Timing belt master thread/sticky?
Discussion in '1st Gen Tundras (2000-2006)' started by Baller, May 12, 2022.
  1. May 12, 2022 at 11:36 AM
    Baller
    Baller [OP] New Member
    '05 Tundra SR5 DC
    I'm needing to do my timing belt this summer. I've tried to search for a thread with what parts kit I'll need and haven't come up with anything. Maybe it's out there and I'm not using the search function correctly. either way, I know Amazon has a kit but, I've also heard some people claim their parts aren't genuine AISIN. I was going to order from Rock Auto What's the most complete kit and do I need anything more than what the kit comes with ? Also, in the interest of being complete, what else should I look into replacing while it's all apart? Thermostat and seal? Besides the pulley/harmonic dampener tool, are there any other specific tools I'll want to pick up to make the job easier?
    Here's what I've put together so far.
    PMH's timing belt thread within his build thread
    https://www.tundras.com/posts/1917085
    Post from when I did my timing belt
    https://www.tundras.com/posts/2964488
    Parts:
    RockAuto kit
    Gates HD serp belt
    Serp belt tensioner
    Radiator fan clutch
    Fan clutch bracket
    Thermostat
    Thermostat seal
    Radiator
    Tools:
    Pulley/Harmonic dampener tool (Amazon)
    Crankshaft holder (Amazon)
    How to:
    1A Auto Part 1
    1A Auto Part 2
    1A Auto Part 3
    Another helpful video
    Toyota Tech doing a timing belt.
    Newer video from TRQ. This one has, by far, the best camera angles to really see where things are.
    4.7L Timing Belt, Water Pump and Valve adjustment
    Step by step from @Weagle. Stated it's a rough draft so I'll update as he hones and polishes it.
    What am I missing or what have I gotten wrong and need corrected on? If there are any better, more concise videos/tutorials out there, post the link. Better information is always appreciated. Also, if there is a comprehensive timing belt thread, post that and we can all forget this thread.
  2. May 12, 2022 at 12:14 PM
    Voss and des2mtn like this.
  3. May 12, 2022 at 12:34 PM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I just performed this maintenance before doing a 2000+ mile road trip. I bought most of my parts through RockAuto. TKT-021 is definitely more on Amazon than what I paid RA. I went with the Gates HD green serpentine belt in PHM's thread.
    Radiator and fan clutch are good to replace too since you have everything apart, if they haven't been serviced before. RockAuto also carries new upper and lower radiator hoses, depending on the condition of yours they are probably good to reuse. Remove your throttle body and give it a good cleaning, also wipe inside your upper intake inside the engine.
    The only special tools I needed were to hold the crank and the harmonic balancer puller. I'm not even sure I needed the harmonic balancer puller with how easy it came off.
    G_unit3000, Voss, Mater and 6 others like this.
  4. Jan 28, 2023 at 9:57 AM
    Baller
    '05 Tundra SR5 DC
    Understandable hesitation with ordering from Amazon. Updated all links to parts from Rock Auto.
    G_unit3000 and shifty`[QUOTED] like this.
  5. Sep 27, 2023 at 10:20 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Voss, FrenchToasty and ColoradoTJ like this.
  6. Sep 27, 2023 at 10:20 AM
  7. Oct 14, 2023 at 6:29 AM
    rodm1
    rodm1 New Member
    Where I can get the crank pulley tool like in video at 3:40 (last video Toyota Tech)?
  8. Oct 16, 2023 at 7:24 AM
    Baller
    '05 Tundra SR5 DC
    The one linked in this thread works and doesn't contact the surface the belt rides on.
  9. Oct 16, 2023 at 8:12 AM
    Baller
    '05 Tundra SR5 DC
    Yah, that's certainly a limitation of linking specific items to Amazon. The specific item and picture of it are still active. Along with a number of links on that page to equivalent tools, I'd think that would be enough for people to find there way to the tool they're looking for. For whatever reason, I couldn't find a crankshaft holding tool on Rock Auto. Probably my own inability to search correctly. Let me know if someone can find it.
    *Update*
    I removed the links to the auto parts stores because those were just cam pully holders, which are suboptimal. You want the tool that screws into the crank pully. Again, I couldn't find the tool on the different auto parts store sites. I'll keep trying to look for them and update if I find anything. I did add another link for just the crank pully tool.
    shifty`[QUOTED] likes this.
  10. Oct 16, 2023 at 8:47 AM
    Baller
    '05 Tundra SR5 DC
    Thanks for the help. I've updated with the part you've referenced.
  11. Oct 20, 2023 at 4:11 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Is this the right one?
    https://www.amazon.com/dp/B09DKHYXWN?ie=UTF8&pd_rd_plhdr=t
    G_unit3000 likes this.
  12. Oct 21, 2023 at 9:03 AM
    As promised @bmf4069 here's more info.
    I bought the tool at this link for $21.99, and it I can’t tell the difference between it and the Schley product in cast/function, looks like an identical cast, but with added texture: https://a.co/d/3KdCYnb
    EDIT: If all else fails, search scAmazon for Schley 64300, trust me, you'll find ample knock-offs.
    WARNING: There are some BAD copies of the Schley product on scAmazon, be careful Like. Not cast parts, just a triangle welded to a circle. Totally inferior shitjobs. If you have the option for [cast tool] vs. [welded tool] always aim for cast metal, it'll be stronger. Look carefully at pics before buying, this is what you DO NOT want.
    This is what I ended up getting (linked in 1st sentence above), basically someone in China took Schley's tool, made a mold of it, and is casting these knockoff tools. They're identical, but you can see imperfections on the surface of mine, including what looks like flaked coating from the tool they molded with - honestly this may be a knockoff of a knockoff, as crazy as that sounds. I'm sure it's inferior quality to Schley (p/n 64300), and is made with pot metal, but hopefully is sufficient to do the job seeing as Schley's tool costs 4x more. Schley's looks way nicer in-person though.
    If you're not understanding how this tool works, this video will help. Obviously, you won't need it if an impact wrench can whing the crank bolt off, but ... in the event it can't, you'll be doing the same thing this guy is doing with a breaker bar in the 1/2" ratchet/bar provision and a breaker bar on the bolt. For the 1GT, I've seen people throw a breaker bar in the square provision and wedge it under the framerail or something to hold tension, so they can 1-man job it and put max torque on the brank bolt.
    FirstGenVol and bmf4069[QUOTED] like this.
  13. Nov 27, 2023 at 9:13 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Hi Y'all,
    I'm getting ready to replace the timing belt on my '03 4.7. I've read the relevant threads including the sticky (Thanks, @Baller - nice work). This will be the second timing belt for this Tundra (141K and 244K). Question: why do we replace the fan clutch and fan clutch bracket? Is this simple preventative maintenance given that the parts are off, they've given 250K miles of service and it's time to replace them? I'm wondering if I can save $200 by not replacing them. Has anyone seen a failure in these parts?
    Truth be told, I generally take a preventative maintenance approach to this stuff but these two parts make me wonder if they can go another 90K.
    Thanks.
  14. Nov 29, 2023 at 4:56 PM
    Baller
    '05 Tundra SR5 DC
    Don't take this as speaking for others but, it's simple preventative maintenance. If your parts still function and saving $200 is more desirable than the risk of failed parts, have at it. I don't think anyone here would fault you like they would if you bought your parts off Amazon.
    jimf909[QUOTED] likes this.
  15. Nov 30, 2023 at 2:33 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Failure of the fan clutch can result in overheating, perhaps an inconvenient breakdown along the side of the road, and possibly head gasket failure if you don't react fast enough to the overheating. Not nearly as catastrophic as a timing belt failure. While it's certainly easier to replace while your engine is apart, it's not a huge problem to change later if you choose.
    The fan pulley bracket, on the other hand has only one critical component...a bearing. Failure of this part will likely announce itself long before it's a crisis, so not likely to leave you stranded, or cause engine damage. It is way more hassle to replace after your engine is back together, however, and zero effort to replace "while you're in there".
    G_unit3000 and jimf909[QUOTED] like this.
  16. Nov 30, 2023 at 3:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I probably need to think about replacing mine soon. What's the process if doing it separate from the timing belt.
  17. Nov 30, 2023 at 4:42 AM
    w666
    Maryland
    Something like this...
  18. Nov 30, 2023 at 6:56 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I’ve only ever replaced one fan clutch over multiple vehicles and that was obvious when it occurred. I would leave it
    whodatschrome and jimf909 like this.
  19. Jan 22, 2024 at 1:03 PM
    jimf909
    Washington or Idaho
    2003 Tundra 4.7 2UZ-FE Timing Belt Replacement Notes
    I'm adding a few notes to this excellent thread on replacing the timing belt. This Tundra has 245K miles with timing belt replacements at 142K on 9/27/2014 and 245K. I felt like I was driving on borrowed time for the last few thousand miles which wasn't any fun. This is a straightforward job and risking a blown engine by extending this service interval (90K miles or 7 years) is just plain dumb. :crazy: If you look at the service interval above I'm squarely in the just plain dumb category.
    Tools
    This photo shows all the tools I used (with the exception of a 3/8” drive torque wrench, big 90 degree needle nose pliers and the angle grinder to cut off the fan pulley nuts). It’s pretty straightforward: screwdrivers, hammers, 3/8" and 1/2" breaker bar (mainly used to turn the engine), ratchets, sockets, extensions (wobbly comes in handy a few times), (very) light duty impact driver, HD impact driver, pliers, combination wrenches, flashlight, etc.
    • The big Ridgid impact driver easily removed the crank pulley bolt so I didn’t buy a harmonic damper/crankshaft pulley holder tool. Note: this impact driver would not fit if I didn’t remove the radiator, fortunately removing the rad is easy and I wanted to do that anyway. A subcompact impact driver would probably do the job.
    • Pulley puller: I did not use a puller to remove the harmonic damper/crankshaft pulley. As suggested in one or more of the videos I just used the two big pry bars and it was fairly easy to remove. However, having a puller available is a good idea in case your pulley is the one that's stuck.
    • Big 90* Needle Nose pliers: also not shown and super helpful in removing/reinstalling hose clamps. The pliers shown don't work very well on the stock hose clamps.
    • Hopefully you won't need an angle grinder for stubborn nuts.
    Gumption Traps
    Most of the work was straightforward. I ran into a few gumption traps:
    • One of the skid plate bolts was a PITA to remove. First I was lazy and rounded it off a bit so then I needed to get in there with some PB Blaster and carefully remove it. This was a problem mostly due to my poor practices while thinking it would be a jiffy to remove. Where's the dummy emoticon?
    • Electrical plugs: I still don't know the secret to some of these and have a heckuva a time separating some of them.
    • Fan pulley bolts: this was the only one that was truly a problem. My guess is that the previous mechanic just plain over tightened these. I used heat, long pry bars, etc. and finally resorted to cutting the bolts. Fortunately the fan pulley bracket and fan clutch were being replaced. More info here.
    Tips
    • Radiator: I removed the radiator because it's very easy, I needed better access to the crank pulley bolt and I just like more space when working. It can be done w/out removing it so it's your choice. Did I mention it's easy? Four easily accessed bolts.
    • A/C compressor: I didn't remove the rear-most 1 - 2 bolts or move the A/C compressor. Removing the 3 (?) forward bolts frees up the water pump housing as needed.
    • Jacking: if it wasn't for the one skid-plate bolt that I screwed up I wouldn't have had to use a jack or jack stands (my Tundra has a stock suspension). As in the one video nearly all can be done from above but I got under the truck quite a few more times.
    • Coolant dumps: be prepared for several dumps of coolant. I thought I was mostly done with them after removing the rad but there were a couple more big ones when removing the t-stat housing and another when removing the water pump. I shoulda known but laziness was winning that day. It did take more effort to clean-up than to put a plan in place.:annoyed:
    • Accessory belt pulley tensioner size: the new Dayco 89255 accessory belt tensioner pulley was about 1/2" smaller than what was on the truck (roughly 3.5" v. 4"). This seems to be known and the smaller pulley is working fine.
    • Timing belt tensioner: DO NOT PULL THE PIN until you're 100% certain that you're ready or have a vice to compress it. One vid says it can be reinserted using big pliers but that seems like it would suck. If you're re-using the tensioner be ready with a vice or forearms of steel.:muscleflexing:
    • Buy the Aisin kit! The belt I took off was not an Aisin (Mitsuboshi) belt and it didn't have some of the markings to line it up. This is mentioned in one of the auto parts store videos and I would have hated doing this job w/out those markings. Plus, my confidence in the Aisin parts is much higher.
    • I probably did the work over about 18 hours. I work slowly. I don't have wifi in my garage so I'd stop the work, walk to the house, watch a relevant video, have lunch, get distracted and then stop to eat dinner. The day is over. Repeat. Did I mention I work slowly? If I did it again I could probably do it in 8 - 10 hours, maybe faster. If I didn't stop to chase squirrels. If you need to get this done over a weekend, do some of the disassembly (radiator, fan, power steering pump, alternator, timing belt covers to get an eye on the timing belt) on Friday evening. Remove the water pump Saturday morning, replace the timing belt by early afternoon, look at it a few dozen times and begin reassembling. Put the final bits back together on Sunday morning (no church this week), add the coolant, check the ATF and put the shiny new sticker (timing belt done date and miles) on the firewall and give it a test drive. Something like that, YMMV.
    Supplies - don't forget:
    • A quart of: Toyota Genuine ATF Type T−IV (ATF JWS3309 or NWS6500), you may only need a few ounces.
    • Asian Red coolant
    • FIPG (formed in place gasket) gasket paste for one seal on the water pump.
    Videos
    • I watched many of the videos. By far, this was my favorite. The dude is straightforward and goes about the job pretty efficiently. Thanks @Baller.
    The damn fan pulley bolts that I had to cut off. Someone had tightened these beyond my best efforts. Instead of an angle grinder, a dremel tool would have been cleaner to just cut the nuts off.
    The parts pile:
    Weagle, BroHon, bmf4069 and 3 others like this.
  20. Jan 29, 2024 at 9:06 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I use the straight pick for stubborn electric connectors. Find the tab portion of connector. And use it to gently push down or up on the tab while simultaneously pulling the connector. The connector will slide out like me on prom night
    also I’d recommend the chain wrench instead of the pulley holder thingie. They’re dirt cheap and do the job well. I used the Bremen from Harbor Freight and a piece of old belt to protect the pulley.
    BroHon and jimf909 like this.
  21. Apr 15, 2024 at 7:45 AM
    qdjohn
    qdjohn New Member
    2003 AC SR5 V8
    I didnt want to make a new thread asking this question.. but, if I use a impact wrench on the crankshaft pulley, I wont need to use the crankshaft holder and pulley/harmonic puller tool?
    Also I am curious if you guys think a m12 fuel impact wrench would break it loose or will I have to step it up and use a bigger impact wrench.
    Thanks!
  22. Apr 15, 2024 at 7:55 AM
    des2mtn
    SW
    Tonto cover
    Depends on how slim your impact wrench setup is I would think. Even with the radiator removed, none of my impacts would fit in there really unless I removed the condenser/ core support. The holder makes it easy to torque the pulley when you're putting everything back together.
    bmf4069 likes this.
  23. Apr 15, 2024 at 7:58 AM
    qdjohn
    qdjohn New Member
    2003 AC SR5 V8
    Gotcha, thank you for the insight!! I will try to order them now just in case, and if they dont get here in time I will try to rent from the Loan-a-tool at autozone.
    Im tackling this timing belt change on friday
  24. Apr 20, 2024 at 6:14 AM
    qdjohn
    qdjohn New Member
    2003 AC SR5 V8
    For the FIPG, did you use toyota or is there another brand/company we can use?
    Thanks
  25. Apr 20, 2024 at 6:28 AM
    des2mtn
    SW
    Tonto cover
    This is what I used. Napa should have it as well I believe.
    jimf909 and FrenchToasty like this.
  26. Apr 20, 2024 at 6:35 AM
    qdjohn
    qdjohn New Member
    2003 AC SR5 V8
    FrenchToasty likes this.
  27. May 4, 2024 at 7:21 AM
    BroHon likes this.
  28. May 6, 2024 at 1:04 PM
    Milo_Snuff
    Milo_Snuff New Member
    Peter
    2005 Red Tundra AC TRD
    Magnaflow exhaust, body lift
    Just did my Timing belt last night. While putting back together the LH cam jumped the belt anx shifted positions about 45 degree's CW and I had to rotate it back upon rotation it sprung another 45 degrees CCW. Finally was able to hold proper position with the belt to get it correct. My question is: did I mess up a valve possibly? I ensured timing was correct twice after all was said and done, but am afraid to start if it will risk more damage. Also the small triangular timing belt cover. It fell into the coolant bucket and I thought my truck was missing it. Only found it after re assembly. Should I disassemble and install?
  29. May 8, 2024 at 9:48 AM
    jimf909
    Washington or Idaho
    If all the timing marks were correct when you released the tensioner all should be fine. It can be heart stopping when the valve spring tension spins the cam. Setting the timing belt with the cam marks just before (less than 1/8") the timing mark can help. If the cam mark is just after the timing mark the poltergeist spinning of the camshaft is more likely. At least I think that's correct, it may be the other way around. That happened to me several times.
    As for the dust cover, ugh. It helps keep dust and debris out of the timing belt cavity to keep them from wearing the belt. I don't recall all the steps needed to get it back in there but I recommend getting it back in. Or covering the opening up with duct tape (Aisin duct tape, of course).
  30. May 8, 2024 at 10:19 AM
    FishNinja
    Lee
    06DC2wd
    I bought the red from freight Al la harbor. Zero issues. Fight me
    bmf4069 likes this.
