TPMS Sensor Re calibrating?
Discussion in 'Wheels & Tires' started by paradizecityz, Mar 17, 2019.
  1. Mar 17, 2019 at 11:23 AM
    paradizecityz
    paradizecityz [OP] New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Any ideas before I bring back to tire shop?
    Had wheels and tires installed about 1.5 weeks ago. They moved the TPMS sensors over and everything was working. Took a small trip on Wednesday and saw error saying something that sensor malfunction, take to dealership. Tried to do the reset and now it’s on this screen. Drove for 30+ mins and it’s still there...
  2. Mar 17, 2019 at 11:31 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Head back to the tire shop, get some gas on the way...;)
  3. Mar 17, 2019 at 11:49 AM
    TundraDrew
    TundraDrew New Member
    Drew
    Hahira, GA
    2020 White Tundra 1794 4x4
    Bakflip Revolver X4, Nitto Ridge Grappler 275-60R20
    I had the same issue and had to take it to the dealership to get it fixed.
    paradizecityz[OP] likes this.
  4. Mar 17, 2019 at 12:04 PM
    paradizecityz
    Richmond, TX
    Haha, yup...bout that time!
    Dang, hoping to avoid the dealership. Hope they won't charge and hope the tire shop can take care of it
  5. Mar 17, 2019 at 12:09 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’d try the tire shop first, since they just worked on it. If a sensor is broken, then it would have been their doing.
    If a sensor has just failed, then you might have to visit the dealer and try to get it replaced under warranty.
  6. Mar 17, 2019 at 12:35 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Seems if a sensor failed, then it would just not read the one that’s bad. The system doesn’t seem to be reading any of them. Have you tried unplugging the battery and letting the ecu reset? Then try and calibrate again?
  7. Mar 17, 2019 at 1:31 PM
    paradizecityz
    Richmond, TX
    That I have not tried. So when I turn if off and turn it onto the ON, it blinks for a minute, then the light would go solid
  8. Mar 17, 2019 at 1:44 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m having another thought here. Did the tire shop actually move the sensors to your new wheels like they were supposed to?
    Or did you bring the original wheels with the sensors still installed home in the back of the truck and park near them up until you took your trip?
  9. Mar 17, 2019 at 1:46 PM
    paradizecityz
    Richmond, TX
    I'm pretty sure they took if off. The OEM tires and wheels were undone and everything. And I've been driving to work and TPMS was working fine the whole time up until Wednesday
  10. Mar 17, 2019 at 1:51 PM
    Danman34
    Danman34 New Member
    Danny
    Yea. I’m wondering if they actually put them in there. Lol.
    Well nvm. They were working....hmmm.
  11. Mar 17, 2019 at 3:16 PM
    BWinter
    BWinter New Member
    Central California
    2018 White 1794, TRD Off Road, 4x4
  12. Mar 17, 2019 at 4:13 PM
    paradizecityz
    Richmond, TX
  13. Mar 18, 2019 at 7:29 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    TPMS Relearn Button on 2018 Toyota Tundra and Sequoia 1. Ensure all tires are inflated to the pressure listed on the tire placard. 2. Start the engine and keep the vehicle in PARK. 3. Press the Tire Pressure Reset button three times. 4. Drive the vehicle for 10-30 minutes at 25mph or faster and the light will turn off once the sensors are registered. Refrain from reversing and driving in heavy traffic during the relearn process. 5. The Tire Pressure Reset button must now be pushed and held down until the TPMS light blinks three times to set the baseline tire pressures. 6. Drive the vehicle for 10-30 minutes, staying above 25mph when possible, and the light will turn off once the current tire pressure values are accepted.
    You might try this??
    ACEMAN4 likes this.
  14. Mar 18, 2019 at 7:37 AM
    paradizecityz
    Richmond, TX
    Yes I’ve.
    Stopped by discount as that’s what was ok my way and they said one of the sensor is dead and they don’t sell any for this truck
  15. May 20, 2019 at 6:01 AM
    tundra403
    tundra403 New Member
    KG
    2018 Tundra SR5 4x4 TSS Off Road - MGM
    -Internal LED Lights -Added VLED's Footwell light strip
    Just got my truck back from the shop.. I had a dual blowout (small single car collision) had to have two rims and wheels replaced. They put in new sensors..
    Ive got the same thing happening to mine right now.
    Now the shop that did it is telling me i have to take to Toyota for them to clear and recalibrate.... I tried the long steps from above, possibly i didnt ride around long enough. was the dealership able to fix it? @paradizecityz
  16. May 20, 2019 at 6:09 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    How much pressure are you running in your tires??
  17. May 20, 2019 at 6:17 AM
    tundra403
    KG
    when i checked they were right.. 42 is what they were when i bought them and thats what toyota has been keeping them at.
  18. May 20, 2019 at 6:22 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    When I put new wheels, tires and TPMS sensors on my truck. It took a couple of days with me messing with the reset button to get it straight. If the shop where you had them installed used air instead of Nitrogen in your wheels, this time of year you're going to get a pretty good swing in pressure. That may be part of your problem.
  19. May 20, 2019 at 6:37 AM
    tundra403
    KG
    been driving it a few days already. Start off by trying to reset the button, wait for it to flash then drive for quite sometime.
  20. May 20, 2019 at 6:47 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    When you start off can you see your pressures on the display?
  21. May 20, 2019 at 6:49 AM
    tundra403
    KG
    neagtive.. just says Tire Pressure Recalibrating.... ^^^^^ same thing as the OP post image
  22. May 20, 2019 at 7:36 AM
    paradizecityz
    Richmond, TX
    I had to buy 4 new sensor in my case. But that’s because I tried using steel wheel sensors but needed the alloy sensors.
    2 different part numbers. Haven’t had issue since I changed them...*knock on wood*
    Medic343 likes this.
  23. May 20, 2019 at 8:03 AM
    tundra403
    KG
    hopefully if anything needs to be replaced.. the insurance/bodyshop will make it right.. the old sensors got destroyed.. so either the new sensors are fucked or not the right ones for the wheels i have. we will see.
  24. May 20, 2019 at 10:04 AM
    paradizecityz
    Richmond, TX
    Did they use OEM or aftermarket?
  25. May 20, 2019 at 10:38 AM
    tundra403
    KG
    i assuemd OEM.. they said they went off what the VIN said to use. that said, it could be bad or incorrect.. or maybe they got a sensor that was meant for a different wheel. Not sure. I dropped it off at Toyota for lunch and they are going to send the other shop the bill since its still an open claim.
    Did say that more than likely it was a bad sensor... i just find it weird, that if one is bad NONE of them register.. Id assume it would just be the one bad one would go out. easier troubleshooting.
  26. May 20, 2019 at 10:46 AM
    paradizecityz
    Richmond, TX
    Did your car come with steel wheels or alloys?
  27. May 20, 2019 at 10:55 AM
    tundra403
    KG
    This what it came stock with.
  28. May 20, 2019 at 10:56 AM
    paradizecityz
    Richmond, TX
    Ah ok, should have the right TPMS sensors then
  29. May 21, 2019 at 5:57 AM
    tundra403
    KG
    when the shop put the new rims on, they didnt put the correct sensors in.. "said" i had to go to Toyota to calibrate it.. toyota discovered its the wrong sensors. Getting two new ones put in at the tireshops expense.
    831Tun and bhuff92 like this.
  30. May 21, 2019 at 6:25 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    marked for video try
