truck has split personalities and I love it. People wondering if it's good for the engine and what not, can't speak on that, but it's certainly not good for the brakes. If I wasn't on the floor with the fun pedal I was standing on the brakes. I would consider this the cheap mans Supercharger. It even sounded bada$$! Wow. And yeah I also experience the involuntary school girl giggling as I blasted out of the parking lot. Better have 2 hands on the wheel! This is no joke.
    And another positive about this mod, it's FREE and doesn't require me to hand someone my credit card which has been happening a lot! She can't get mad about a free fun button! Let er rip boys!
    MTRock and Trooper2 like this.
  16. Mar 24, 2021 at 5:24 PM
    #286
    FWD Tundra
    Washington
    Research can be contagious. We try to keep this stuff TOP SECRET. :smokertransformer:
    BGoodiE likes this.
  17. Feb 5, 2024 at 6:10 PM
    #287
    JsjTundra2
    JsjTundra2 Long Time Toyota
    Maine
    The most important question i have, is where can I get a button that replaces "Tow/Haul' with "Beast Mode?"
  18. Feb 5, 2024 at 7:57 PM
    #288
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
  19. Feb 6, 2024 at 4:51 AM
    #289
    JsjTundra2
    Maine
  20. Feb 7, 2024 at 5:06 AM
    #290
    Canman
    Canman New Member
    2007 Crewmax Limited
    I tried this last night (I think). Still somewhat confused as to the steps, but this is what I did:
    1. Get truck back into 2WD vs 4x4, as when in 4x4, the “VSC OFF” dash light is already on.
    2. Press the VSC and hold until both the VSC symbol on the dash and the “VSC OFF” dash light are both on.
    3. Press and release the “Tow Haul” button and the “Tow Haul” dash light comes on.
    4. That was it for me, and it made a huge difference in terms of acceleration. I would say the truck is just as fast or faster accelerating from a rolling speed of 20 kph to 120 kph as my 05 Subaru Legacy GT wagon with the 5-sp manual. Lol!
    5. I forgot to engage the “RSCA OFF”button during my test runs, so not sure if that also needs to be engaged.
  21. Feb 7, 2024 at 5:19 AM
    #291
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's unrelated to what you were trying to do.
    bulldog93 likes this.
  22. Feb 7, 2024 at 6:06 AM
    #292
    Canman
    Canman New Member
    Ok. Good to know. When I pressed the “VSC OFF” button, I now got the “AUTO LSD” dash light on, but no “VSC OFF” dash light. What is the significance of this AUTO LSD light?
  23. Feb 7, 2024 at 6:18 AM
    #293
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    you need to do a press, then two seperate ~3 second holds
  24. Feb 10, 2024 at 7:37 PM
    #294
    Canman
    Canman New Member
    I figured out that you cannot get the “VSC OFF” dash light to come on if your’re moving. Vehicle has to be at a stop or in park.
    For me, I just press and hold the “VSC” button for about 5 seconds until both the VSC symbol and “VSC OFF” dash lights come on sequentially in that order. No need to press and release the VSC button. To activate “Tow Haul” dash light is simply a matter of pressing the “Tow Haul” button. Going to try it out on my daughter’s Tundra tomorrow afternoon.
  25. Feb 28, 2024 at 4:39 PM
    #295
    IIonPilgrimg
    IIonPilgrimg New Member
    2008 Tundra Limited Double Cab 4x4 5.7 6-speed Red Rock
    Read to this Post #146.
    I've only had my 2008 for a couple of wintery months. In that time, I've installed a Kenwood aftermarket head-deck with the Maestro RR2 harness.
    So... the head-deck does have a 0-60 Gauge in the top/left corner and I've confirmed in bumper/bumper traffic it seems to work and counts up to about 30 seconds before ceasing the clock.
    Haven't truly got round to testing the thing in any mode. Will do so in all of them... if/when it ever quits raining here in W-Valley Oregon. Some light snow predicted this week: Might venture out if fun opportunity arises.
  26. Feb 29, 2024 at 3:59 AM
    #296
    Canman
    Canman New Member
    We tried the beast mode on my daughter’s 2011 5.7, and the set up is different then on my 07, and like what folks have been saying with holding for 3 secs on/off. Weird…
  27. Feb 29, 2024 at 6:44 AM
    #297
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There was a change in the early years of the 2nd generation. I dug this up and it indicates that there was a change from 2007 to 2008.
    Canman[QUOTED] likes this.
