Throttle Response
Discussion in '2nd Gen Tundras (2007-2013)' started by Junior4888, Nov 4, 2016.
  1. Dec 13, 2018 at 6:26 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I had the same problem for a couple of years. I tried holding my right foot every way I could think of to stop the lurching at slow speeds on rough roads and never found anything to improve the issue.
    I took a chance on this peddle and I'm glad that I did. It's much smoother on rough roads that the stock one. No more lurching and bucking over potholes when I'm moving slowly.
    FXFormat[QUOTED] likes this.
  2. Dec 13, 2018 at 6:33 PM
    flywheel
    flywheel New Member
    Red Tundra
    did you loose the top end power? i dont care about spinning my tires , I just want to control my truck. I think if I had a stiffer spring in my old one it would work great. it wasnt soft until after the recall. it actually could be a danger the way it is.
  3. Dec 13, 2018 at 6:38 PM
    FXFormat
    FXFormat New Member
    Didn't lose any top end, it just maps the acceleration differently now, smoothing out the throttle. Let's say before, when you push the pedal 30% you'd end up with 70% power, now when you push it 30%, you'd get 30% power kinda thing. Nah mean, jelly bean?
    flywheel and careyrob like this.
  4. Dec 13, 2018 at 6:43 PM
    flywheel
    flywheel New Member
    Red Tundra
    I can def live with that. Thanks for your assistance. Ill keep you informed when i get it on. :)
  5. Dec 13, 2018 at 6:46 PM
    careyrob
    Carey
    Massachusetts
    Same thing for me.
  6. Dec 27, 2018 at 5:54 PM
    flywheel
    flywheel New Member
    Red Tundra
    FXFormat , I installed the new pedal, It works great. I never lost a bit of power but did gain control of my truck again. it is smooth. Thanks again for sharing your experience with the new style pedal .
  7. Dec 27, 2018 at 7:02 PM
    FXFormat
    FXFormat New Member
    Nice bro, i'll take a coors light if our paths cross one day. Enjoy!
