TPMS Sensor Re calibrating?
Discussion in 'Wheels & Tires' started by paradizecityz, Mar 17, 2019.
  1. Mar 16, 2023 at 7:16 PM
    #61
    Goofinator
    Goofinator New Member
    Bernard
    okay will try but what about that it blinks now? Even when I put the key in “on” it will blink several times then stay solid and the TPMS screen will say calibrating please wait
  2. Mar 16, 2023 at 10:01 PM
    #62
    Goofinator
    Bernard
    I tried it. I put the truck to on waited for the light to stop blinking and stay on. Pushed the button 3x it flashed and stayed on, turned off the truck and started the engine and it flashed until it stayed on waited and drove and nothing. Gonna disconnect the battery lol
  3. Mar 21, 2023 at 12:00 PM
    #63
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I still need to do this. The aftermarket TPMS are calibrated to my factory vin verified TPMS part number, but the mobile tire installer couldn't do his magic with the TPMS calibrating since my engine was apart and battery out at the time. Just been driving around with that light on
  4. Mar 21, 2023 at 12:43 PM
    #64
    Goofinator
    Bernard
    Well for me I went to another discount told me it was fine, went to the dealer my dude told me take it back to sams discount and make them make it right that they either hit a sensor, damaged it or didn’t “marry it” to my truck. Went back to the same discount they looked at the one they did rebuild but it was OEM so no issues turned out to be the front passenger sensor they replaced it with another and if it didn’t work they would order a OEM one but luckily as soon as they put in the other sensor in the front passenger boom fixed! So I am all good
  5. Mar 21, 2023 at 12:52 PM
    #65
    itsZEUStime
    itsZEUStime New Member
    Paul
    2019 White Tundra SR5 Crewmax
    RCI Sliders RCI Skids Prinsu Rack AJT Chrome Delete Pop & Lock Power Tailgate Lock Super Pacific Camper Incoming
    Separate, but related question, has anyone rotated their spare in with the other tires? I do not believe the spare includes a TPMS and I was wondering how you guys might have worked around that, if at all?
  6. Oct 24, 2023 at 4:39 PM
    #66
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I'm having an issue where the sensors are reading backwards. I keep my front tires at 45 PSI and the rear at 50 psi. I have a new Alpine radio that can see the tire pressures, and it shows it backwards. I took it in to discount tire and they tried to reset with their calibration machine with no luck. I tried the reset button under the dash with no luck as well. Has anybody run into this?
  7. Oct 24, 2023 at 4:51 PM
    #67
    On my 2020, mine were reading in opposite corners diagonally after a tire rotation on my head unit, the dash, and my SG. I reset it with no luck. I ended up using my TS508 to correct it.
  8. Oct 24, 2023 at 4:54 PM
    #68
    coTony
    Tony
    Montrose, CO
    If it came from the dealer like that then the dealer added it, that is not stock
  9. Oct 24, 2023 at 8:56 PM
    #69
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    That looks similar to the tool they tried using. I'm gonna drive it around for a while and see if it relearns. If not, guess it's off to discount again...
  10. Dec 12, 2023 at 9:52 PM
    #70
    seanyy11
    seanyy11 2018 SR5 4x4 Inferno
    After multiple tries, this worked for me. Thank You!
    Tundra234[QUOTED] likes this.
  11. Dec 25, 2023 at 11:00 AM
    #71
    Burdturger
    Burdturger New Member
    Just want to share my experience with aftermarket TPMS having this issue. To start, I do have a TPMS programmer with aftermarket TPMS. I was having the same issue where I programmed the TPMS and the re-calibration in progress seemed to be stuck with the flashing orange TPMS light. I drove over 100 miles and the re-calibration status never went away nor did the warning light. So today I tried a different approach. Instead of programming the TPMS with the old sensor codes, I programed the TPMS with new codes then proceeded with the relearn process. After driving for about 30 seconds the light went away and they seem to be functioning. So for anyone in this situation that has or doesn't have the tool, it seems to me when using aftermarket TPMS you should be programing them with new codes and not pulling the old codes out of the ECU. Just my .02.
