Tips for installing Bilstein 6112?
Discussion in 'Suspension' started by phonyteachr, Jul 18, 2018.
  1. Sep 17, 2018 at 11:37 AM
    #91
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I pulled the trigger and stuffed 37X12.5 on 3/1.5 lift.
  2. Sep 17, 2018 at 11:59 AM
    #92
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Beef
    matictundra[QUOTED] likes this.
  3. Sep 17, 2018 at 12:07 PM
    #93
    matictundra
    Franco
    AZ
    Tonka truck look now.
  4. Sep 17, 2018 at 12:31 PM
    #94
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Was trying to order Bilstein 6112's and 5160's from 4 wheel parts who is asking me about "top hats". Is that something needed now? They're charging me $60 to set the 6112's at 2.5", but I am not sure about the top hats.
    Since their labor is stupid expensive, $120 hour, I'm having all this stuff bought individually and then having my local tire shop do the install at $70 hour.
  5. Sep 17, 2018 at 12:48 PM
    #95
    matictundra
    Franco
    AZ
    Top hat is required if you are not re-using the old ones. In this case yes, since you are having them pre-assemble, assuming your truck is not in their shop.
  6. Sep 17, 2018 at 1:09 PM
    #96
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    Side shot? Also excuse my ignorance but what is a diff drop mod?
  7. Sep 17, 2018 at 1:10 PM
    #97
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Gotcha
  8. Sep 17, 2018 at 4:38 PM
    #98
    phonyteachr
    phonyteachr [OP] New Member
    2018 SR5 TRD off-road CM
    Settle in nice and added toytecs 1/2 shim to driver side rear. Driver and passenger side now equal! Need some new rubber eventually..IMG_20180917_162325355_HDR.jpg
    MistrRoboto, equin and Gabby_Miles like this.
  9. Sep 18, 2018 at 10:42 AM
    #99
    matictundra
    Franco
    AZ
    For 4x4, there are spacer kit out there to drop the front differential to avoid extreme angle drive shafts and damage to CV boots and joints. Not typically required for 2.5" lift or below but cheap insurance.
  10. Oct 23, 2018 at 7:48 PM
    #100
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    @.manny. did your TSS system give you any errors after you leveled your truck?
    .manny.[QUOTED] likes this.
  11. Oct 24, 2018 at 8:24 AM
    #101
    Biff_Elwood
    Biff_Elwood New Member
    Denver
    2014 Platinum
    Im working on it!
    Sounds like a diff drop is not needed.
  12. Oct 24, 2018 at 9:17 AM
    #102
    jones83
    jones83 New Member
    2016 Blue Tundra CrewMax 4x4
    For those at 1.9" on the 6112s with a shim on the driver side only, did you use shackles as well for a slight rake? I just installed the front this week, and will install the rear 5160s with toytec shackles, but I don't know if I should do 1" or 1.5" on the shackles. I want the rear to be slightly higher than the front for towing and hauling, but nothing crazy. Any help with pictures of this setup on a flat surface would be greatly appreciated.
    I'll probably order the superbumps while I am at it. My 6112s came preassembled so I don't remember seeing any washers for the bumpstops from Bilstein. Are these really necessary? I see Wheelers sells a 1/4" or 3/8" spacers to go with their superbumps. Would a 1/4" work?
    TacoWuzzaTurd likes this.
  13. Oct 24, 2018 at 10:15 AM
    #103
    32vsnake
    32vsnake New Member
    david
    British Columbia
    2008 DC Limited
    My 6112's are set on the third ring (1.9 and no shims) and I run the toytec shackles at 1". Don't have any straight on side pics and I have an extra 300 lbs in the back from the canopy....the truck sits slightly nose down.
    Biff_Elwood and jones83 like this.
  14. Oct 24, 2018 at 10:18 AM
    #104
    jones83
    jones83 New Member
    @32vsnake Do you wish you had it on the 1.5" setting at all? I plan to eventually have a RTT over the bed for when my wife and I go camping. Truck looks really clean man.
  15. Oct 24, 2018 at 1:51 PM
    #105
    .manny.
    .manny. New Member
    Manny
    2018 Cement Tundra SR5 Crewmax
    no sir, I have not had any TSS issues. I did end up adding Toytec shackles in the rear, so I have very slight rake now.
    I did drive the truck for a few weeks with a little bit of squat due to getting about 2.5" of front lift from the bilsteins, but still had no issues with TSS
    bmcdds[QUOTED] likes this.
  16. Oct 24, 2018 at 6:55 PM
    #106
    32vsnake
    32vsnake New Member
    david
    British Columbia
    2008 DC Limited
    Nope... The 1" setting has been perfect for what i wanted out of my set up.
  17. Apr 10, 2019 at 1:30 PM
    #107
    Tundra BRuh 88
    Tundra BRuh 88 New Member
    2016 Tundra crew cab Limited 4x4 TRD
    Noob alert!
    Does both the spring label Bilsteins need to be oriented to face outward towards the tire or do I follow the markings on the top hat of where the old spring use to be? Because if I did follow the mark then one of the springs with the label would be facing toward the engine bay?
  18. Nov 12, 2020 at 4:50 PM
    #108
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    I’m going to get into this in the near future if it stays warm. I think your comment is incorrect based on the instructions in the link?
    (1) At the front of the arm, loosen the bolt head facing forward.
    (2) At the rear of the arm, loosen the nut facing rearward.
  19. Nov 13, 2020 at 7:12 AM
    #109
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Been a while! I don't remember the specifics anymore, but I do know I tried the wrong one for a while and broke a socket.
