Thoughts on 6" lift?
Discussion in 'Suspension' started by CDB, Nov 15, 2019.
  1. Nov 19, 2019 at 6:40 PM
    TxTundra37
    TxTundra37 New Member
    Deer Park
    2019 Black Platinum Tundra
    6" pro comp stage II lift, fender flares, bakflip cover, 36" light bar, 35" Nitto's, etc..
  2. Nov 19, 2019 at 6:41 PM
  3. Nov 19, 2019 at 6:53 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Oh trust me will do. I sent it to you and Mike. Also the salesman said today that they make a plate to put on my pondtoon trailer so the sway bar can hook up to it. Measured the pondtoon tonight Iam at 35 feet long. Lol
  4. Nov 19, 2019 at 6:58 PM
    6" RC lift, 35x12.50x20 tires, 20x9 wheels with +20, tires are flush with fender flares, after being on here for some time now, I have learned from seasoned vets on here, yes the Tundra looks cool on a 6" lift, but ride quality is CRAP! BUT, for what I do with MY Tundra, suits me ok, I plan on starting all over again, don't get me wrong, I love my Tundra! But I also want ride quality as well, I don't live in the Rockies or out in the desert and the lift I have wouldn't work well at all, do your research and how you plan to use your Tundra, you wanna do a spacer or drop bracket lift, so be it, it's your money, you wanna Baja race, climb rocks and have a great ride and all that, then be ready to spend some money, you got lots of members on here that are willing to help you and give good advice on what you want to achieve with your ride, good luck
    Trooper2, georgiey22, 15Yota and 9 others like this.
  5. Nov 19, 2019 at 7:41 PM
    CDB
    CDB [OP] New Member
    Nice looking truck, thanks for the info
  6. Nov 19, 2019 at 7:55 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    3 in lift- minimum 34in tires
    6in lift 35 minimum, id try for 37's
  7. Nov 19, 2019 at 8:09 PM
    CDB
    CDB [OP] New Member
    I'm going with this setup. 6" ProComp, 20×12 rims with -43 and 35" tires. Hopefully tires only come out an inch or so past the fender flares
  8. Nov 20, 2019 at 3:14 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    when ?
  9. Nov 20, 2019 at 7:40 PM
    CDB
    CDB [OP] New Member
    Unfortunately I can't schedule it until December 30th, that's the only time I will have a 2nd vehicle
  10. Nov 20, 2019 at 7:46 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Good luck with ur build!! Make sure you sent pictures. Also I wished I have took measurements before lift and after lift.
  11. Dec 7, 2019 at 1:19 PM
    And1
    And1 New Member
    Andy
    2019 Silver tundra TRD
    Ok, so I am having the same issue. I am not sure if I should go with a rough country/ ready lift 6" or 8" or BDS 8"? Some people down here in south Florida tell me that R/C and ready lift are not as good as BDS? Being new to installing it on my own ride I am not sure what to go with. My 2012 GMC 1500 had a 6' pro comp and I loved it. never had any issues. I don't mud my ride, just use it for towing, going to the mountains in NC and when I go up north to NY/NJ
  12. Dec 7, 2019 at 1:34 PM
    HighOctane
    HighOctane New Member
    SFV
    2019 White Tundra
    D5339928-0090-4BB5-8C88-B1305C9B6C95.jpg 6” lift on 20x12 -44 wheels
  13. Dec 7, 2019 at 2:11 PM
    And1
    And1 New Member
    Andy
    What lift kit do you have?
  14. Dec 7, 2019 at 2:12 PM
    And1
    And1 New Member
    Andy
    Truck looks sweet man. Back ground looks amazing.
  15. Dec 7, 2019 at 6:45 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    He has a PROCOMP if your talking about member HighOctane
    HighOctane likes this.
  16. Dec 7, 2019 at 6:49 PM
    And1
    And1 New Member
    Andy
    . So can someone tell me the big diffrence between a PROCOMP AND BDS
  17. Dec 7, 2019 at 7:28 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    I think BDS have a life time warranty. But I am sure someone with more information on this will chime in. I was told a bracket lift is a lift. Unless you go off roading.
  18. Dec 7, 2019 at 9:31 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Tag, i want to see pics, lots of pics.
  19. Dec 7, 2019 at 9:50 PM
    #49
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    The -19 offset is in mm... it is roughly 3/4".
  20. Dec 7, 2019 at 9:53 PM
    #50
    realtorblake
    -25mm is roughly 1"... if that helps.
  21. Dec 8, 2019 at 12:17 AM
    #51
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    Negative ghost rider
  22. Dec 8, 2019 at 8:38 AM
    #52
    DexterL
    DexterL New Member
    One mans opinion, going based off what looks best to me
    Iowa12tundra[QUOTED] likes this.
  23. Feb 8, 2020 at 8:31 PM
    #53
    Mnorris1206
    08 tundra
    Curious what tire size are you running? O and they are bfg correct? And would you have any pics or info did you have to do a bmc for this set up ?
  24. Feb 9, 2020 at 4:44 AM
    #54
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I loved my white tundra I lifted. Only aggravating thing was cleaning off the rail dust/rust spots every year.
    Mnorris1206 likes this.
  25. Feb 9, 2020 at 7:29 AM
    #55
    CDB
    CDB [OP] New Member
    Here are a couple pics of the final build. It looks really good and it rides like shit. Stiff, stiff, stiff, I feel everything on the road. I also have a vibration / shudder in the drivetrain at 9-12 mph. The info I got on this forum leads me to the carrier bearing spacer being too small. Currently the spacer is .50", I have purchased the 1.25" spacer kit but I haven't installed it yet, I hope it fixes the vib20200103_144159.jpg 20200103_154119.jpg 20200103_154135.jpg
    k0diak8o8 and DM 2018 Tundra like this.
  26. Feb 9, 2020 at 7:33 AM
    #56
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    .50” is only good up to 3” right?
  27. Feb 9, 2020 at 7:46 AM
    #57
    CDB
    CDB [OP] New Member
    That is the way it was explained to me. 3" to 5" rear lift requires a 1.25" drop down spacer. Still not 100% confident it will fix the problem though
