TPMS Bypass - shut off - disable
Discussion in '1st Gen Tundras (2000-2006)' started by 737fixer, Sep 2, 2019.
  1. Sep 2, 2019 at 9:59 AM
    737fixer
    737fixer [OP] New Member
    I've been searching for how to disable, shut-off the TPMS light on my 2005 Tundra Doublecab. Seems even when searching in the 1st gen section I'm only getting 07 and 08 Tundra's. Does anyone have the old instructions on this project. Many thanks as usual.
    Desrat and because_wumbo-truck like this.
  2. Sep 2, 2019 at 10:05 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Does yours have the TPMS button underneath the driver side dash, above the accelerator? If so, start the truck and hold it down for 6 seconds, then let the truck run for 3 minutes or so. This will initialize and should turn the light off. Not sure what to do if you don't have the button.
    because_wumbo-truck likes this.
  3. Sep 2, 2019 at 10:25 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    That will only work if the system is functioning 100%. If one or more of the sensors are bad then the light will come right back on.
    Due to the age of the vehicle I would bet one or more of the sensors in the tires are bad hence, the light stays on.
  4. Sep 2, 2019 at 11:01 AM
    Kerch71
    Mechanicsville VA
    Good point
  5. Sep 2, 2019 at 12:23 PM
    mscribellito
    mscribellito New Member
    Michael
    2006 White Regular Cab Tundra
    Here ya go...
    I attached a pic of how I did mine. Just have to ground out a wire from the module behind the radio. I removed the dash panel around radio and radio itself to access it more easily. 67809943_130745488149979_5461667926274352974_n.jpg
  6. Sep 2, 2019 at 12:30 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i cleared the TPMS codes with my scan tool and the light never came back on.. and im missing all the sensors
  7. Sep 20, 2019 at 2:25 PM
    Daq_daddy
    Daq_daddy New Member
    2005 SR5 Doublecab
    What scan tool you using?
  8. Sep 20, 2019 at 9:10 PM
    3.4Tundra
    3.4Tundra New Member
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    Just did this mod. I couldn't get my fat hand in far enough to unclip the plug from the glove box area so I pulled the radio bezel off, 5 Phillips screws (1 behind each AC knob, and 1 at top of each vent).
    Once that is off, there is one nut holding the tpms module bracket on(silver), once unscrewed, piece of cake!! It's a 10mm nut and you will need an extension to reach it.
    Like others, the wire on mine was solid pink.
    Thanks for the tips everyone!
    mcharfauros likes this.
  9. Sep 20, 2019 at 9:42 PM
    TheBeast The Beach
    i think I saw that button on my 2012, does it work on gen 2s ?
  10. Sep 20, 2019 at 9:53 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    It should as long as your tire pressure is correct and the system is working fine (sensors all responding etc..).
    TheBeast[QUOTED] and Kerch71 like this.
  11. Sep 21, 2019 at 4:45 AM
    Kerch71
    Mechanicsville VA
    Agreed
    TheBeast likes this.
  12. Sep 21, 2019 at 10:15 AM
    empty_lord
    05 rollover special
    Snap on modis
    TomGreen and Tundra2 like this.
  13. Sep 21, 2019 at 11:50 AM
    TheBeast The Beach
    yes it does but thinking of switching wheels set and not getting tpms in my "off road "set
  14. Sep 21, 2019 at 3:14 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    If you switch to wheels without sensors then your sensor light will always be on.
  15. May 27, 2020 at 5:40 AM
    Fishin
    Fishin New Member
    Anyone have the procedure for a 15 Tundra?
  16. May 27, 2020 at 11:55 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  17. Aug 30, 2020 at 10:16 AM
    LASurf
    LASurf New Member
    Los Angeles
    300k+mi 06 AC4x4
    Just did this the grounding way. If anyone has questions, shoot.
  18. May 16, 2021 at 2:11 PM
    redfishnc
    redfishnc New Member
    Will
    wanted
    4WD
    I cut the solid pink wire going to the TPMS and grounded the wire on the wiring side, not from the TPMS module side. Is this correct?
  19. May 17, 2021 at 10:06 AM
    LASurf
    LASurf New Member
    Los Angeles
    300k+mi 06 AC4x4
    Cut the pink and silver before the connector. See photo...
    Someone else asked about this and I sent the below links via PM.
    Pictures: Thread I used: Getting your hands in there gets real tight, good luck!
    bmf4069, tdrich7 and BubbaW like this.
  20. Nov 26, 2022 at 12:07 PM
    KnotOnCall
    KnotOnCall New Member
    Is this behind the radio or under the steering wheel?
  21. Nov 26, 2022 at 12:46 PM
    shifty` We call it “riding the gravy train”
    This is what I did also. More info here: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1557#post-3103575
    Neither. It's behind the glove box. Notice the ECU in the background behind the box with the words DO NOT CUT, with all the connectors going into it.
    CodyP likes this.
  22. Dec 19, 2022 at 9:57 AM
    wegner44
    wegner44 New Member
    2005 Gold Tundra DoubleCab SR5
    I was able to accomplish this mod, no more flashing TPMS light!!!
    For those needing to do this, here are some pictures to help point you to the module and wire needed to jump to ground.
    G_unit3000 and abcinv like this.
  23. Dec 19, 2022 at 1:19 PM
    growit
    growit New Member
    2006 Dbcb SR5
    Is that white wire with the black stipe a ground wire?
  24. Dec 19, 2022 at 1:21 PM
    wegner44
    wegner44 New Member
    I am not sure, I didn’t put a meter to it. The pink wire with silver is the one you want. Run that to chassis ground.
  25. Dec 19, 2022 at 1:26 PM
    growit
    growit New Member
    2006 Dbcb SR5
    Thanks
  26. Dec 19, 2022 at 1:34 PM
    Yes. Toyota uses white with black stripe for ground almost universally through the truck. So the proper, easy fix could possibly be jumpering white/blk stripe to pink on the backside of the connector. But don't quote me on that - quote me on the wire color, it's all over the EWDs, but I don't know what the pink dumps into, or if it would be impacted negatively from jumping it to ground while connected.
    Jackson Smith likes this.
  27. Dec 19, 2022 at 2:57 PM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    I did this mod a year ago. It worked perfect, no more light. I'm OCD about dash lights
  28. Jan 28, 2024 at 7:50 AM
    Valkron8
    Valkron8 New Member
    Which wire side do you connect to ground? The side that comes from the plug or the side that goes to the TPMS module?
  29. Jan 28, 2024 at 8:18 AM
    18" TRD Off Road Wheels
    There are literally pictures showing it... :facepalm:
  30. Jan 28, 2024 at 9:48 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    that pink wire. You need to add some sort of extension to it so it can get grounded somewhere.
    Here’s the rig I made up. Just put the pink/silver wire in the slot on the splitter and clamp it down. Plug it back in. And ground the connector to a screw or blot that’s attached to the frame.
    455h0le_dachshund likes this.
