TPMS Bypass - shut off - disable
Discussion in '1st Gen Tundras (2000-2006)' started by 737fixer, Sep 2, 2019.
  1. Jan 28, 2024 at 12:27 PM
    Valkron8
    Valkron8 New Member
    No its actually not, only pictures of which wiring you have to take. But not wich side have to be grounded.
  2. Jan 28, 2024 at 12:29 PM
    Valkron8
    Valkron8 New Member
    Ah oke, so you can let the wire still get Connected. Thanks alot:)
  3. Jan 28, 2024 at 3:11 PM
    Just don't use scotchloks as pictured, they're bastard shits of the devil, pure hackery. Do it the rightway, use a Posi-tap instead, or solder + heat shrink. Scotchloks are notorious for mangling wires, allowing oxygen to corrode copper, breaking strands of copper weakening the signals across wires, and generally causing irreparable damage, unless you ultimately cut and re-solder to restore the wire's integrity. I can't tell you how many issues I've traced back to those pieces of shit.
    Just look at the thickness of that split in the connector, and think about the awg of the wire. Do the math on what's going to happen when you shove a stranded wire into a slot half the thickness. Bad shit.
    G_unit3000 and Cruiserpilot like this.
  4. Jan 28, 2024 at 3:15 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I said it was sketch. Don’t judge me.
    shifty` likes this.
  5. Jan 28, 2024 at 3:15 PM
    Not judging, just trying to save n00ber from some future headaches :D
  6. Jan 28, 2024 at 3:21 PM
    18" TRD Off Road Wheels
    I love how every time those pop up we can see your blood boil. The passion is real and the desire to save others the headache is admirable. Though I half think about recommending them at times just to see the reaction. :drevil:
    Cruiserpilot likes this.
  7. Jan 28, 2024 at 4:31 PM
    I'm just out to be an asshole. :rofl:
    GODZILLA[QUOTED] likes this.
  8. Jun 16, 2024 at 12:34 PM
    Bxavier
    Bxavier New Member
    Just did the modification and it worked. I had to pull the dash apart...pull out the radio to unhook the connector. Soldered a wire onto the pink...silver wire and grounded it on the frame ground right behind the glovebox.....thanks for the help...
  9. Jul 29, 2024 at 3:52 PM
    dokaman
    dokaman New Member
    06 Sequoia SR5
    Quick question about this mod. Seems straight forward, but do you "need" to plug the TPMS module back in or can you remove it completely. This is assuming you have already grounded the pink wire.
    Thanks!
  10. Jan 11, 2025 at 8:20 PM
    This entire thread is specifically pertaining to the 1st gen, and it was posted here in the 1st gen subforum, though Search may not have informed you which subforum you were in. Always important to check that when clicking thru.
    I highly recommend you check in over at the 2nd (2.5) gen forums HERE to ask if it works the same with the later years. I wouldn't expect the 2017 to act like the 2000-2006 years.
  11. Sep 7, 2025 at 6:09 PM
    TWC
    TWC New Member
    2005 Tundra Regular Cab V-8 2WD
    I completed this task today on my 2005 regular cab, thanks to the information found here. Thank you.
    To make the modification 100 percent reversible, I actually removed the SOLID PINK conductor from the connector, the added a length of wire to it by reducing the number of strands until it just slid into the factory terminal, then slid a piece of heat shrink over the joint to hold them together. I did not crimp, or solder the joint. A ring terminal on the other end of the wire extension was placed under a nearby mounting screw head.
    If anybody makes the mistake, as I did, of removing the PINK w/ SILVER dots & BLACK stripe, and grounding it, you will get a flashing CRUISE indicator on the gauge cluster.
    abcinv likes this.
