Toyota Tundra Battery
Discussion in '2nd Gen Tundras (2007-2013)' started by kenomouth64, Jan 3, 2018.
  1. Jan 3, 2018 at 5:44 AM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    So my Diehard battery has been giving me fits the past few days. Some mornings it will turn the starter, others it just clicks and I have to hook the charger up to it.
    What size of battery do you recommend?
    What brand?
    Cold Cranking Amps?
    It is 2 degrees where i live currently and that is not the normal here, usually around 37 degrees.
    Y0TA PR0 likes this.
  2. Jan 3, 2018 at 5:49 AM
    Mine has a size 27 battery.
  3. Jan 3, 2018 at 9:00 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Tetrus, as Ron said above, there is plenty of info on what batteries , what's the best, etc.
    I have the Duralast Gold @ 750 cranking amps. No complaints so far. Ran me around $150.
    NewImprovedRon likes this.
  4. Jan 3, 2018 at 2:07 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I stuck a 48 dollar battery from Wal-Mart in mine.
    rons23 likes this.
  5. Jan 3, 2018 at 2:20 PM
    rons23
    Ron
    Kill Devil Hills
    Jeremy let me know how that turns out;)
    theraven, TundraTss and Black Wolf like this.
  6. Jan 3, 2018 at 2:21 PM
    Isn't that like drinking box wine. Lol
  7. Jan 3, 2018 at 2:22 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I'm going on 9 months. If it don't last, my feelings won't be hurt..
    Stulloh and Prostar 190 like this.
  8. Jan 3, 2018 at 2:23 PM
    Great looking truck !
    jeremyd[QUOTED] likes this.
  9. Jan 3, 2018 at 2:24 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I buy that box wine also ! Not joking, lol
    SullyMoto19, JC303, DalTee and 6 others like this.
  10. Jan 3, 2018 at 2:38 PM
    Size 27. Plenty of battery options out there. Depends on budget, use.
  11. Jan 3, 2018 at 4:26 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Group 27. I have the Toyota True Start in mine. Haven't had any problems. I do want to upgrade to an Optima though. I have one in my Xterra that will not die!!!!
  12. Jan 3, 2018 at 4:29 PM
    Ditto on the Yellow Top.....
    gilgawrath and Prostar 190 like this.
  13. Jan 3, 2018 at 4:33 PM
    Keep in mind that there are two versions of group 27. I think 27F has the posts at the front not at the rear of the battery. Battery cables won't reach.
  14. Jan 3, 2018 at 4:35 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    Correct!!!! I forgot to mention that!!! I love my Optima. Its 6+ years old and starts my mini monster like a charm. Be it below freezing or hot as hell.
    Black Wolf likes this.
  15. Jan 3, 2018 at 4:36 PM
    Still the #1 selling AGM battery for good reason....
  16. Jan 4, 2018 at 12:36 PM
    kenomouth64
    Tetrus
    Well thanks for the suggestion the battery that was currently in it was in fact defective (group 35 Diehard Gold Battery, 3 years old). I ended up cheaping out and buying an Everlast MAXX group 35 (640 cca). Upon review, I wish I would have got the group24f as it has 740 cca, thought that could have cause issues dureing the 100+ degree summers here.
  17. Jan 4, 2018 at 12:50 PM
    TheBeast The Beach
  18. Jan 4, 2018 at 12:56 PM
    kenomouth64
    Tetrus
    Sort of curious as to what the inside story is here...
  19. Feb 16, 2018 at 6:59 PM
    pilot218
    pilot218 New Member
    Kevin
    2008 Silver Tundra CM Limited 4x4
    Bilstein 6112s (1.9"), 2 CB shims driver side, 1 CB shim passenger side, front differential drop Bilstein 5160s, Toytec 1+ shackles (set at 1"), 1/2" block spacer driver side, carrier bearing drop, TRD rear sway bar TSS silver rims 20"x9" (+50) Toyo Open Country AT2s 295/60/20 Stock Limited wheels with 275/60r20 Michelin Defenders LineX BacFlip Cover
    My original Toyota battery lasted 9 years and I replaced it with another Toyota battery. I tried an Evermax first but the +/- terminals weren’t in the correct position for the cables. I think it ended up being cheaper too.
  20. Feb 16, 2018 at 7:09 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    I just picked up my Northstar today,
  21. Feb 16, 2018 at 9:26 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  22. Mar 8, 2018 at 5:57 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Odyssey 34R-PC1500 in my Gen 2, 34-790 in Gen 1 also x2 in my boat
    Gen 2 this photo was taken b4 the batt box
    Gen 1
    Boat
    NewImprovedRon, Y0TA PR0 and T-Rex266 like this.
