TOYOTA Read this. Improvements needed on Tundra
Discussion in 'General Tundra Discussion' started by 1UPPER, Jun 11, 2017.
  1. Jun 12, 2017 at 6:59 AM
    #61
    I just tried to load up a GMC 6.2L truck. No option for it....
  2. Jun 12, 2017 at 7:00 AM
    #62
    1UPPER
    1UPPER [OP] Not A New Member
    TEXAS
    Flux capacitor!
    Maybe because they're not comparable. lol
  3. Jun 12, 2017 at 7:02 AM
    #63
    Looks like there is an option for it, but Toyota didn't upgrade the towing capacity or payload. The price is way off as well.
  4. Jun 12, 2017 at 7:10 AM
    #64
    1UPPER
    TEXAS
    Flux capacitor!
    I knew I forgot to add something to that post with the comparison chart. "I 1UPPER cannot verify the accuracy of this comparison chart. I cannot be held accountable for members spending their own time analyzing the far superior Tundra to lesser quality trucks."
    Thanks Chris! I forgot to post a disclaimer on that one. Lol
    1tonGun and ColoradoTJ[QUOTED] like this.
  5. Jun 12, 2017 at 7:11 AM
    #65
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    They need to upgrade interior, sleekness to dash exct... the other big 3 are killin it.. way behind IMO.
    Vector W8 likes this.
  6. Jun 12, 2017 at 7:43 AM
    #66
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
  7. Jun 12, 2017 at 7:46 AM
    #67
    zcarpenter92 likes this.
  8. Jun 12, 2017 at 8:37 AM
    #68
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    Confirmed.
    It's now a cartridge filter under the engine, and you have to remove a skid plate to get to it. Oil changes take twice as long now.
  9. Jun 14, 2017 at 4:13 AM
    #69
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Those rakes drive me nuts!
  10. Jun 14, 2017 at 4:14 AM
    #70
    DalTee
    DalTee New Member
    Dal
    Thank God there's no diesel!
    ColoradoTJ and Law323[QUOTED] like this.
  11. Jun 14, 2017 at 5:41 AM
    #71
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I can confirm this
  12. Jun 14, 2017 at 5:42 AM
    #72
    Eclipsed & Floating
    Voluptuous Whitey
    Explain full floater, Chris. This is a new term for me
  13. Jun 14, 2017 at 5:43 AM
    #73
    Eclipsed & Floating
    Voluptuous Whitey
    3/4 ton would be great....I'd prolly call it a 1 ton.....:D
  14. Jun 14, 2017 at 6:00 AM
    #74
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i have yet to hear someone complain about the pleated leather dash and seats in my platinum not being sleek enough for them. seems like half of these complaints are people venting how they should have bought a higher trim package.
  15. Jun 14, 2017 at 6:17 AM
    #75
    For a full-floating system, the axleshaft only serves to transmit the rotational torque from the differential out to the wheel. It does not carry the weight of the vehicle as a semi-floater does. On a full floater, a spindle is attached to the outer end of the axle.
    Yes you would goofball. :D
  16. Jun 14, 2017 at 6:54 AM
    #76
    Cement Pro
    Stock
    If you've never owned a diesel you'll never understand. Diesels are; more fuel efficient, have greater durability, more torque which comes on very low in the rpm range, easily modified for huge power and torque gains...
    Coolhardy likes this.
  17. Jun 14, 2017 at 7:38 AM
    #77
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    It's Apple's and Oranges. It's just like our Yeti thread. It's what you need it for. Makes no sense whatsoever to put a diesel in a 1/2 ton truck, especially if it's your daily driver and your not doing any heavy towing
    Patriot and zcarpenter92 like this.
  18. Jun 14, 2017 at 7:42 AM
    #78
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I guess I'm comparing to stock Chevy and sr5. Cause is a big difference in what the Chevy has stock compared to Toyota..
    PlatinumPro[QUOTED] likes this.
  19. Jun 14, 2017 at 7:48 AM
    #79
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Don't forget the extra $20,000, DEF, 15 quart oil changes, extra 1,000 lbs of weight...
    15whtrd and zcarpenter92 like this.
  20. Jun 14, 2017 at 8:10 AM
    #80
    Cement Pro
    Stock
    Perhaps you're exaggerating a touch?? The oil change is more expensive but the frequency of change is double that of the Tundra. I'd anticipate roughly 25 mpg vs 14 in the Tundra with gas. Here in my home state I could and would delete the DEF and tune the engine easily gaining 200 hp in the process. The current 5.7 makes what (381/400 ft/lb). The Cummins in stock form makes 385/900 ft/lb. Delete, tune, add a $500 exhaust and your sitting on 600hp and 1200-1300 ft/lb of torque while still easily getting well over 20mpg. Pull a 9000 pound trailer through the mountains in the Tundra you'll get well under 6 mpg and have to run the 5.7 at 3500-4500 rpm to keep the load up to speed. In the Cummins you pull the load easily at speed limit and still get over 14 mpg. Trust me because I just came out of a Cummins. I have owned 4 Tundras including one supercharged.
    Coolhardy, Lilly, Newm and 1 other person like this.
  21. Jun 14, 2017 at 8:19 AM
    #81
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I don't have a diesel but the new ones aren't strong 20mph and over.. no way
  22. Jun 14, 2017 at 8:22 AM
    #82
    Cement Pro
    Stock
    What's that supposed to mean (not strong 20 mph and over)? Mine was an absolute beast in the bottom and top. It had a 12 second 1/4 mile and weighed 9000+ pounds. Those little tires are 37's.
    Coolhardy and Jsena[QUOTED] like this.
  23. Jun 14, 2017 at 8:25 AM
    #83
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That was a typo about strong.. it's crazy to think they are getting over 20mph. If they are that's awesome on a truck like that.. I find it hard to believe that tho.. doesn't mean it's not true
  24. Jun 14, 2017 at 8:29 AM
    #84
    Fair enough. So you want more for less? Good luck with that. I'm sure you would put in 20 extra hours per week at work for no extra pay huh?
    Again, more for less...see above.
    And again, more for less. A diesel option is around 8-10,000.00. If you want a diesel, go buy one. They do make them in a 1/4, 1/2, 3/4, 1 ton trucks. You should look into the GM offering in the mini Duramax.
    There is no way you are putting in a 6.7L Cummins motor in a 1/2 ton and getting any kind of capacity at all. The Rams still have shitloads of front end problems due to the 1050 lb motor up front...among plenty of other costly issues. This leads me to my next comment...See below.
    You may have missed it, but I do currently own a Duramax Diesel 3500, and a "few" Dodge diesels. I do understand the the pro's and con's, but wondering if you have any long term experience with newer Common Rain/emissions systems. Since I have worked in a Cummins repair facility for a long while, I can tell you one thing, daily driving a modern diesel is just ignorant and costly in the long run. Most people trade up every couple of years, so they never experience these problems.
    zcarpenter92, Jsena and rons23 like this.
  25. Jun 14, 2017 at 8:42 AM
    #85
    Cement Pro
    Stock
    You do know the new diesels don't use glow plugs anymore. The front end problem was fixed in 2014. If you get rid of the emissions crap you don't even have to worry about the DEF and regeneration issues. I know of many daily drivers running around with 200,000+ miles.
    Jsena likes this.
  26. Jun 14, 2017 at 8:49 AM
    #86
    No it is not. The cummins is 15K mile oil changes with no city driving or towing. 7500 miles if either of those two conditions occur. The Tundra is 5K for flex fuel and 10K for regular 5.7 motors.
    Delete and tune...now you are comparing a ham sandwich to an apple (and it is illegal as hell). Again, working in the industry, I seen plenty of idiots just throw a programmer on and have at it. It was good for my buddies shop with all the motors, turbos, studding heads, fire ringing heads, trans issues...the list goes on.
    Jsena likes this.
  27. Jun 14, 2017 at 8:52 AM
    #87
    Jesus Christ. You should probably just opt out of this conversation. The Cummins motors never used glow plugs, but heater grids, and this has nothing to do with daily driving.
    Again, deleting this equipment is against federal law and people have been getting hit with fines. Shops especially, and it has gone up from 25000.00 to 50000.00 per occurrence.
  28. Jun 14, 2017 at 8:55 AM
    #88
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    So wait, a diesel isn't a good daily driver?? Just asking for knowledge purpose...
  29. Jun 14, 2017 at 8:56 AM
    #89
    Oh, and the front end was not fixed in 14'. Still alive in 2016. My contractor had several 14-16' 3500 Rams, and all had issues with DPF filters, DEF injection systems, and ball joints/steering tie rod ends before 30K miles. No thanks.
    Wrongside and Jsena like this.
  30. Jun 14, 2017 at 8:57 AM
    #90
    rons23
    Ron
    Kill Devil Hills
    TJ, care to answer. Hahaha
    Jsena and ColoradoTJ like this.
