TPMS Sensors
Discussion in 'Wheels & Tires' started by Bluedevils4life, Jun 1, 2020.
  1. Jan 30, 2023 at 3:36 PM
    #91
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    It was $160 after tax and shipping for all 4. But I also got them in Black Valve Stems, that added $10 to each TPMS
    Bergy24[QUOTED] likes this.
  2. Mar 4, 2023 at 8:41 PM
    #92
    Kev90
    Kev90 New Member
    2019 Tundra SR5 CM
    Hey guys I have a 2019 sr5 oem steel wheel with key to start and I’m going to be putting on alloy wheels. I think I should be buying the 42607-0C091 set for my alloy wheels. Is that correct??
  3. Mar 17, 2023 at 8:15 AM
    #93
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Quick question for the group…I put the black OR wheels from my totaled 17 on my new to me 19. Took it to Discount Tire to see if they could do the TPMS sensor reprogram. I was told that because the sensors are off a 17 and are now on a 19 that it wouldn’t work. Does that sound right? So I asked my buddy at the shop down the street from me and he said it shouldn’t be a problem so he’s gonna try it for me. If that doesn’t work, can I just swap sensors from the Sport wheels that came with the truck onto the wheels that I put on?
  4. Mar 17, 2023 at 8:20 AM
    #94
    I know the 2020 is different due to a different mhz and additional number in the sensor ID. The 17's may work in the '19. If not, the sensors that came with the truck should work since they are going from alloy wheel to alloy wheel.
    nhw544[QUOTED] likes this.
  5. Mar 17, 2023 at 8:41 AM
    #95
    nhw544
    nhw544 Food fight!
    RVA
    Ok thanks! Dumb question, but does it matter that the sport wheels are 20” and the OR wheels are 18”?
  6. Mar 17, 2023 at 8:46 AM
    #96
    Not that I am aware of.
  7. Sep 9, 2024 at 6:36 PM
    #97
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    My apologies for bringing this back. But i need some advice. i am looking to purchase a 2021 platinum with push to start, but it came with aftermarket wheels. The tpms light is, of course, flashing. This tells me the aftermarket wheels does not have tpms sensors installed..
    When i put the vin into toyota part catalogue, it gave me this part number:
    42607-0C101
    How can i find out what sensors is correct for my truck?
    Can the new sensors be use on aftermarket wheels or oem 20” alloy only?
    Thank you
  8. Sep 10, 2024 at 1:16 AM
    #98
    When it comes to sensors, there are 2 types...one for steel wheels, and one for alloy. The difference is the angle of the sensor. As long as you have the sensor that fits an alloy wheel, it can be used in any OEM or aftermarket alloy wheel. You will need OEM sensors from Toyota. The 2020 and newer does not like aftermarket sensors. The parts department can verify that part number by the VIN.
    BrandonL812[QUOTED] likes this.
  9. Sep 25, 2024 at 5:39 AM
    #99
    BrandonL812
    Brandon
    I finally called 4 dealership. 1 said they dont give out part number, which is BS. 1 gave me 42607-02053. The last 2 gave me, 42607-02050.
    so i believe the correct part number for my 2021 platinum is 42607-02050.
  10. Sep 28, 2024 at 3:21 PM
    #100
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    My TPMS light has been on for a while but I knew the pressure in my tires was good. I rotated the tires the other day and the light went away. No idea how/why that happened but I ain't mad at it. :1up:
    BrandonL812 likes this.
  11. Sep 28, 2024 at 3:43 PM
    #101
    H20ne
    H20ne New Member
    California
    2021 Limited Nightshade CM 4x4
    aFe, TRD, Eibach, RCI
    For what it's worth, I just installed Denso sensors (purchased from Rock Auto) in my new FN Fx Pros. When I put the Fx Pros on the truck, I followed the instructions to reinitialize the TPMS and the truck automatically detected the Denso sensors after about 20 min of continuous driving. 2021 Limited CM.
  12. Sep 28, 2024 at 3:46 PM
    #102
    BrandonL812
    Brandon
    I went ahead and purchased 4 with black valve stem from tpms.com after getting the oem part number. Then finds out the wheels i ordered is on Backorder. 1-3months nationwide. Yay me. Im hoping the one from tpms.com wont give me issue later when i finally get my wheels in.
    H20ne likes this.
  13. Sep 30, 2024 at 3:23 AM
    #103
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Keep us posted to how these work and if the light comes back on. This may be a great option. Thanks for the info!
  14. Oct 7, 2024 at 12:52 PM
    #104
    Qbert
    Qbert New Member
    WOW, I am so confused after reading all of this. I have a 2020 (PushButton) limited with alloy wheels. I recently purchased some Methods MR315's and need to purchase some new TPMS sensors. After reading through the posts I thought I needed part #42607-06030 but now I am not sure. Was trying to go aftermarket as Toyota has them listed on their site for $104 (https://autoparts.toyota.com/products/product/valve-sub-assy-tire-4260706030#popup-1), not sure if this is for 1 or all 4. Any help would be appreciated. Thanks
  15. Oct 7, 2024 at 1:08 PM
    #105
    BrandonL812
    Brandon
    You should do what i did and call a bunch of dealership around and get the actual part number off of your vin. Then you can order them from online or through the local dealership. That’s a safe bet to know they are correct part for your truck. Dont guess. Call and confirm for sure.
  16. Oct 7, 2024 at 3:08 PM
    #106
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    It is EXTREMELY confusing. I do not want to vouch for the correct part numbers because you never know. They vary by model, electric start, wheels and most likely color! The suggestion of @BrandonL812 to check a few dealers is a good idea.
    I have a 2020 Platinum (push button) and purchased the wrong sensors (42607-0c091). The correct ones for my truck (I am told) are 42607-06030 that are $71.75 each. https://autoparts.lewistoyota.com/search?search_query=4260706030 Wait for a Toyota parts sale and get 15-25% off.
    I do not think that the aftermarket sensors play well with the system. GOOD LUCK
  17. Oct 7, 2024 at 10:08 PM
    #107
    H20ne
    H20ne New Member
    California
    It's been several hundred miles so far and no issues with the Denso 5500118 sensors. The pressures read accurately and are displaying on the MFD just fine.
  18. Oct 7, 2024 at 10:09 PM
    #108
    French Avocado
    Utah / Wyo
    Congrats!! That is good to hear.
  19. Nov 11, 2024 at 11:04 AM
    #109
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Yall are some minty fellas after 3 sets of TPMS sensors off Amazon and ordering an Autel reader I got it to work….. I think.
  20. Dec 12, 2024 at 5:34 AM
    #110
    BrandonL812
    Brandon
    Just to update this. I went with the sensors from Tpms.com for my 2021 PTS. Shop installed and did the relearn with their scanner and the tpms light is now off. Gauge showing psi again on all 4.
    part number i used: oem - 42607-02050
    Tpms sensor: UVST6T17R-TOYOTA
    Toyota Huf IntelliSens TPMS Sensor 42607-02050 42607-12010 315MHz
    [Valve Stem Option (SCH):Black Metal Valv
    Just be aware, they have terrible after sale customer support. I had one DOA sensor. After email with 2 respond they ghosted me. I called 3 days later and was told they will send a new replacement. A week go by and nothing. I send 2 more emails and still no respond. I ended up buying another sensor from them and it was shipped out a day later.
    So basically they dont give any support if you received a dead sensor. BUT, you can buy another and it will get shipped out right away.
  21. Dec 12, 2024 at 6:14 AM
    #111
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I recently put new aftermarket allow wheels on my 2010. I talked to local OK Tire guy here in BC. The TPMS sensor light
    has been flashing for a while. I found a set on Amazon.ca that stated they worked for 2007-2013 Tundra, about $47 or something.
    Took them to Tim @ Ok, he took out his Autel, scanned them and said they'd be fine. After they were installed
    it took about 3-4 minutes for the reader to identify and code them in to the truck. I drove away with the TPMS light
    flashing, by the time I pulled onto the highway the light was out. Haven't seen it since.
    His other advice is that once a light starts to flash, generally the battery has died. Don't waste around just order
    a new set and have them installed. I don't have sensor installed in the spare. I just inspected it before next weeks road trip,
    stock valve stem.
  22. Dec 12, 2024 at 6:17 AM
    #112
    BrandonL812
    Brandon
    The 2020 and 2021 are picky on sensors. I was glad the ones i got was fine. Hopefully it will be trouble free from here on out. Will report back if any issue arrives.
  23. Dec 12, 2024 at 9:31 AM
    #113
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I've been having issues with my 2018 platinum. It does not even show anything on the display in middle of the gauge cluster. I have tried the re-learn/initialize process but still does not work. I even removed the LED bulbs I had in the dome light bc I read that they could interfere with it. I am at a lost and just gave up. Do you guys have a part# that work for the 2018 model?
  24. Dec 12, 2024 at 9:39 AM
    #114
    Are they the original sensors? We're they replaced with aftermarket?
  25. Dec 12, 2024 at 10:23 AM
    #115
    jalam321
    jalam321 New Member
    I am not sure, I bought the truck used with aftermarket wheels on it. I think I remember seeing it display in the cluster when I first got it but now there is nothing. I plan to get new wheels soon so I'll probably have to get new sensors also.
  26. Dec 12, 2024 at 10:27 AM
    #116
    BrandonL812
    Brandon
    Go to your local tires shop and have them scan each wheel. See if anything shows up. Then you’ll know if there are anything in there.
