TOTAL CHAOS - UCA Maintenance (Lubricating Bushings & Uniballs) *VIDEO*
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Jun 9, 2018.
  1. Jun 9, 2018 at 3:14 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    At TOTAL CHAOS we want to make it easy to maintain your suspension components! Our Upper Control Arms (UCA) are designed to be easily greaseable without removal from the vehicle or an alignment afterward. With just a few tools and a couple minutes of your time, you can be greased up and ready adventure!
    NOTE: Do NOT pump grease into a UCA without loosening thru-bolt. Doing so will most likely cause the bushing to deform and require replacement. Please watch the videos below on HOW TO properly maintain your TOTAL CHAOS UCA bushings and uniballs
    HOW TO - GREASE YOUR TOTAL CHAOS UCA BUSHINGS
    https://www.youtube.com/watch?v=xvMdAX2uybs
    HOW TO - LUBRICATE YOUR TOTAL CHAOS UNIBALLS
    https://www.youtube.com/watch?v=udUaFDCwGAA
    THRU-BOLT TORQUE SPECS:
    2000-06 TUNDRA (98ft/lbs)
    2007 + TUNDRA (173ft/lbs)
    1996-02 4RUNNER (87ft/lbs)
    2003+ 4RUNNER (85ft/lbs)
    2007+ FJ CRUISER (85ft/lbs)
    1996-04 TACOMA (87ft/lbs)
    2005-15 TACOMA (85ft/lbs)
    2016+ TACOMA (85ft/lbs)
    1998-07 100 SERIES LAND CRUISER (72ft/lbs)
    2008+ 200 SERIES LAND CRUISER (136ft/lbs)
    Want to know HOW TO Prep your TOTAL CHAOS UCA’s? We cover replacing Bushings and Uniballs in this thread:
    https://www.tundras.com/threads/total-chaos-uca-prep-replacing-bushings-uniballs-video.27031/
    Post up or give us a shout if you have any questions! Hope everyone is causin' some CHAOS this weekend!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  2. Jun 9, 2018 at 4:58 PM
  3. Jun 9, 2018 at 7:20 PM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Was tempted to grab a set of UCA earlier today at the ORW customer's appreciation day, but not much % off there.
  4. Jun 11, 2018 at 8:13 AM
    TOTAL CHAOS
    Corona, CA
    Thank You! :thumbsup:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  5. Jun 11, 2018 at 8:14 AM
    TOTAL CHAOS
    Corona, CA
    ORW is just one of our Authorized Dealers. Occasionally one of our Dealers will run a sale or special which will save you a little money. Take a look at our list of Authorized Dealers:
    http://chaosfab.com/media/dealers/
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  6. Aug 7, 2018 at 11:36 AM
    TOTAL CHAOS
    Corona, CA
    We recommend using a grease like Super Lube for our Urethane Bushings. Comment below if you have any questions
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    TexasTundra27 and 5.7TRDProm like this.
  7. Aug 8, 2018 at 4:38 AM
    5.7TRDProm
    Dara
    can't wait for my CRC PTFE dry lube to come in from Amazon so I can install my TC UCA already. It's too bad that item isn't as lightening fast with prime shipping.
  8. Aug 8, 2018 at 4:42 AM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I’ve had real good luck with the Tri Flow Dry lubricant, 63k miles on my original uniballs! Although I think they’re getting ready for replacement finally.
    5.7TRDProm[QUOTED] likes this.
  9. Aug 8, 2018 at 6:43 AM
    5.7TRDProm
    Dara
    The only time chaos is allowed on my bed... haha.
    TheBeast likes this.
  10. Aug 8, 2018 at 9:16 AM
    TOTAL CHAOS
    Corona, CA
    :hattip:
  11. Aug 27, 2018 at 10:01 AM
    5.7TRDProm
    Dara
    Question regarding the uniball lubing. If there anything we can use to maybe spray and clean the uniball before lubing with the CRC PTFE? Like maybe the Tri-Flow Rapid Clean dry degreaser? I just dont like how the uniball is dirty or gunked and then spraying new CRC dry lube all over it again.
  12. Aug 27, 2018 at 10:04 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    I always rinse off the uniball before lubricating. Usually water or water/simple green mix cleans it up nicely. Dry with a rag then apply Tri-Flow PTFE lube
  13. Aug 27, 2018 at 10:12 AM
    5.7TRDProm
    Dara
    Have a dilution number with simple green? Does it clean off pretty good with just water?
  14. Aug 27, 2018 at 10:18 AM
    TheBeast The Beach
    soap/ water / light brushing and drying. Don't overthink it imo.
  15. Aug 27, 2018 at 10:31 AM
    Bailey
    CO
    No dilution number. Blast it with a garden hose - you're overthinking this :D
  16. Aug 27, 2018 at 10:49 AM
    5.7TRDProm
    Dara
    I like overthinking at times.
  17. Aug 27, 2018 at 12:40 PM
    TOTAL CHAOS
    Corona, CA
    Soap & Water or just Water will work to rinse off the uniball. Always clean and dry before re-lubricating :)
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  18. Aug 27, 2018 at 2:46 PM
    5.7TRDProm
    Dara
    thank you.
  19. Feb 12, 2019 at 12:38 PM
    TOTAL CHAOS
    Corona, CA
    What grease should I run in my UCA's?
    We recommend super lube but a few shops have had good experience with red bearing grease. If anyone has experience with other options, please post up! These are just two options that WORK :thumbsup:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  20. Apr 17, 2019 at 7:32 PM
    TOTAL CHAOS
    Corona, CA
  21. Jul 31, 2020 at 12:37 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I used that same grease on mine, new uniballs,new bushings. Greased per video, torqued to specs.
    why do the click and pop going from reverse to drive and vice versa. @TOTAL CHAOS
  22. Apr 18, 2025 at 11:49 AM
    Bucktown_Sweetback
    Bucktown_Sweetback New Member
    TC
    2020 DC Quicksand
    Does anybody have any tips/tricks for dealing with clogged zerk ports? Every time I go to service my TC UCA's, they consistently have issued accepting grease; requiring me to either loosen and cleanse the zerk or just apply a new zerk to the fitting (which becomes a feat on the drivers side interior zerk due to the ABS hardlines). Any information would be helpful!
