This truck can't handle 285/70/17
Discussion in '1st Gen Tundras (2000-2006)' started by toyoboyo, Aug 2, 2019.
  1. Aug 2, 2019 at 7:23 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I don't pay attention to my mpg much but it's around 14 with mixed driving daily on my 06 with 315 70 17 and stock 4.10 gears. I expect that regearing to 4.56 or 4.88 would get me up 1 mpg or more and make it more fun too. My suspension doesn't seem to wear too bad and I'm only running(or was only running because I'm not running anything now) 2" lift spacers up front and a 1" diff drop.
    Honestly for a small half ton truck I'm impressed with what my tundra has done. My old Titan had more power and would have pushed 35s better, but mpg was 13.5 mixed with 33s on 22s. So it wasn't exactly an economy vehicle either.
  2. Aug 3, 2019 at 6:13 AM
    Professional Hand Model
    Hand Protectors
    Sure did. An admitted non expert.
    Lets do a regrouping of this thread.
    1) The OP thread title says the ‘truck can’t handle 285/70/r17’ which you and our ‘in house expert’ says is the equivalent size to my 285/75/r16 (within .10”). My truck is proof that ‘diameter’ tire can be handled. After all, my tire is slightly bigger? This truck is on its 5th set of 285 tires.
    2) Now go back and read my intro post #5 response. Absorb it. Nothing will change what I said. Its an opinion based on years of experience.
    3) In my #5 post response, it was suggested to skip the spacers which you later say “99% of the time you do not recommend”. I agree with you here 100%. You simply did not understand the 1.25” minimum, tried to walk it back with mumbo jumbo, and then turned into the ‘spelling police’ where you forgot to add a period at the end of your sentence.
    4) People commenting on wheels without telling us the year of their trucks in relation to the OP.
    Back on topic: Maybe Toyoboyo can shoot us some pics of his set up?
    Give us a little service history?
    Deslock23 likes this.
  3. Aug 3, 2019 at 2:34 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    for everyone's reference, I compared 3 different tire sizes for their weights and measurements. My tire choice was the staple BFG KO2 all terrain E rated.
    Size 1 - 265/75/16 (+1): 53lbs, 31.6" diameter, Sect. width of 10.5"
    Size 2 - 285/75/16: 59lbs, 32.8" diameter, Sect. Width of 11.2"
    Size 3 - 285/70/17:58lbs, 32.7" diameter, Sect width of 11.3"
    As you can see, the specs of a 285/75/16 and a 285/70/17 are almost identical. Hopefully this clears some things up for people.
  4. Aug 4, 2019 at 8:06 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    My understanding is that the 5100s shouldn't be put to the top notch with stock UCAs and without a diff drop kit. Could be wrong though. I'm running 2-3" spacer lift up front and everything seems to be just fine (it's been there a LONG time too. PO installed).
    OR18TRD[QUOTED] likes this.
  5. Aug 4, 2019 at 2:20 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
  6. Aug 4, 2019 at 7:42 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    You only doing city driving? I get 15 hwy in my 05 tundra with 33.5s
  7. Aug 7, 2019 at 5:49 AM
    andrew8404
    andrew8404 New Member
    Andrew
    I went with the 255/80 17 Nitto Ridge Grapplers and haven’t noticed much drop in MPG or power loss. I think this tire is the sweet spot. Haven’t needed any trimming either. So far really happy with this set up.
  8. Aug 13, 2019 at 10:22 PM
    Cajunman007
    Cajunman007 New Member
    Shane
    Lafayette, LA
    02 Tundra Access Cab 4x4 4.7
    I have 285/70/17's on mine also, and 5100's are on the 3rd notch. It rubs a little on the inside when turned hard. Which notch should they be on? I don't have a lift, just an extra spring in the back. I get about 14 mpg on the road.
  9. Aug 19, 2019 at 9:50 PM
    marovn
    marovn New Member
    nick
    Cajunman. do you happen to exactly where your tires make contact when you turn hard?
  10. Aug 19, 2019 at 10:58 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    This thread is all over the place so I will pretend I haven’t read anything after your first post.
    First and foremost we need more info about what exactly is wearing out. Bushings? Ball joints? What?
    MPG.
    Your tires have a 7% difference in size than the Oe 265/70/16.
    When you refill and check mpg multiply your miles X .07. Add that back to your miles. For instance your odo indicates 200 miles between your fillup. 200x.07 =14 so you’ve actually traveled 214 miles.
    A 285/70/17 is not over the limits of what your trucks suspension can handle.
    I wheeled my 99 Tacoma (same front suspension components as your Sequioa) for 4 years on 35’s with little failure (aside from breaking a CV every time I went wheelin, but that’s a whole nother issue).
    This is what I would recommend.
    Remove the wheel spacers. They are adding extra leverage by moving the tire and wheel so far out. 1.25 isn’t extreme but again, this is what I would recommend.
    Second. Your front end only has a couple other wear components. Lower control arm bushings, lower ball joints, tie rods (inner and outer) and rack and pinion bushings.
    Without any knowledge of your service history I would start by replacing all of those 5 things.
    History tells us that you would be better off buying a new set of LCA’s because the bushings aren’t easily replaceable. I would go straight to toyota for the LCA’s, BJ’s and TRE’s.
    You can find low cost OEM parts from places like cool springs Toyota or toyotapartsales dot com.
    For steering rack bushings energy suspension makes a poly urethane set. Can’t go wrong there.
    Okay, after all the wear items are replaced... it sounds like you may be lifted way too high but I can’t say without seeing it. I thought the highest setting on the 5100’s was a no go.
    When we lift our trucks with adjustable coil overs all that does is move the suspension to a static location that is closer to full droop. We have roughly 6.5” full suspension movement. The ball joints are the limiting factor for droop (down travel).
    A lot of the times some of these lifts actually put your suspension very close to full droop. This will tear up ball joints in a hurry.
    Imagine the ball joint like your knee cap. It can only go so far in either direction and you’re gonna mess things up if you try and force it past.
    I’m just some dude on the internet so feel free to take what I say with a grain of salt. However that’s where I would start if I was in your shoes.
    shifty` and Darkness like this.
  11. Aug 20, 2019 at 1:55 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    As an FYI, 17” wheels were one of the stock sizes available on 1st gen Tundras and Sequoias.
    If the 285/70/17 tires are BFG, recommended rim width is 7.5” - 9”.
    Those SEMA rims are 7” wide.
  12. Aug 24, 2019 at 12:33 PM
    Hand Protectors
    Its been a few weeks. Are you pregnant?
    Darkness and bmf4069 like this.
  13. Oct 9, 2019 at 3:46 PM
    toyoboyo
    toyoboyo [OP] New Member
    Mega Bump! So sorry guys, been really busy. Anyway, here are some photos of my truck...
    Truck:
    2005 TOYOTA SEQUOIA, 2WD (NO 4WD)
    Wheels/Tires:
    17x7 4Runner TRD PRO, 285/70/17 BFG K02
    Spidertrax 1.25 wheel spacers
    Suspension:
    Bilstein 5100 All around, OME 862 springs on the rear with firestone coil-rite air bags (completely deflated).
    Polyurethane bushings on steering rack.
    All products were purchased from suggestions of Tundra Solutions forum (1st gen sequoia section). That forum is way too slow for any feedback.
    Goals:
    This is a beater truck, wanted to make it look as little "Soccer Mommy" as possible. Every time I see this car on the road it's a beat up jalopy driven by a Mexican mom or it's in mint condition driven by an elderly person.
    Willing to add a rear locker and re-gearing if possible. Please suggest!
    Symptoms:
    Both front wheels rub on full lock and even less at times.. If there's a heavy load in the back of the vehicle, it stops rubbing.
    Alignment and steering wheel way off and misaligned.. Steering wheel off axis to the right and it's all over the road sometimes. If I correct the steering wheel axis to dead center, the truck pulls hard left.
    Clunking from the front, most likely lower bushings.... In the photos, is my upper control arm bushing leaking? They are nearly brand new SPC arms.
    Transmission doesn't like to shift into 5th and constantly seeks gears. Cursing at 45-50mph it will stay locked in 4th gear which crushes MPG's.. I have to set it on cruise control for it to shift into 5th then cancel cruise.
    Sorry for bold letters and if it seems like I'm yelling. Just wanted to make this stand out in between the debates.. I am welcoming all posts and answers and actually enjoy reading your opinions.. Can anyone recommend a shop in Phoenix AZ? 4wheelparts any good?
    20191009_151644[1].jpg 20191009_151652[1].jpg 20191009_151707[1].jpg 20191009_151747[1].jpg 20191009_151756[1].jpg 20191009_151808[1].jpg 20191009_151810[1].jpg 20191009_151827[1].jpg
    Darkness likes this.
  14. Oct 9, 2019 at 3:55 PM
    toyoboyo
    I'd also like to add that it has some beefier sway bar end links from a shop here in AZ. Forgot the name.
    Hi06silver likes this.
  15. Oct 9, 2019 at 4:17 PM
    SoCalPaul
    Paul
    It looks like you have SPC Upper Control Arms, so you should be able to get your alignment correct. I'd try a different alignment shop.
    2wd should be able to use the top setting on front if you have stock springs. I'd remove the wheel spacers in front & see if you have clearance issues.
  16. Oct 9, 2019 at 4:19 PM
    toyoboyo
    Wouldn't removing the spacers sink in the wheels/tires more which would cause even more severe rubbing?
  17. Nov 27, 2020 at 8:32 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    4:10s are stock?
  18. Nov 27, 2020 at 9:42 AM
    Gmillz85
    Gmillz85 Ski Bum Extraordinaire
    greg
    2004 Salsa Red AC 4x4 Pro Edition
    She's a Pro
    Just for reference, I get 11mpg with 33's and an 1100lb slide in camper on steep pass roads in Colorado. Is it just me or does the upper control arm look like it's positioned too far above the top of the shock?
  19. Nov 27, 2020 at 11:39 AM
    #49
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    "4wheelparts any good?"
    A lot of mixed reviews on them, but wanted to mention there is a member on the Taco version of this forum who manages a Orlando, Fl store. He seemed to know his stuff and his store had good reviews, maybe he could point you towards a good one in your area.
    Gmillz85 likes this.
  20. Nov 27, 2020 at 12:39 PM
    #50
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    On some trucks yes.
    4 wheel parts is actually great for getting alignment done. Be ready to pay about $120 but it will be done right. I don't go there for anything else.
  21. Nov 27, 2020 at 2:08 PM
    #51
    Hand Protectors
    I had my front end rebuilt by them and they did a great job at an awesome price compared to many other places/prices I’ve heard thrown around. First time I’d ever gotten a High Dolla Alignment (never heard of one before) and questioned why so much. Well worth having all the compound angles aligned properly. Truck still drives like a dream 2.5 year later.
    Gmillz85 and Darkness[QUOTED] like this.
  22. Nov 27, 2020 at 2:19 PM
    #52
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup, I was used to $50-60 for alignment. The first time I called them for an estimate I think it was $100, I passed and went elsewhere. My tires started showing odd wear by the first rotation so I went to 4 wheel and paid them. Took a few hours but when I got the truck back the specs looked great and the odd wear stopped.
    Last time around I think it was $120, I didn't even flinch at the price.
  23. Nov 27, 2020 at 2:27 PM
    #53
    Hand Protectors
    They charged me $150. The standard alignments were $79 around here which isn’t the complete deal and doesn’t address everything.
  24. Nov 27, 2020 at 2:30 PM
    #54
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Island life comes at a cost. I would pay 150 no problem for it done right.
  25. Nov 27, 2020 at 2:34 PM
    #55
    Hand Protectors
    Yep. The thing was at the time I had no idea there was a top notch alignment and was skeptical of the cost. I could see the front end angles had changed when looking at the front after the work was done. Truck turned better and no more wobbles. Well worth it.
  26. Nov 27, 2020 at 6:34 PM
    #56
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    He has a double cab right? Did those have 4:10s?
  27. Nov 27, 2020 at 7:35 PM
    #57
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The more I think I know about offered gear ratios the more I see that contradicts what I knew. That said, 4.10 seemed to be pretty common with double cabs.
  28. Nov 28, 2020 at 5:38 AM
    #58
    Hand Protectors
    And Sequoias, iirc.
  29. Nov 28, 2020 at 6:40 AM
    #59
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I have read that. How do I confirm what gears I have?
  30. Nov 28, 2020 at 6:59 AM
    #60
    Hand Protectors
    Your Factory Service Manual or Owner Manual.
