Tips for installing Bilstein 6112?
Discussion in 'Suspension' started by phonyteachr, Jul 18, 2018.
  1. Aug 21, 2018 at 10:24 AM
    #61
    .manny.
    .manny. New Member
    Manny
    2018 Cement Tundra SR5 Crewmax
    Assembled mine last night. Swapping them into my truck on Saturday. Decided to go with the 1.9 setting up front and stock height in the rear.
  2. Aug 21, 2018 at 10:32 AM
    #62
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    On this video, the washers he tossed away are to be used as bump stop extension so you don't damage your shock when at the top two setting.
    Rica25 likes this.
  3. Aug 21, 2018 at 11:56 AM
    #63
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Yea I'll probably add wheelers offroad SuperBumps. I had them on Taco and they were awesome.
    Rica25 likes this.
  4. Aug 21, 2018 at 1:00 PM
    #64
    matictundra
    Franco
    AZ
    The SuperBumps collapse to the same height as OEM bump stops, zero net effect on extension. You will still need to add the washers provided by Bilstein.
    Rica25 and equin like this.
  5. Aug 21, 2018 at 1:07 PM
    #65
    TacoWuzzaTurd
    Scottsdale AZ
    They were added on my install. The video is not of me.
    Side note The super bumps dramatically softened the jarring effect of impact when bottoming out in the Tacoma. If they're half as effective on the Tundra I will be very pleased.
    Rica25 likes this.
  6. Aug 23, 2018 at 7:05 PM
    #66
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    Got my 11 DC back, yes it was expensive but it had to be done. New Lower arms, cam bolts, ball joints ugh. but the alignment went into spec without a problem and I got my 33"s installed Wildpeak AT3W 275/70/18 . 6112 at top setting, 1" shackle and other supporting drop/spacers ( diff, carrier, bumpstop)
    [​IMG] [​IMG] [​IMG] [​IMG]
  7. Aug 23, 2018 at 7:23 PM
    #67
    phonyteachr
    phonyteachr [OP] New Member
    2018 SR5 TRD off-road CM
    Nice! New lower control arms but stock uppers?? Aligned with no issues??
    Rica25 likes this.
  8. Aug 23, 2018 at 7:38 PM
    #68
    groverdill
    joe
    Rathdrum ID
    Yes it aligned just fine, drives great. I wasn't planning on new lower arms but the shop said the others were ruined during removal of the seized parts. The truck has 145k on it so yeah. I dont think it had spent a night in a garage until I got it back in late June.
    Rica25 likes this.
  9. Aug 24, 2018 at 9:57 AM
    #69
    phonyteachr
    So after 3 weeks of settling here are my numbers....
    Driver side, .25 bro lean
    F 22 3/4
    R 22 1/2
    Passenger side, .25 bro lean
    F 22 7/8
    R 22 5/8
    Overall front lift...2.5 on 3rd setting. Not what I wanted but it looks level...what's everyone's opinion??IMG_20180816_094025740.jpg
    Tsoot, K6BRY and equin like this.
  10. Aug 24, 2018 at 10:18 AM
    #70
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Looks good to me bro
    Rica25 and phonyteachr[OP] like this.
  11. Aug 24, 2018 at 10:38 AM
    #71
    groverdill
    joe
    Rathdrum ID
    Looks fine but a set of shackles would fix the bro lean and not break the bank.
    Rica25, equin and phonyteachr[OP] like this.
  12. Aug 26, 2018 at 11:07 PM
    #72
    K6BRY
    K6BRY New Member
    2017 Black Tundra TRD 3/1 Lift Sittin' on 34s
    So you went from the 1.9 and took them off again and went up to the next click at the 2.5 setting? Is that how i'm reading it? Factory UCAs?
    Rica25 likes this.
  13. Aug 27, 2018 at 2:34 AM
    #73
    phonyteachr
    Nope...on the 1.9 setting I got 2.5 inches of lift...yes stock UCA'S..hoping the 2.5 settles closer to 1.9.
    Rica25 likes this.
  14. Aug 27, 2018 at 2:38 AM
    #74
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Here is my truck with 6112's on the highest setting with 2 CB' shims on the driver side and one CB shim on the passenger side, a little over 3" (stock UCA). I also have #2 CB shackles on the rear springs truck is level within an 1/8" on all four corners, which is what I was going for.
  15. Aug 27, 2018 at 4:38 AM
    #75
    Blueknights75
    Ron
    Clayton, NC
    Did you do a dif drop mod? Looks great!
    Rica25 likes this.
  16. Aug 27, 2018 at 5:31 AM
    #76
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    Yes I did do a diff drop, thx.
    Rica25 and Blueknights75[QUOTED] like this.
  17. Aug 27, 2018 at 9:00 AM
    #77
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Have you measured on level ground? Reason I ask is because I have yet to find truly level ground to measure from after I installed my 6112s on the 3rd setting. I’ve driven several hundred miles in the 3 weeks or so after installing them and my measurements have ranged from 1.75” to 2.25” depending on the angle of the ground parked on. I always try to measure while parked in as level ground as possible, but even with that I can still discertain a slight enough downward or upward angle that may affect an accurate measurement. I suppose most multi-level parking garages might be considered level enough (with the exception of the ramps, of course), but I haven’t had a chance to park in one yet to take out the measuring tape. Anyway, just thought I’d mention that as a possible factor to take into consideration since your measurements seem to be higher than most at the supposedly 1.9” setting.
  18. Aug 27, 2018 at 10:02 AM
    #78
    Tsoot
    Tsoot New Member
    18 Plat White
    Looks Bad Ass I’m definitely doing this soon!
  19. Aug 27, 2018 at 6:10 PM
    #79
    equin
    Ed
    DFW, TX
    Update: Waited a few weeks and a few hundred miles for the coils to hopefully settle (which they never did) before getting an alignment. The alignment, though, gave me what I assume are more accurate measurements, albeit lower ones as well. Whereas before the driver’s side was slightly higher than the passenger side by about a 1/4”, now it’s the other way around. Passenger side is now around 2” while driver’s side is now 1 3/4”. I’m disappointed I didn’t get at least 1 7/8” to 2” on the driver side and now wish I would’ve set them at the highest setting to compensate for the eventual coil spring sag that typically occurs over time. Later on I may remove and disassemble them to set them at the highest setting. Too much of a pain to do that again right now in the Texas summer time heat using hand tools in my apartment parking lot, though.
    Biff_Elwood and Tsoot like this.
  20. Aug 28, 2018 at 6:26 AM
    #80
    Biff_Elwood
    Biff_Elwood New Member
    Denver
    2014 Platinum
    Im working on it!
    Thank you for the very helpful update.
    equin[QUOTED] likes this.
  21. Aug 30, 2018 at 1:42 PM
    #81
    matictundra
    Franco
    AZ
    I'm thinking of stuffing 37X12.5 in mine. Any thoughts?
  22. Aug 30, 2018 at 2:09 PM
    #82
    .manny.
    .manny. New Member
    Manny
    I'm in the same boat, kind of. I went with the 1.9 setting and got much more than that. I've driven it for a week now and it looks to be settling a bit, but not much. The driver's side also seems to be settling more than the passenger side. I've got positive camber as well. Going to drive it like this for another couple of weeks before I mess with it.
    The ride has also been shit at the 1.9 setting. Any bad street, which are a lot in LA, cause a pogo effect. I'm thinking of dropping down to the the 1.3 setting and adding a shim or two on each side. I'm hoping that it softens the ride and still gives me enough clearance to for the 295/70R18 on 18x9 +18 Methods.
  23. Aug 30, 2018 at 2:49 PM
    #83
    phonyteachr
    Weird...while I got more than 1.9 inches on 3rd setting, the ride I think, is much better. Stinks u have had what sounds like a negative experience. I do have to say after an alignment from a chain shop, my camber still seems a bit more positive than I would like....
  24. Aug 30, 2018 at 3:36 PM
    #84
    .manny.
    .manny. New Member
    Manny
    Yea, I'm a little bummed. I thought the ride felt awesome at first, because I hadn't really been on a bad street, but as soon as I started driving it to work, the bounce became noticeable.
    I hope the lower spring perch/ less preload on the spring will mitigate the bounce. If not, I'm going to have to look at a different lift.
    Rica25 likes this.
  25. Aug 30, 2018 at 5:02 PM
    #85
    equin
    Ed
    DFW, TX
    Sorry to hear your ride experience is worse with the 6112s at the 1.9” setting. Do you know how much initial lift you got? Also, have you had a chance to put it in 4wd (assuming yours is a 4x4)?
    I noticed an improved difference in ride after I installed mine. I also purposely hit bumps, dips and pot holes in the road (not hard, though) and I put in in 4wd along a dirt road for a few miles to help the coil springs to sag and settle a bit before getting an alignment.
    I’m interested in hearing if you can fit 295s at the 1.3” setting (if you decide to drop it down a notch). Please give us a report and post photos when you do.
  26. Aug 30, 2018 at 7:42 PM
    #86
    .manny.
    .manny. New Member
    Manny
    I'm 4x2. Bought it mostly as a tow rig, maybe small trails after I install a locker (when warranty expires).
    I have been driving it over bumps and dips to help. :p I am waiting for everything to settle a little more before I even attempt to mess with it or align it. :)
    I plan on adding two shims on each side if I go down to 1.3". We'll see if it works. I'll definitely report back.
  27. Aug 31, 2018 at 7:58 AM
    #87
    .manny.
    .manny. New Member
    Manny
    @equin I forgot to answer your initial question. I think it was close to almost 3", it was bro leaning pretty hard.
    In my excitement to get it done, I didn't measure the base height.
    equin likes this.
  28. Sep 4, 2018 at 1:35 PM
    #88
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Have you guys who are over 2 inches of lift with the 1.9in setting given the truck some nice swerving around to compress the front? I was over 2.5in after install but within about 10 minutes of driving, which included swerving around a bit, it came down to exactly 1.9.
    How many clip spots/adjustment points can you see when you peek under there?
    equin and .manny. like this.
  29. Sep 4, 2018 at 1:54 PM
    #89
    .manny.
    .manny. New Member
    Manny
    Mine have settled a little more after almost two weeks, but still over 2" in lift up front. I've done some swerving around, dips, speed bumps, and stuff like that to get them to come down more.
    I plan on putting my new wheels and tires on this weekend, so we'll see what the truck looks like and drives like after it's all put together.
    I'm on the 3rd circlip, which is the 1.9" setting.
    equin likes this.
  30. Sep 4, 2018 at 4:59 PM
    #90
    phonyteachr
    I am definitely on the 3rd clip and after about 600 miles and an alignment, I am still over 2 inches...2.25 on driver and and a bit over 2.25 on passenger...all good though. 1.9 is average, I am OK being "above average"...lol
    Gabby_Miles, .manny. and equin like this.
