TOTAL CHAOS - Stock Length Lower Control Arm (LCA) - Should I upgrade?
Discussion in 'Suspension' started by TOTAL CHAOS, Jul 9, 2018.
  1. Nov 18, 2018 at 3:52 PM
    #91
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    We choose Polyurethane bushings for a great blend of performance and longevity while maintaining a street-friendly ride. These will provide a more responsive feel which many users love. Urethane bushings are stronger for off-road applications. Road vibrations are a little bit more noticeable, but the performance increase on and off the road makes up for it 10x.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    tundra_20 likes this.
  2. Nov 18, 2018 at 4:04 PM
    #92
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    So I keep coming back to/looking at these lowers and come to the same question, simply based off visual appearance and not seeing them in person.
    To me it looks like, from pics, that in static the lower C/O mount is higher on the TC arms vs the OE set as they are recessed into mid width on the LCA.
    Is this just a trick on my eyes or do the King shocks have a special collapsed length to account for this?
  3. Nov 18, 2018 at 4:19 PM
    #93
    TOTAL CHAOS
    Corona, CA
    It's probably a trick of the eyes
    On the Tundra LCA, the Coil Over and Bypass are at the same levels as the factory equipment. The Lower Shock drops down into a pocket up front and the rear bypass mount isn't on top of the LCA. The lexus pictured above has a different mounting style from the factory ^
    The Coil Over shock is the same model that bolts to the factory LCA. We did work with King to develop a stock length bypass shock, It works on our LCA's and OEM LCA bypass mount.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Watt maker and 14burrito[QUOTED] like this.
  4. Nov 18, 2018 at 4:32 PM
    #94
    14burrito
    2014 SR5 CM 4x4 5.7
    Looks like maybe i was looking at a different arm as it was different than what you juat posted a pic of, silly me. Thanks
    dcsleeper408 likes this.
  5. Nov 20, 2018 at 1:11 PM
    #95
    TOTAL CHAOS
    Corona, CA
    TOTAL CHAOS suspension systems & accessories are 100% Made in the USA and handcrafted by our fantastic team in Corona, CA. TC’s experienced fabricators work very hard to provide top performing products that are built to last and also look great. The best companies in the industry provide components like bushings, uniballs, and hardware (all 100% Made in the USA). Each component is hand-picked and tested over thousands of miles to give you maximum performance and durability.
    CLICK HERE to learn more about TOTAL CHAOS products and to check out our current offerings for your ride!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  6. Oct 13, 2019 at 1:24 PM
    #96
    mohd.darmaki
    mohd.darmaki New Member
    Mohammed
    1794 platinum Black model 2017
    Honey-D kit , sos performance lowering kit , TRD daul exhaust , front & rear sway bars ,TRD Air Intake , TRD Pro Grill/Hood Bulge , 2018 Front lights/ Fog lights , Fuel marveick wheels 20x12 negattive44 with grapper 305 tires , Glossy Black Door Handles Cover Half mirrors tailgate w cam, Tundra Steep foot; Fridge center console ,Tundra black Tailgate Trim Bezel , 4x4 Tundra tail , cup olders , Disk Brake Calipers Cover , TRD Liscense Plate , kuda mount black, Super Charger
    I need ur advise am planning to buy the lower control arams for my tundra my question i have already installed the total upper control on my blisten shocks what should i go for in the lower control am not dessert fan but if it will make the car looks good plus more comfortable in bumps i will go for them
    This my car i know in this picture my car is lowered because i don't have pictures lifted with blisten shock so give my ur advice should go for the lower and is the TRD front sway bar should be remove if i install them pls give me ur opinion
  7. Jan 17, 2021 at 10:50 PM
    #97
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    @TOTAL CHAOS Do you guys know if your Tundra stock length LCA is compatible with your spec King 3.0 bypass that you offer? It looks like it is already a tight tolerance between the abs tab and the 2.5 secondary shock in the photo above^. Just wondering if you guys have tested fitment on this yet. A King 3.0 CO and 3.0 bypass for stock length sounds very intriguing.
    Rica25 likes this.
  8. Jan 19, 2021 at 7:48 AM
    #98
    TOTAL CHAOS
    Corona, CA
    Currently the way King makes their 3.0 C/O, if you were to run it you wouldn't be able to run the secondary hoop because the King 3.0 C/O has the studs come up through the coil bucket where our hoops mount.
    Rica25 likes this.
  9. Jan 19, 2021 at 9:08 PM
    #99
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    Would you guys consider remaking or modifying the current secondary hoop in order for this to work?
    Rica25 likes this.
  10. Jan 20, 2021 at 6:59 AM
    #100
    TOTAL CHAOS
    Corona, CA
    At this time that isn't in the works but it would be something to consider in the future.
  11. Mar 2, 2021 at 1:47 PM
    #101
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    I ran the TC upper and lower control arms paired with Kings on my Tacoma. I loved this set up and am planning on doing the same on the Tundra.
    Tacoma setup:
    reywcms, TOTAL CHAOS[OP] and chugs like this.
  12. Apr 17, 2021 at 11:32 AM
    #102
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Are there skid plates available for these?
  13. Apr 21, 2021 at 9:08 AM
    #103
    TOTAL CHAOS
    Corona, CA
    Not from us.
  14. Apr 28, 2021 at 10:10 PM
    #104
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Total Chaos
    would you happen to have the secondary bypass shocks in stock for the mid travel hoops? The lead time from King is insane right now.
  15. Sep 15, 2021 at 10:06 AM
    #105
    Cruzer
    Cruz
    Sunnyvale, CA
    :yes:
    Just pulled the trigger on this!
  16. Sep 17, 2021 at 7:56 PM
    #106
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    You will like them. I had them on my Taco and was saving for these but spent the $$ on bike parts instead. I noticed a difference in the amount of LCA deflection with the bushing differences and was able to get really good caster numbers. They are still on the top of the list for the Tundra.
    tundra_20, TOTAL CHAOS[OP] and Cruzer like this.
  17. Sep 17, 2021 at 8:41 PM
    #107
    Cruzer
    Cruz
    Sunnyvale, CA
    From your experience did you notice if these helped keep alignment in check? Usually, after a wheeling trip I would need an alignment - learning how to do alignments myself helped keep cost and time down.
  18. Sep 18, 2021 at 7:59 AM
    #108
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    I didn’t have any alignment issues but it was a smaller truck with smaller tires. You might want to add cam tab gussets if you haven’t already. I also saw in a different thread that someone installed octagonal (?) cam tabs.
  19. Sep 25, 2021 at 10:22 PM
    #109
    Diesel_dave
    Diesel_dave New Member
    Just bought a set these lca coming in Wed. By any chance does these lca push the wheel forward or did I read that wrong somewhere? I believe almost an in
  20. Dec 21, 2021 at 11:51 AM
    #110
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Will the coilover/shocks work from the stock width kit to the long travel?
  21. Dec 21, 2021 at 5:03 PM
    #111
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    Nope. LT kit requires different shocks. Total Chaos list the required part number on their website.
    TOTAL CHAOS[OP] likes this.
  22. Dec 21, 2021 at 5:47 PM
    #112
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Copy. Thanks!
  23. May 7, 2022 at 10:23 AM
    #113
    CallMeD
    CallMeD New Member
    Are the race series no longer available? I only see the expedition series on the site. What is the difference?
  24. May 9, 2022 at 10:41 AM
    #114
    CallMeD
    CallMeD New Member
    Update - I reached out to TC and received additional info from Pat…
    Expedition series - Has a new uniball housing that was not on the race series? This is also listed on the original post for this thread so I’m wondering if this is just a name change from race to expedition or if there is actually a physical difference/design change…
    Does anybody have the expedition series LCA’s? would love some real world pictures/feedback.
  25. May 9, 2022 at 1:27 PM
    #115
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Sounds and looks like they just changed the name. I bought them back in October when they were called “race series” if I remember correctly. Regardless, I’m super happy with them and know they can take a beating
  26. May 9, 2022 at 1:59 PM
    #116
    CallMeD
    CallMeD New Member
    Thank you! and they do look beefy. I’ve been eyeing these and comparing to the Dirt King LCA’s (big price difference). I already have TC UCA’s.
    TG705[QUOTED] likes this.
  27. May 9, 2022 at 2:57 PM
    #117
    TOTAL CHAOS
    Corona, CA
    Yes it's overall just a name change. We originally had called the new products "Race Series" but as time went on we found that some people felt that they didn't need to "race" their trucks and thus didn't need "race" parts.
    Upon making improvements to the Tacoma LCA (new billet Uniball and steering stops) we decided to make that the "Expedition Series" to better market towards it's target user.
    The 87555-R (stock Tundra LCA) has always had the billet uniball and steering stops but was developed before making a shift towards "Expedition" and getting away from "Race".
    TLDR: same arm, same performance, new name.
    tundra_20 and TheBeast like this.
  28. May 20, 2022 at 8:16 PM
    #118
    CallMeD
    CallMeD New Member
    Just picked up a used set and there is a ridiculous amount of noise…at first, I thought it could be the bushings, but I’m wondering if it’s the uniballs that need some PTFE lubricant. Either way, I’ll be lubing the uniballs tonight
    TG705 likes this.
  29. May 20, 2022 at 8:42 PM
    #119
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    The uniballs do squeak but also the bushings
  30. May 20, 2022 at 8:58 PM
    #120
    CallMeD
    CallMeD New Member
    any advice?
