TOTAL CHAOS - UCA Prep (Replacing Bushings & Uniballs) *VIDEO*
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Jun 9, 2018.
  1. Jun 9, 2018 at 3:01 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    https://www.youtube.com/watch?v=HjAqneTSDys
    At TOTAL CHAOS we specialize in suspension products for Toyotas. We designed our Upper Control Arms to be very strong and easy to maintain. Not only do you get added peace of mind having a product much stronger than stock, it’s also much easier to prep! Maintenance and Preparation are key to ensuring your TC products last for many years and many trails to come.
    Above is a video showing HOW TO change your TOTAL CHAOS UCA Bushings & Uniballs. Replacement parts are can be ordered through one of our AUTHORIZED DEALERS or seen at WWW.CHAOSFAB.COM. Email info@chaosfab.com with any questions
    UCA Urethane Bushing Kit
    http://www.chaosfab.com/2007-2017-Tundra-Upper-Control-Arm-Bushing-Kit-69000
    1” STAINLESS STEEL - UNIBALL REPLACEMENT KIT
    http://www.chaosfab.com/2007-2017-Tundra-Replacement-Uniball-Kit
    Want to learn HOW TO maintain your TOTAL CHAOS UCA’s? Visit THIS THREAD for info on greasing your TC Bushings and Uniballs
    https://www.tundras.com/threads/tot...ce-lubricating-bushings-uniballs-video.27032/
    *** DO NOT PUMP GREASE INTO YOUR UCA BUSHINGS WITHOUT LOOSENING THE UCA BOLT. WATCH VIDEO FOR INFORMATION ***
    Give us a shout if you have any questions! SEE YOU IN THE DIRT!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  2. Jun 11, 2018 at 8:30 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    What is your recommended time frame or millage for replacing the bushings?
    What is your recommended time frame or millage for replacing the uniball?
    dcsleeper408 likes this.
  3. Jun 11, 2018 at 8:42 AM
    TOTAL CHAOS
    Corona, CA
    Great question!
    There isn't a set lifetime or life expectancy for those products. A LOT comes down to maintenance and preparation. If you keep your Uniballs Lubed and Bushings Greased we've seen customers with 100K without replacement. We've also seen them need to be replaced at much lower mileage. This TYPICALLY is a result of little or no maintenance combined with living in an area with harsh climates. Maintenance and Preparation is key which is why we've created this thread as well as THIS ONE covering keeping your TC products maintained.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  4. Jun 19, 2018 at 10:33 AM
    TOTAL CHAOS
    Corona, CA
    TOTAL CHAOS - CLOSED 6/22 - 7/09 - SHOP VACATION
    We will be closed 6/22-7/09 for our Shop Vacation. Every year we shut the shop down and allow our team to enjoy a couple of weeks off around the 4 of July. If you NEED replacement parts or to order items please contact us NOW or visit an Authorized TOTAL CHAOS Dealer.
    There will be a slight delay in forum responses. Cause some CHAOS this Independence Day!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  5. Jan 28, 2019 at 11:27 AM
    TOTAL CHAOS
    Corona, CA
    Don't forget to check out the above video before replacing your bushings or uniballs!
