Top mods under $200
Discussion in '2.5 Gen Tundras (2014-2021)' started by wexttxco, Sep 12, 2021.
  1. Sep 14, 2021 at 11:16 AM
    #61
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    A pair of my Billet Tie-Down Anchors will only run you $89 shipped! You can run two pair on a Tundra, still well under $200.
    https://billettiedowns.com
  2. Sep 14, 2021 at 11:48 AM
    #62
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Let us know how you route the red wire that goes to your battery once ya install por favor, the install video completely skips that part and can't seem to find any good info on how to do it.
  3. Sep 14, 2021 at 11:57 AM
    #63
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    There should be a couple fuses that are 12v constant in the interior kick panel fuse box, but I've never checked with a multimeter. An add-a-fuse would make that a simple thing to tie into, if you could find a power source there.
  4. Sep 14, 2021 at 2:38 PM
    #64
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Yes they are the OEM TRD Pro blacked out headlights. Hopefully NOT part of the recent recall! They are nice…you can’t have these, they’re spoken for :D
  5. Sep 14, 2021 at 2:39 PM
    #65
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I think the recall was just for the halogen lights, not the LED.
    boostedtrdpro[QUOTED] likes this.
  6. Sep 14, 2021 at 2:54 PM
    #66
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
  7. Sep 14, 2021 at 11:58 PM
    #67
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Out of $15K in mods to my 2014 SR5 DC;
    The TRD shift knob is a top favorite..
    I've bought 2 of them, first a sliver, then a black when I blacked the dash out..
    You can find cheap aftermarket on Amazon.
    But I like the TOYOTA OEM parts..
    34A99214-9947-4C01-84E9-82931D2E90AF_zps_a277231ca080fdf7fe38f90f83f6deb6d61d4b89.jpg
    I guess I should add the AJT dash parts...
    AJT DESIGN (ajtdesign-llc.com)
    corwv1ob_zpsdajt4wcz_48bca738373a7ef907e01b257e866ba3bb5bd93d.jpgdh6nc8v6_zpseu3zve2d_30de934e2fd825be0dca800af4d3b56ae1b09955.jpg
    bulldog93, STR1, Wallygator and 4 others like this.
  8. Sep 15, 2021 at 4:53 AM
    #68
    wexttxco
    wexttxco [OP] New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Wonder if they're going out of business, as they only have chrome delete covers for the knobs
  9. Sep 15, 2021 at 7:42 AM
    #69
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Lmfao. I meant rear sway. Stupid auto correct. And yes it is. I’ve used one on every vehicle of mine with or without a supercharger.
  10. Sep 15, 2021 at 9:10 AM
    #70
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Damn, you really had me going for awhile, I was trying to think what toyota could have done to the seat in the TRD's and why I hadn't heard of it yet. I'll have to look around the site and see if anyone has a write up on adding the oil catcher. If it's not a huge job I may get it done with my next oil change.
  11. Sep 15, 2021 at 9:45 AM
    #71
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I would suggest against this and only run it directly to the battery or a accessory fuse block. There is a reason the folks who made it suggest going straight to the battery and not tapping in.
    I don’t know the reason for sure but I know a lot of window motors pull a lot of power so it is likely much safer having dedicated power instead of tying into another circuit that could be damaged.
    It’s a single wire and simple to run, fish it through your door to cab grommet (this is the hardest part as it’s a tight squeeze to work in there especially when you are fat like me).
    That will come out your drivers footwell kick panel. Just a little bit above that in the firewall there is a pass through grommet to the engine. That is on the battery side so just run it to the battery in the engine bay.
    And yes the 3WLiners module is probably one of the most useful mods out there.
    Being able to roll the windows down from the remote is great when it is 95 degrees outside. Let’s a huge amount of heat out before getting in.
  12. Sep 15, 2021 at 9:50 AM
    #72
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Valid point - I didn't think about the current being pulled, just saw what looked like a pretty small gauge wire. If I ever get around to this mod I'll poke around a bit, but you're probably right that it's best to run to the battery/engine fuse block.
  13. Sep 15, 2021 at 10:38 AM
    #73
    pursuit2550
    pursuit2550 New Member
    Not a huge job but some question it’s purpose. I have had one in both S/C and non. On the non S/C it caught some. The tundra does come with a factory style oil catch can already actually.
  14. Sep 15, 2021 at 1:09 PM
    #74
    Shaken_1
    Shaken_1 New Member
    2015 TRD 4x4 OffRoad CrewMax
    Ill say best and cheapest was my console organizer from Amazon
  15. Sep 15, 2021 at 2:09 PM
    #75
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    bulldog93 and Elroy_unlimited like this.
  16. Sep 15, 2021 at 4:09 PM
    #76
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
  17. Sep 16, 2021 at 4:32 PM
    #77
    Bentarm13
    Bentarm13 New Member
    Question about this, how strong is it? I’ve heard very good, and very bad things after install.
  18. Sep 16, 2021 at 4:42 PM
    #78
    Bentarm13
    My mods (DON’T ADD THEM UP)!
    AJT all the way, I didn’t buy anything requiring dash removal
    ESP under seat storage
    Dash cam hard wired
    Console organizer is a must
    Gun magnet by knee
    Leveling kit, it was only $50, install will cost you more
    Blackout covers for emblems, they were cheap and I’m deciding which to just remove completely
    TRD rear sway bar is a must IMHO
    bulldog93 and toyofan87 like this.
  19. Sep 16, 2021 at 4:42 PM
    #79
    TucsonTundra1794
    Anthony
    Tucson, AZ
    It's its strongest right before it breaks.
  20. Sep 16, 2021 at 4:48 PM
    #80
    Bentarm13
    Vague but helpful. I'm not sure I want to risk damaging the A post or the air bag hauling my old ass in.
  21. Sep 16, 2021 at 6:11 PM
    #81
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    It’s exactly the same grab handle that was in all the 2007-2013 trucks for millions of collective miles pulling up thousands of other old asses. Don’t sweat it
    ETA: and the A-pillar frame is exactly the same so no worries there.
    bulldog93, Badknees, 1lowlife and 3 others like this.
  22. Sep 16, 2021 at 6:37 PM
    #82
    Bentarm13
    I will also add, I have applied the crappy black liner along the door edges because I have small monster boys that I assisted in reproducing. Apparently opening the doors like a SWAT officer is the only way to get out of the truck..
  23. Sep 16, 2021 at 7:27 PM
    #83
    camron1039
    camron1039 New Member
    Camron
    2021 Tundra Platinum
  24. Sep 16, 2021 at 7:43 PM
    #84
    AZTundra
    Paul
    Phoenix, AZ
    This is how much I've caught in the past 15k miles. I'm running a dual kit (pcv and crankcase) although the crankcase can has been bone dry since the install. This is all from the pcv catch can.
  25. Sep 16, 2021 at 7:53 PM
    #85
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Locking tail gate for about 60 bucks
    bulldog93 likes this.
  26. Sep 17, 2021 at 5:23 AM
    #86
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
    What is this exactly? Are you talking for the hitch?
    Did you hard wire it to the real mirror?
    Thanks man!
  27. Sep 17, 2021 at 6:02 AM
    #87
    nmjameswilson
    James
    Kansas City
    I had a 2021 Toyota Limited Nightshade built in April and quickly added the below. Some are move overs from the 2008 Tundra but they are mostly still available to purchase.
    Under $200
    Power locking Tailgate
    Cell phone charger in console
    Smoked rear taillights
    VLED Light upgrade for rear
    Matching tint added to front windows
    Chrome Delete from AJT
    Steering Wheel Emblem blackout
    Center Console Tray
    Tomahawk Shifter (From 2008 one) (Very hard to find)
    Inverter Install (From 2008 one)
    Hawk floor mat slide stoppers
    Dash Cam connection to rearview mirror
    Coin cup holder (From 2008 one)
    Over $200
    Leveling Kit
    Spray In Bedliner
    TRD Pro Grille
    Falken Wildpeak A/T3 295/60 R20
    Bed Cover
    Running Boards
    Pedal Commander
    RAM Laptop Stand (From 2008 one)
    Rear facing dash cam (From 2008 one)
  28. Sep 17, 2021 at 6:09 AM
    #88
    :rofl::rofl::rofl::rofl::rofl::rofl:
  29. Sep 17, 2021 at 6:44 AM
    #89
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Some I’ve done:
    LED interior and LP bulbs
    Shifter knob
    Metal oil filter housing
    Magnetic oil drain plug
    AFE dry filter
    TRD air flow accelerator
  30. Sep 17, 2021 at 8:04 AM
    #90
    pursuit2550
    I use to catch about the same from my S/C Silverado SS. In my TBSS N/A I pulled less. Not all engines pull the same either. In the grand scheme of things it will take like 45-50k to fill up that bottle. I have also heard the crankcase can never catches anything. Also most people sell their vehicles with low mileage or average mileage to even know if the catch can was worth it. To each his own I guess.
    bulldog93 and AZTundra[QUOTED] like this.
