The Truck, by OsidePunker
Discussion in '2nd Gen Builds (2007-2013)' started by osidepunker, Jun 1, 2018.
  1. Jun 1, 2018 at 9:37 AM
    osidepunker
    osidepunker [OP] OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    So I have a build thread that I started on another forum back when I bought my truck in 2013. Its pretty long and chronicles my journey from the beginning. Rather than copy and paste, I figured I would just write about where The Truck is now. Its complete. Totally finished. Oh there are a few things I would like to to do, like gears and lockers, but those aren't necessary. Just wishlist stuff. Plus there will always be things that need to be fixed, or improved upon. But I have accomplished my goal of building a fast, capable, reliable, comfortable backcountry RV. If you ever want to roll with me, hit me up! I love talking trucks and I do a trip about once a month on average. I have a great group of friends I go wheeling and camping with and I'm always looking for new trail dogs.
    I’m a punker who grew up in Oceanside CA. I’ve been in the military flight simulation industry for over 20 years and I have an extensive technical background. Since I was very young I have always been fascinated with exploring off the beaten path. My first off road vehicle was an ’88 Cherokee Chief and I drove the piss out of that thing. In the 90’s I moved from CA and spent some years in the Seattle/Tacoma area, Portland, Arkansas, and then finally I was able to relocate back to Southern CA in 2011. When I moved back I quickly remembered that the Southwest corner of the US offers vast opportunities for backcountry exploration. I decided that I needed a proper vehicle for traversing Planet Earth swiftly and in comfort so I could experience as much as I could in the short life we humans have been granted. So I built…
    "The Truck"
    …a 2013 Tundra DC Rock Warrior 5.7L 4x4
    I started this project in 2013 and I called it complete at the beginning of 2018. I had a 5 year plan and I pretty much stuck to the script. The goal was to build a fast and capable RV. Something I could live out of for weeks and be very comfortable. A truck that would allow me to cross large distances off road in half the time it would take a typical jeep. A rig that could tackle very technical terrain and still be ultra-reliable and allow me to safely travel solo.
    The entire suspension has been modified for ultra-fast desert travel as well as providing for increased articulation on technical terrain. The system was built with extreme durability and reliability in mind. It was tuned to provide a strict balance between high speed performance, technical capability, large load hauling capacity, and comfortable street ride. All suspension fabrication and installation was performed by DMZ Fab and Race Prep in Norco CA; utilizing components from Total Chaos Fabrication, Fox Racing Shocks, and Deaver Spring Inc.
    Suspending The Truck up front is a Total Chaos long travel suspension system with bypass hoops, spindle and cam tab gussets, and limit straps. Fox Racing Series 2.5 coilovers with 800 lbs Eibach springs and 2.5 bypasses control dampening. The system is fully cycled and strapped at 16” clean suspension travel and the wheel well is fully cleared to fit 37’s. The wheel alignments specs are custom, in order to provide excellent high speed stability; 6.5 degrees caster, 0.0 camber, and 0.08 toe.
    The rear suspension system is fully cycled and strapped at 17” usable suspension travel. The rear axle has been fully converted to a spring under axle setup with custom spring plates and shock tabs. The leaf spring are custom 3” wide progressive packs from Deaver. They are reverse eye and double military wrapped. DMZ fabricated new front leaf hangers with bash plates to accommodate the wider leafs. A full DOM bed cage with dimple plate and secondary supports was fabricated by DMZ to provide shock mounting and help support the truck frame. I designed a custom one-off electric articulating bed rack for my roof top tent and awning; DMZ performed the fabrication. The articulating rack allows access to the gear in the bed while keeping the weight of the tent low for good handling. The rear half of the frame was also fully boxed by DMZ up to the re-enforced center section under the cab. Fox Racing Series 2.5 16” bypasses and 2.5 3” hydraulic bump stops control dampening.
    TRD Rock Warrior Wheels with 37x12.50x17 Cooper STT Pro tires connect The Truck to the dirt. Two full size spares mounted in the bed provide confidence when I am miles from the nearest help.
    The front bumper was fabricated by DMZ Fab and Race Prep and is a fully welded DOM tube prerunner-style winch bumper. The frame horns are double walled with 1” shackle tabs. A Comeup Seal Gen2 12.5rs winch was mounted. This is a 12.5k winch with synthetic line and a Factor 55 Prolink XXL which accepts a larger 1” stainless steel shackle. I also pack misc recovery and winch gear from ARB. A DMZ custom front skid is made of 1/4” aluminum plate and the rest of the skids were manufactured by Bud Built and are also 1/4” aluminum plate.
    The rear bumper is a fully welded DOM tube high clearance bumper fabricated by DMZ Fab and Race Prep. The frame horns were extended with 3/16” box ends and feature 1” shackles tabs. The center section is double walled DOM tube and secondary supports are gusseted to the frame.
    White Knuckle sliders with .188 DOM outer rail provide side protection.
    Sleeping quarters consist of a very light-weight James Baroud Horizon Vision roof top tent. The mattress was swapped out for an Exped MegaMat Duo 10 LW+. This mattress is extremely comfortable and specs an R value of 9.50 and a temperature rating down to -54.4 °F. An ARB 82 quart fridge keeps the beer cold. I designed and built a custom on demand water system with up to 20 gallons of water storage. A propane hot water heater can be connected for hot showers on the trail. An IBS-DBS dual battery controller separates a pair of house batteries from the main battery. Total system storage is 210 Ah. AC is routed throughout The Truck and is supplied by a Xantrex PROwatt SW 1000 inverter. A NOCO Genius Gen1 battery charger keeps the Odyssey batteries maintained and provides light shore power duties. All electrical work was done by myself and features marine and/or military grade components. The system is fully fused and the winch is isolated when not in use.
    There is a full complement of auxiliary lighting, more than 60k lumens of forward lighting projected by a Baja Designs 40” Hi-Power Onx6 light bar and four Squadron Pro side lights. The rear light bar features an auxiliary brake light, rear clear cubes, and amber dust cubes for visibility. Lighting is switched by an SPOD unit with a switch bank mounted above the rear view mirror and old school rocker switches so I can flip them when the trail gets rough.
    The Truck has multiple systems of on onboard communication including a fully unlocked Kenwood TM-V71A dual band/dual tuner ham radio, Kenwood TH‑K20A VHF handheld radio, two way Garmin Inreach Explorer+ satellite communicator, an emergency ACR ResQLink Plus Personal Locator Beacon and a back up cell phone. Other miscellaneous equipment consists of a dedicated Samsung 10” tablet with Backcountry Pro Navigation, H3R Performance Halogen fire extinguishers, two pairs of TRED Pros traction boards, HiLift 60” jack, full size shovel and axe, full set of tools, and a huge set of balls.
    Here is a small media dump. I have collected so many awesome memories over the years its unreal. I'll also use this thread to post trip pictures and reports.
    Spangler Hills and Trona Pinnacles Sep '18
    Big Bear MTB Trip June '18
    Big Bear Wheeling/Camping trip June '18
    Parker 425 Prerun '19
    Baja June '19
    https://youtu.be/mM6bzFPQTHI
    https://youtu.be/I6G6iG2Dijg
    https://youtu.be/E4Oubkv8aEg
    https://youtu.be/FRJXabbuv9s
    https://youtu.be/0tDTOgEFrG0
    https://youtu.be/Jmkrhh5oTrQ
    https://youtu.be/jaA68U1WvuI
    https://youtu.be/lk9g1NoMqmo
    https://youtu.be/2FKo6Vb_Vog
    https://youtu.be/ZY9XCUmI91s
    https://youtu.be/gxdi_LyPN4I
    https://youtu.be/o6ZXYQqpmyY
    https://youtu.be/YrG5k4IhH5M
    https://youtu.be/3YOfAc0tBbg
    https://youtu.be/z8yHLv1pCjc
    https://youtu.be/3kyWdHgmvNQ
    https://youtu.be/V7TZRHgikAw
    https://youtu.be/kb5mRqgz_xk
    IMG_20171212_064712_210.jpg IMG_20180505_090937_988.jpg IMG_20170920_081857_920.jpg IMG_20171031_104317_473.jpg FB_IMG_1525427130305.jpg IMG959801.jpg FB_IMG_1525427170698.jpg FB_IMG_1525338700508.jpg FB_IMG_1525338788284.jpg IMG_20180504_055621_379.jpg IMG_20180502_094848_595.jpg IMG_20180506_125659_721.jpg FB_IMG_1525338690896.jpg FB_IMG_1507136566103.jpg FB_IMG_1525338659935.jpg IMG_20180507_081301_980.jpg FB_IMG_1525338697042.jpg IMG_20180503_072806_382 (1).jpg FB_IMG_1525338729472.jpg IMG_20171016_083303_707.jpg IMG_1027.jpg IMG_1049.jpg IMG_0968.jpg IMG_0972.jpg IMG_1024.jpg IMG_20170919_085323_225.jpg 20180404_190545.jpg IMG_20180330_205951_823.jpg IMG_20171025_072854_948.jpg Photo Sep 30, 6 12 49 PM.jpg Image uploaded from iOS-20.jpg IMG_20180501_093604_306.jpg IMG_20171030_062407_547.jpg IMG_1057-2.jpg IMG_20170826_094006_548.jpg 20180406_192532.jpg IMG_20180408_154624_290 (1).jpg 20170721_165044.jpg 20170804_173716-EFFECTS.jpg 20180404_183042.jpg IMG_20180405_102201_266.jpg 20180407_153532.jpg 20180405_174602.jpg 20180427_152813.jpg 20170804_173710.jpg 20170914_163905-EFFECTS.jpg 20180404_183237.jpg 20171105_122215.jpg IMG_20180508_101019_831.jpg 20180404_165420.jpg 20180404_165337.jpg 20171209_154044.jpg 20171209_152435.jpg 20180404_165357.jpg 20180406_174906.jpg IMG_20180219_094304_492.jpg 20171209_124930-EFFECTS.jpg 20180404_165408.jpg Image uploaded from iOS-4.jpg 20180407_154205.jpg IMG_20170629_090513_511.jpg Image uploaded from iOS-2.jpg Image uploaded from iOS-3.jpg 20170804_152343.jpg Image uploaded from iOS-10.jpg 20170929_160615.jpg Image uploaded from iOS-9.jpg 20170804_152331.jpg Image uploaded from iOS-25.jpg
  2. Jun 1, 2018 at 9:41 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    one hell of a post. glad to have you on here so we can all bug the shit about your setup. ;)
    GODZILLA, Lake.Life24, blue16 and 5 others like this.
  3. Jun 1, 2018 at 9:49 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nice!! Loving the media dump!
    GODZILLA and osidepunker[OP] like this.
  4. Jun 1, 2018 at 9:49 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'll talk trucks all day lol trust me, its not buggin me
  5. Jun 1, 2018 at 9:50 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    thanks! It was supposed to be a bunch of thumbnails, but for some reason it keeps puking full size pictures lol
    GODZILLA and Law323[QUOTED] like this.
  6. Jun 1, 2018 at 9:54 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Glad you moved stuff over here, it’s an absolute bitch to look at on “the other Tundra site which shall not be named” :rofl:
    Also, that’s one hell of a ride man! It’s cool to see guys using their rides to the fullest, especially for those of us that don’t.
  7. Jun 1, 2018 at 10:01 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Sweet pics and vids!
    osidepunker[OP] likes this.
  8. Jun 1, 2018 at 10:04 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Ain’t complaining brother! I prefer full size! LOL
  9. Jun 1, 2018 at 10:05 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thanks homie! Yeah that site is pretty dead too lol
    thanks! those were just the recent ones lol
    zcarpenter92[QUOTED] likes this.
  10. Jun 1, 2018 at 10:09 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    4x4_Angel and osidepunker[OP] like this.
  11. Jun 1, 2018 at 10:10 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    thanks! Awesome lights btw! The 40" hipower is almost too bright lol I had to change the lenses to reduce the spot and increase the wide
    Baja Designs[QUOTED] likes this.
  12. Jun 1, 2018 at 10:28 AM
    TheBeast The Beach
    very nice ! love it.
  13. Jun 1, 2018 at 10:30 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thanks mang! Let go wheeling!
    TheBeast[QUOTED] likes this.
  14. Jun 1, 2018 at 10:41 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  15. Jun 1, 2018 at 11:08 AM
    Great vids n pics!!!!
  16. Jun 1, 2018 at 11:13 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    thanks dude!
  17. Jun 1, 2018 at 11:18 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Nice build and photos Alex, look forward for the Big Bear trip.
  18. Jun 1, 2018 at 11:20 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Very cool. I have always been a fan of your truck.
    UNTMatt and osidepunker[OP] like this.
  19. Jun 1, 2018 at 11:27 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thanks man! It's been a long journey and a lot of work
    Yeah buddy! We'll get to meet in person soon!
  20. Jun 1, 2018 at 11:56 AM
    Notachickmagnet
    Notachickmagnet New Member
  21. Jun 1, 2018 at 12:00 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thanks yo!
  22. Jun 1, 2018 at 12:24 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’ve enjoyed watching your build and posts on both forums. Great looking rig, i really appreciate the thought that went into it as well as your follow through with ideas. Many folks can dream shit up, but “talking ain’t walking”!
    How did you get into this situation?
    osidepunker[OP] and 4x4_Angel like this.
  23. Jun 1, 2018 at 12:37 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Cinders is a great spot! Went there last winter in my pro. Know of any good spots close to PHX area? specifically the west valley.
  24. Jun 1, 2018 at 1:40 PM
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Awesome Alex !!! Every time I see pics and vids of your truck my bank account goes down lol
  25. Jun 1, 2018 at 3:21 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    your truck is so bad ass because it can tell so many stories. i am so impressed because every mod you made served a purpose. thanks for the great read man!
  26. Jun 1, 2018 at 4:21 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    You are an inspiration to all of us. Thanks for sharing all your great photos and videos. Peace. D
  27. Jun 1, 2018 at 4:40 PM
    Vizsla
    Vizsla pretend2send
    Truck is awesome. Got to watch in person at cinders, I had no idea. Watching the rear suspension, holy crap!
    osidepunker[OP], 831Tun and 4x4_Angel like this.
  28. Jun 1, 2018 at 5:00 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Sadly this is me for now.... but i have goals and one day I'll reach them! :D
    Alex....BA build! When i grow up i wanna be like you!
  29. Jun 1, 2018 at 5:33 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Cool as truck bro... nice pictures
  30. Jun 1, 2018 at 5:52 PM
    Nice thread Alex!!
    Hell of a job on the video editing.
    Total @waistband
    osidepunker[OP], 831Tun and boardude like this.
