Tiger Tanker's White 2016 Platinum Edition Adventure Build
Discussion in '2.5 Gen Builds (2014-2021)' started by TigerTanker, Nov 28, 2017.
  1. Dec 17, 2017 at 2:00 PM
    TigerTanker
    TigerTanker [OP] Tyranny doesn't leap, it creeps
    Tacoma WA
    2016 White Platinum Edition Tundra
    none so far
    My next big move might be to upgrade interior lighting, puddle lighting, and reverse lighting which isn't bright enough for me. On the reverse lighting, not sure I need Baja quality at 50mph in reverse type stuff. I just wanna be able to clearly see through cam and mirrors where I'm going on a dark wet foggy night.
  2. Dec 26, 2017 at 2:24 PM
    TigerTanker
    Tacoma WA
    none so far
    Based upon my truck's appearance, does anyone have recommendations on a style/brand of fender flares? I will want them in white.
    Indeed, as the truck currently stands, they are spraying the sides pretty good with debris.
  3. Dec 26, 2017 at 2:29 PM
    I like my Bushwacker made Stampedes although you may want to go with Wackers' wider coverage pocket style.
    TigerTanker[OP] likes this.
  4. Dec 26, 2017 at 2:38 PM
    TigerTanker
    Tacoma WA
    none so far
    I just called Line-X in the South Puget Sound area. Since I'm installing some hardware into the bed of my truck, and yanking out the Toyota bedding, and putting an elaborate rack system on my truck I figured I should ask questions.
    I got a quote for $500, and they suggested I do the drilling first for my later to be applied items. He said that drilling in later doesn't void the warranty as someone had warned me of previously. I was told the process is done in about 2 hours and can be done in any weather, the process cures very quickly.
  5. Dec 26, 2017 at 2:39 PM
    That quote sounds about right...
  6. Dec 30, 2017 at 3:55 PM
    TigerTanker
    Tacoma WA
    none so far
    Work day...
    9BD4EF26-0FC1-454C-A987-2B30DCFFDC52.jpg 6CC3C044-396C-4397-BE3E-6E1B28805CA7.jpg F4DB6935-51DD-44D6-B72D-A6CCA0F58F9D.jpg C0174552-2D67-4AFD-BD3A-359001CA5BC0.jpg
    Black Wolf likes this.
  7. Dec 30, 2017 at 3:57 PM
    TigerTanker
    Tacoma WA
    none so far
  8. Dec 30, 2017 at 3:57 PM
    I'm really liking that rack.
  9. Dec 30, 2017 at 4:00 PM
    Is that the ADV system rack?
  10. Dec 30, 2017 at 4:03 PM
    TigerTanker
    Tacoma WA
    none so far
    The Wilco rack must me 2nd generation. The directions were a bit off but my two friends with mech skills figured it out and install was done in 2 hours. One bolt was missing from kit.
    The advertising for this system is a bit low budget and the ordering process a bit unprofessional and a bolt missing. Other than that, this system is very damn nice and of very high quality with quality craftsmanship.
    Also installed were risk racing bike mounts. The motorcycles are attached by clamps at the foot pegs. No tie downs needed.
  11. Dec 30, 2017 at 4:07 PM
    TigerTanker
    Tacoma WA
    none so far
    The risk mounts need some better bolts... but the system is very slick. I can quickly remove from truck bed with 4 easy screws.
    I’m going on a 5 week road trip through west USA and Mexico this spring and these mounts will be so much easier than last year!
    The above truck rack is stout! Fantastic storage options up there!!
  12. Dec 30, 2017 at 4:10 PM
    TigerTanker
    Tacoma WA
    none so far
    Next up is a BedStep2 for the rear. Please give feedback if you got any!
    I also want to upgrade lighting, add flares, and other customs for my dirt bike stuff. Feel free to shout out suggestions or ideas.
  13. Jan 4, 2018 at 5:22 PM
    TigerTanker
    Tacoma WA
    none so far
    Ok, so for folks that want a closer look on the Wilco rack.
    FYI, was very impressed with the quality of the finished product.
    The instructions had the first gen stuff, and missing one bolt. Otherwise, perfect.
  14. Jan 4, 2018 at 5:23 PM
    TigerTanker
    Tacoma WA
    none so far
    hoping that @BlueBottle weighs in on his lighting upgrade advice...
  15. Jan 4, 2018 at 9:30 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Trucks coming along nicely! I like that rack!
    As far as led bulbs, if you want the best get VLED’s. They are the brightest and I like the fact that you can get them in 5k color so it’s more white than blue. Gotta warn you they aren’t cheap! But def worth every penny! They have a sale that ends tonight I believe but they always have sales on every holiday.
    For the front turn signals use the vled triton V6 w resistor so no hyper blink. You can also run the triton for the rear brake lamps.
    For the headlamps you should either get a retrofit or oem 18 leds. Anything else is a waste. Stock fog location I can’t say enough good things about bajadesigns. Super bright. Not cheap either tho...
  16. Jan 4, 2018 at 9:30 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  17. Jan 5, 2018 at 9:02 AM
    TigerTanker
    Tacoma WA
    none so far
    @BlueBottle
    Ok, thanks for touching base with me. Today I'm going to study your links and thread some more and come up with a shopping list!
    Did find some used white Bushwacker fender flares for a very good price on Craig's List for $450, usually they go for 800 ish, so I figure I'll try them out and if I don't like them I'll sell them again.
    BlueBottle likes this.
  18. Jan 5, 2018 at 9:22 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Nice build, fun to watch!
  19. Jan 5, 2018 at 9:31 AM
    #49
    TigerTanker
    Tacoma WA
    none so far
    @1UPPER
    Have been looking at your build thread... very impressive.
    Looking at my truck, what suggestions do you have for a cool front headlight set up? Whitish, blueish would be nice, and my fog lights totally suck, and I'm really trying to find something that lights things up a bit more to the sides because if I'm turning sharply in the dark, there is no light being cast by the headlights or fog lights.
    Thanks!
    1UPPER likes this.
  20. Jan 5, 2018 at 10:01 AM
    #50
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Thanks for the kind compliments on my Tundra build! You've got a great looking Tundra! A few suggestions I would make for headlights. The new 2018 headlights IMO look great but they don't project as much light output as a high quality projector on the previous style housing. I currently have the morimoto DS2 4.0 but I've also heard very good reviews with other projectors. I went with the DS2 4.0 because they allow you to fit them into the stock housing without needing to cut. I'm still running the stock fog lights with LED bulbs. I don't recommend putting LED bulbs into a stock reflector. You get great light output but the light shines in all directions including the top of the trees. This ends up blinding oncoming drivers. For fog lights, I'm a fan of the Baja Designs Squadron Sport lights or the Rigid Industries Dually SAE leds. You can also do the Morimoto projectors for your fogs. As far as color of your light goes. That's a personal preference. I'm running 5,500 K bulbs for my projectors. Typically the more yellow the light output the farther the light pattern but I personally prefer a more white bulb. That's why some people go with yellow lenses on their fog lights. I hope this helps. Lots of great post on here for headlight retrofits.
  21. Feb 14, 2018 at 10:45 AM
    #51
    TigerTanker
    Tacoma WA
    none so far
    Before Fender Flares and After. Some Tundras and their associated mods do NOT look good with flares, but some do. I bought these $850 flares for only $400 from a guy that had them on his truck for only a few months...they didn't look good on his rig. I'm very happy with how they look on mine! A fellow Tudra forum member helped me score the good deal on these...THANKS!
  22. Feb 14, 2018 at 10:52 AM
    #52
    TigerTanker
    Tacoma WA
    none so far
    Was getting very tired of the mess the "no flares" were making on my truck. Hope this helps.
    Yesterday, also installed Phillips LED headlights. Cost $200 and made a HUGE difference!! Glad I didn't spend $800+ on full housing etc...
    Also installed the VLED lights inside the vehicle, the cargo light, and the rear white lights. Bam! From awful to awesome!!!
    I didn't read @BlueBottle thread quite enough, and ordered the upgraded puddle bulbs...but they don't work. So, I used his post about the replacement (self contained units) and will order those asap.
    I do want to upgrade my fog lights, but just the bulb. I really don't wanna spend boatloads on the housing and fogs.... so I'm assuming that perhaps Phillips also makes a bulb for my fogs? Input appreciated on this.
    Next up, I'm going to figure out how to improve the acoustics in the vehicle by getting the car filled with foam etc. Input appreciated there too, I'm going to contact a car stereo company about that as soon as I know what I need to do, and a rough idea of what it might cost.
    Also considering putting line-x UNDER my vehicle. I would think that would protect it from corrosion and also deaden noise.
    My big West USA trip starts in about 6 weeks!!
  23. Feb 14, 2018 at 10:54 AM
    #53
    dradd
    dradd Sometimes there is just us
    City of Champyinz
    '17 TRD Pro
    pending...
    Nice truck, its coming along well.
  24. Feb 14, 2018 at 10:54 AM
    #54
    TigerTanker
    Tacoma WA
    none so far
    More flare pics with the Jester Wheels and Toyo tires
    Heatonrx likes this.
  25. Feb 14, 2018 at 11:03 AM
    #55
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    nice rig, i'll keep an eye out on I-5 for it. what lift you running again?
  26. Feb 14, 2018 at 11:05 AM
    #56
    TigerTanker
    Tacoma WA
    none so far
    Toytec 3 inch with Bilstein
    I have the rig on bad gravel a fair amount, and I can power through the ruts and puddles with little a ripple on my cup of coffee! Nice stuff, and a great investment.
  27. Feb 14, 2018 at 11:08 AM
    #57
    TigerTanker
    Tacoma WA
    none so far
    The truck is seeing plenty of gravel at Shelton Dirt Rider. A Private Off Road Vehicle club in Western Washington State. My son and I are out there each weekend building motorcycle and ATV trails.
  28. Feb 17, 2018 at 12:39 PM
    #58
    TigerTanker
    Tacoma WA
    none so far
    I just ordered the Go Rhino RBG10 running boards with steps from auto anything. They aren't a discount item, but I managed to use chat and get a smoking deal as a new customer. $650 shipped. I've scheduled an appt with a local audio shop to have the doors sound deadened as they rattle like hell when playing music. Will see how that goes, as I suspect the stereo otherwise is good enough for me. I'm also going to line-x the bottom of my truck, got a quote for $350...seems pretty reasonable and the guys in my area Fife, Wa, did a nice job on my bed liner a couple months ago.
    I'm very pleased with this website. The software here is fantastic and the members have been great, feel like I've saved a ton of hassle and trouble trying to get my ride set up. So many useful and helpful ideas here! Thanks everyone.
    DaBoro54 and thetwood like this.
  29. Feb 20, 2018 at 5:13 PM
    #59
    Heatonrx
    Heatonrx New Member
    You have a +12 offset? Looks good with the flares.
  30. Feb 21, 2018 at 6:45 PM
    #60
    TigerTanker
    Tacoma WA
    none so far
    So, I spent $550 to have my doors stuffed.
    Wow, what a difference!
    I had asked the folks at Rainier Audio in Lakewood Washington to come up with some stereo upgrade ideas
    They told me that my premium JBL system was very good and unless I liked really heavy bass music, my truck needed nothing more than the sound deadening.
    Pure Awesome! My stereo now sounds solid and the doors no longer vibrate and shake.
