Towing Performance
Discussion in 'Towing & Hauling' started by Javajim, Apr 22, 2021.
  1. Apr 23, 2021 at 10:37 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    hitech and ColoradoTJ like this.
  2. Apr 24, 2021 at 9:20 AM
    Javajim
    Javajim [OP] New Member
    James
    2014 Tundra Crewmax Platinum 4x4
    Stillen CAI
    I have come to the same conclusions. While I believe I can manage things to stay at or under the limits, it would be a hassle to constantly be wearing my loadmaster hat not to mention the accelerated wear and tear on the truck.
    With that being said, there is a reason those numbers are what they are and according to some of the reputable sites out there, the numbers are compliant to the SAE standard that has a margin of safety built in. There is extensive testing to generate those numbers. For my own personal standards I would have liked to have about a 10 percent buffer between my intended use travel weights and the max limits of the truck.
    I really like this truck, I spent a lot of time researching and searching for it. Now I have to do it all over again.
  3. Apr 24, 2021 at 9:21 AM
    Javajim
    James
    Stillen CAI
    Outdoors RV 21 TRX
  4. Apr 24, 2021 at 9:38 AM
    Javajim
    James
    Stillen CAI
    It would be nice if there was a way to legally bump those official limits up through after market products.
  5. Apr 24, 2021 at 2:30 PM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    Okay, I know i'm over payload and just waiting on new 2022 Tundra. here are are some numbers: 8,400lbs dry weight. probably around 9.400 fully loaded with gear. 1375 payload and 1200 tung weight, I'm over payload. No need to to call me out. This is my 3rd trailer and the heaviest. I've done all the upgrades as far as airbags and shocks to help. I just added roadmaster leaf spring helpers and they helped a little. if the 2022 doesn't solve the payload and towing, i'll probably go GMC. Nevertheless my 2008 has has been rock solid with no issues towing everything. I have 170k miles and have not had a problem towing heavy weight. However I only go about 60 miles and to our favorite spots and in good conditions. no high winds or anything crazy. I go from the San Francisco Bay area to Pismo once or twice a year and that's the toughest 4 Hour Drive I do. one big grade and n0 problem doing it at 60mph.
    Not sure how accurate some of the numbers I have attached..
    Ruggybuggy and Bigboitundra like this.
  6. Apr 28, 2021 at 1:56 PM
    Javajim
    James
    Stillen CAI
    So I purchased a 2019 Ram 2500
    thank for all y’all’s input, it really helped
    really gonna miss my Tundra
    snivilous likes this.
  7. Apr 28, 2021 at 2:15 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    It’s too bad Toyota doesn’t make a HD truck. Unfortunately I was in the same boat as you, exceeding the Tundras payload rating then moving to a HD. Be sure to post how it goes!
    Cpl_Punishment likes this.
