Tips for installing Bilstein 6112?
Discussion in 'Suspension' started by phonyteachr, Jul 18, 2018.
  1. Jul 18, 2018 at 6:03 PM
    phonyteachr
    phonyteachr [OP] New Member
    2018 SR5 TRD off-road CM
    Just picked up a set of 6112's from Boss 4x4. Can't wait to install. Any tips, trials or tribulations for a quick install??
    T-Rex266 and Sas like this.
  2. Jul 18, 2018 at 6:41 PM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    Well first you need to decide what height your wanting to raise your truck. 3rd setting up from bottom 1.9 seems to give a good level +/- .25
    If you got them preassembled then its not to bad to swap over a complete coilover. There is a tutorial thread on here somewhere.
    If you didnt get them as a complete coilover then I would advise at getting a set of KYB top hats/ strut mounts.
    KYB SM5737 - Mount Kit https://www.amazon.com/dp/B0142SLVXK/ref=cm_sw_r_other_apa_cY-tBbTDF0R7P
    @dirtydeeds has a youtube video on assembly
    Goodluck and happy wrenching
  3. Jul 18, 2018 at 6:55 PM
  4. Jul 18, 2018 at 7:03 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    With the 6112's set at 1.9", isn't the only thing that needs to be done is the shock swap in the front and an alignment?
    My plan is 6112's in the front at 1.9", powder coat the existing TRD rims matte black, and upgrade to 295/70/18's. Is that doable without doing anything else?
  5. Jul 18, 2018 at 7:22 PM
    phonyteachr
    Yeah I got them pre assembled at 1.9 for ease of install. I didn't want to mess around with coil compressor from local auto store tool rental...
  6. Jul 18, 2018 at 7:44 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Cant wait to see the after pics!
  7. Jul 20, 2018 at 8:15 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    equin and phonyteachr[OP] like this.
  8. Jul 20, 2018 at 8:56 AM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    I know my limitations, I am definitely going to have a “professional“ install mine!
    MistrRoboto[QUOTED] likes this.
  9. Aug 12, 2018 at 12:03 PM
    phonyteachr
    Ok 6112's finally installed. Install went as planned... unfortunately on the 3rd setting my nose is slightly higher than the rear. Going to give the springs a few miles to settle before alignment. If not I will probably drop to 2nd setting 1.3"...
  10. Aug 12, 2018 at 12:06 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    LOOKS GOOD!
    phonyteachr[OP] likes this.
  11. Aug 12, 2018 at 12:08 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Dang, that's only on the 3rd setting? Seems a bit higher than most other pics I've seen. Looks good though!
  12. Aug 12, 2018 at 12:09 PM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    I got the same slightly nose high numbers as well. After awhile it settled to about even. Unfortunately any weight in the bed and it then goes back to looking nose high. I have shackles on my list to do.
  13. Aug 12, 2018 at 12:19 PM
    phonyteachr
    I definitely have over 1.9 inches right now on 3rd setting more like 2.25...hoping it settles in nice!
    MotoTundra likes this.
  14. Aug 12, 2018 at 12:23 PM
    phonyteachr
    Yep...3rd setting, thinking maybe I should have done 2nd..ugh. That's why I am waiting a few miles before alignment in case I decide to lower to 2nd setting..
    BuckWallace[QUOTED] likes this.
  15. Aug 12, 2018 at 12:26 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Looks great, did you do the install yourself?
  16. Aug 12, 2018 at 12:29 PM
    phonyteachr
    Yeah...all by hand since my air compressor took a crap last week!
  17. Aug 12, 2018 at 12:30 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Go figure. Props to you for doing the install!
  18. Aug 12, 2018 at 12:37 PM
    phonyteachr
    The wife thought I was nuts for tearing the front end of a brand new truck apart!! Hahaha
    equin and MotoTundra[QUOTED] like this.
  19. Aug 12, 2018 at 12:39 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Yeah I could see that!
  20. Aug 14, 2018 at 6:42 AM
    MistrRoboto
    Virginia Beach, VA
    Naa man, your good. It only starts high. Go take a drive around and swerve back and forth to get both sides to compress a bit. It will drop right into place.
    Immediately after I installed mine, I was also about 2.5 inches. Called Darren at Boss to figure out what happened and he said just give it a bit. Sure enough, it goes down.
  21. Aug 14, 2018 at 8:51 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I just installed mine last night at the 1.9" setting. This morning, about 8 hours after install, it was sitting at exactly 2" passenger and 2 .25" driver. So for some reason, I got the opposite of the infamous " driver's lean, " at least for now.
    For what it's worth, mine is a 5.7L double cab 4x4 with stock bumper. Only added weight I have up front is the aluminum TRD Pro skid plate, which I don't think weighs that much (maybe 40-50 lbs?). I thought I remember reading a post somewhere claiming that double cabs normally yield 1/4" to 1 /2" higher lift with 6112s than crewcabs, which is what I was hoping for and was the main reason I set the clip on the 3rd setting from the bottom when assembling them. But either mine's an anomaly or the double cab claim is one of those that may be true for some but not all.
  22. Aug 14, 2018 at 9:06 AM
    phonyteachr
    Whew that makes me feel better!! I am at about 2.5 now so I hope they settle in a few miles just like yours!
  23. Aug 14, 2018 at 9:08 AM
    phonyteachr
    Any issues with VSC or anything after install?? Did you do the zero calibration I hear some others mention??
    equin likes this.
  24. Aug 14, 2018 at 9:59 AM
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    I just installed my 6112's and the spring compressor was the scariest part. Beefy! I did OME rear shocks,
  25. Aug 14, 2018 at 10:06 AM
    phonyteachr
    Wow you set on highest setting...what did you get for lift??
  26. Aug 14, 2018 at 10:09 AM
    groverdill
    joe
    Rathdrum ID
    It was over 3" once I lowered it Sunday, I havent driven it yet but today it is about 2.75" or so. stock 275/65/18 with 1" shackle in the rear. I have some 33"s ready to go on once I get the alignment done
    equin, parker44 and Biff_Elwood like this.
  27. Aug 14, 2018 at 10:22 AM
    MistrRoboto
    Virginia Beach, VA
    No issues here. 2in lift in the front, nice and level. Rear stayed stock.
  28. Aug 14, 2018 at 10:43 AM
    phonyteachr
    Stock UCA's? Alignment dialed in nice??
  29. Aug 14, 2018 at 10:43 AM
    phonyteachr
    Nice!
  30. Aug 14, 2018 at 11:22 AM
    MistrRoboto
    Virginia Beach, VA
    Yes, stock UCA. Only suspension mod was the 6112s set at 1.9in clip, one below the top. That's exactly why I went this route, didn't want to gamble with needing UCAs if I lifted 3/1. I played that game on my FJ and never got it into perfect alignment.
