The Truck, by OsidePunker
Discussion in '2nd Gen Builds (2007-2013)' started by osidepunker, Jun 1, 2018.
  1. Dec 9, 2018 at 9:54 AM
    #121
    osidepunker
    osidepunker [OP] OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    sry, I bought off some random shop on instagram, I dont remember who.
    But they are Energy Suspension bushings. Try looking on their website or calling them
    SoCal619, TheGibbster and 831Tun like this.
  2. Dec 9, 2018 at 10:09 AM
    #122
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
  3. Dec 9, 2018 at 10:42 AM
    #123
    TheGibbster
    TheGibbster Kumite Express leaves in five minutes
    SF Bay
    Energy Suspension Bushings are definitely good stuff. I put them on my dads old Tacoma a couple years ago, and like you said, they really helped stiffen the steering back up.
  4. Dec 9, 2018 at 11:10 AM
    #124
    Vizsla
    Vizsla ☠️☠️☠️
    Nice! Thought Bruce @papasmurf had Delrin bushings made?, was wondering if they are too hard for the application. What do both of you think about changing them without pulling the rack?
  5. Dec 9, 2018 at 11:41 AM
    #125
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    @papasmurf @osidepunker if you didn't need to make the repairs to the crossmember would the bushing replacement have been possible without pulling the steering rack completely out?
  6. Dec 10, 2018 at 5:47 AM
    #126
    osidepunker
    Alex
    2013 Tundra DC 4x4
    No.
    The instructions that Energy supplies with the bushings say that you can do it with the rack in place. I wouldn't wish that on my worst ex girlfriend. The stock bushings are pressed in metal sleeves, two halves. There is an inner metal sleeve for the bolt and an outer metal sleeve thats pressed in to the rack housing. I had to pound on the lip of the outer sleeve with a chisel for about an hour just to lift the lip away from the housing on one side without damaging the rack housing. Then we had to weld a rod to the inner metal sleeve so we could pound the rubber inner bushing out. Then we carefully hammered and molded one side of the outer metal sleeve in until there was a nice half face so we could pound it out from the other side. Then we were able to use a socket to pound out the other half of the bushing. total time was two hours just to remove the bushings and I don't see anyway to make it go faster.
    Now, the instructions say to use a pickle fork. We had one, but too small. But even if you were to use a pickle fork you still have to get the lip of the sleeve separated from the housing and there is no way you're going to be able to do that while the rack is on the truck.
  7. Dec 10, 2018 at 5:48 AM
    #127
    osidepunker
    Alex
    2013 Tundra DC 4x4
    He had delrin on a previous rack and the dealer has since replaced a rack and left the stock bushings on
    papasmurf and joonbug like this.
  8. Dec 10, 2018 at 11:49 AM
    #128
    n2deep
    n2deep Pavement Princess
    I think @Spvrtan did it without pulling the rack by himself.
    Rica25 likes this.
  9. Dec 12, 2018 at 12:11 AM
    #129
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Yea, I did mine while the rack was on the truck. It's doable but definitely a bit more annoying than taking out the whole rack and doing the swap on a table with space ..however, taking the rack out completely is also more work in itself. So I suggest leaving the rack in place and dealing with the tight workspace.
    As for the upgrade itself.. I also HIGHLY recommend to anyone that actually offroads their truck to do it. The rubber bushings wear out easy. I'd venture a guess that my bushings started going bad around 50k miles on the truck and I could hear the squeaking/popping and the steering was a little loose. I went to polyurethane around 75k and the squeaks/pops are gone and the steering feels amazingly tight.
  10. Jan 4, 2019 at 4:44 AM
    #130
    osidepunker
    Alex
    2013 Tundra DC 4x4
    UPDATE:
    December was a little busy for me so I haven't really touched The Truck. But yesterday I had the steering wheel clocked and got the toe adjusted. Drives great now and I can definitely feel the tighter bushings on the freeway. When Bruce and I were down there last month we found a small crack on the cross member by the drivers front mount for the front differential. I put it off for anther day. However, when the alignment shop was down there yesterday they found the drivers rear mount for the front diff is also cracked. Basically the mount that hangs off the frame for the diff is cracked almost all the way around and about to fall off.
    fml
    So I'll need to pull the diff and get these cracks welded. Oh and I also found my bed cage in the rear is cracked on both sides where the RTT rack is welded to the cage. So I have to get those fixed and reinforced as well. Hopefully everything should be glued together before the Parker prerun on the 18th
    and the lesson is that I hope you guys are putting your eyes on your truck on a regular basis. I am always inspecting The Truck, but even I miss sht.
  11. Jan 4, 2019 at 5:32 AM
    #131
    Aurora CO
    That's great advice Alex. You really put your Tundra to the test for sure. Great thread!
    TheBeast and osidepunker[OP] like this.
  12. Jan 5, 2019 at 6:43 AM
    #132
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Damn Alex it sucks about all the issues that have come up but glad you saw the cracks before it became an issue out on the trail.
    The issues suck but honestly I’m not all that surprised because I’ve wheeled with you and have rode shotgun so... hahaha
  13. Jan 8, 2019 at 2:42 AM
    #133
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    It's a sign Alex for you to do your gears while your front diff is out.
    Ace402, papasmurf, 831Tun and 3 others like this.
  14. Jan 11, 2019 at 2:02 PM
    #134
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Git er Done Alex!!
    :thumbsup:
    osidepunker[OP] and 831Tun like this.
  15. Jan 11, 2019 at 2:40 PM
    #135
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yep Alex, Bruce told me "all the cool kids are doin' it." That was all I needed to hear. She's off to the shop Wed. for 5.29s and rear locker.
  16. Jan 12, 2019 at 11:39 AM
    #136
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Nice! I really want gears and lockers, but after 5 years of spending big money on The Truck, I'm done. I need to concentrate on other things in life now like my house haha
    Besides, I've never been stopped on the trail because I didn't have lockers. There's always a way to get through. They would help for sure, but its more of a want then a need for me. I'll get them one day maybe
    831Tun[QUOTED], papasmurf and Sunnier like this.
  17. Jan 23, 2019 at 6:32 AM
    #137
    osidepunker
    Alex
    2013 Tundra DC 4x4
    So I got all the cracks glued together. All in all it wasn't that expensive. I still can't figure out my damn VSC. Its super sensitive even after doing the Zero Point Calibration. I have to turn it off because its basically useless. See this thread: Vehicle Skid Control (VSC) Extremely Sensitive (Advanced Troubleshooting)
    I missed posting a couple trips from last year, Anza, Joshua Tree, and the Turkey run. But I'm kinda internet lazy nowadays haha. Here are some pics/vids from last weekend Parker Prerun:
    https://youtu.be/b3GTVl-gi0E
    https://youtu.be/O1ZfHYvHh0s
    IMG_20190122_080503_492.jpg 20190118_093842.jpg 20190120_140322.jpg 20190119_160235.jpg 20190119_175102.jpg 20190120_185359.jpg 20190119_174614.jpg 20190119_180805.jpg 20190119_133255.jpg 20190118_152309.jpg IMG_20190120_143734_706.jpg
  18. Jan 23, 2019 at 6:40 AM
    #138
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    Nice Alex ! Thanks for sharing
  19. Jan 23, 2019 at 8:09 AM
    #139
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Your truck is just amazing dude. Tim does do great work. Makes me miss my old pre-runner!
    papasmurf and osidepunker[OP] like this.
  20. Jan 30, 2019 at 4:31 PM
    #140
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  21. Apr 24, 2019 at 5:33 AM
    #141
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Well call me a sucker, but I have a set of REM polished nitro 4.88 and ARB rear locker sitting in my garage waiting on installation LOL
    The Truck is currently at the shop getting surgery. Should be done this week. Then I have some wiring and airline plumbing to do, then gears/locker installation.
    Also, I'm working with Bud at Budbuilt on some replacement skids. The ones I have are 1/4" aluminum. They've held up pretty good, but after 4 years of bashing they're pretty bent up. Bud is going to make me a set of 1/4" steel with some additional custom ribs for support. Then I'm going to figure out a way to guard my forward LCA cam mounts. They're pretty bent up from rocks so I have to do something about that.
    My goal this summer is to clear John Bull with minimal damage haha @Spvrtan you wanna run it with me??
    Sunnier, dragos28, BestGen and 4 others like this.
  22. Apr 24, 2019 at 7:24 AM
    #142
    Spvrtan
    Kris
    San Diego, CA
    Someone say John Bull!? Let's plan it!
    I'm building belly sliders to replace the skids I took off but I had BudBuilt 3/16" stainless steel transfer case and gas tank skids. They got some good gouges but never has either skid bent or warped even after dropping on them a few times in Johnson Valley and Corral Canyon. 1/4" steel is overkill and if you're going to spend the cash on the thicker steel, might as well get the slightly thinner but stainless steel version.
    Just my .02 cents.
    osidepunker[OP] likes this.
  23. Apr 24, 2019 at 7:30 AM
    #143
    osidepunker
    Alex
    2013 Tundra DC 4x4
    We'll like I said, I bent the shit out of my 1/4 aluminum. Don't forget I weigh a little over 8000 lbs, 4100 lbs on the front axle. On paper, 3/16 steel isn't much stronger than 1/4 aluminum. I'm ok with overkill. A lot of stuff on my truck is overkill. These skids will also have additional ribbing as well. I think they'll only add about 100-150lbs of weight which I'm ok with since I've dropped some weight in other areas. Hopefully they'll be the last skids I buy.
    I'm definitively ready to plan John Bull! I should have the skids in 2 months, so either June or July
    papasmurf and BestGen like this.
  24. Apr 24, 2019 at 10:33 AM
    #144
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    Nice, not too many tundras doing JB
  25. Apr 24, 2019 at 10:43 AM
    #145
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I made it all the way up the gatekeeper last year. But then I had to turn around because I was by myself LOL
    Sunnier and ColoradoTJ like this.
  26. May 3, 2019 at 4:56 AM
    #146
    osidepunker
    Alex
    2013 Tundra DC 4x4
    The Truck is rolling again!!
    Next week I'm installing gears and locker so this weekend I have to get the air lines plumbed and the wiring run. Then I have a fckn laundry list of items that I need to inspect/repair before Baja next month. And I have to do all this with a broken wing fml Thats ok, I'm excited to finally get my hands on The Truck. Especially since I missed T2S.
    Upgrades in the next month or two include another shock revalve (I'm gonna put the rate plates and flutter stacks back in the bypasses) and new skid plates. I'm also chewing over ideas to armor up my front LCA cam bolts. I have some minor things in the works, like mounting a spare CV axle assembly somewhere, re-arranging my cab switches, and shifting some gear weight around. The skids are gonna add weight to the front of The Truck so I want to shift some weight to the rear so I can keep my 50/50 weight distribution.
    Mentally I'm in a different place now. I need to change my attitude about how hard I go in life. It doesn't matter what I do, work, girls, MTB, off road, I seem to GO HARD at everything. 110% all. the. time. So when it come to girls, I end up single. At work I end up alienating coworkers (I just can't help being a badass haha). Off road I end up breaking The Truck. aaannnd MTB I end up doing this:
    This is my second collar bone plate. Now I have matching hardware in both sides. I'm not a cat so I don't have 9 lives, but I've definitely used up two of them. 6 years ago it was broken clavicle and broken neck (C7). That took a year to heal. This time around it was concussion (with amnesia), broken clavicle, and broken/separated ribs.
    Two years ago I went head on with a Chevy on the trail. A couple months ago I flopped The Truck on its side.
    So I'm putting this out here publicly. I am going to SLOW DOWN. Seriously. Wellll, I'm going to make a conscious effort to slow down haha I need to stop and smell the roses. The adrenaline rushes just aren't worth it anymore. I'm still gonna do what I love, I'm just going to take it down a notch.
    Anyways, thats just a little insight into my mind at the moment. Stay tuned. Baja next month, then Big Bear, then Mammoth, then Sequoia, then North Rim, then back to Baja, then Moab, then Death Valley, then Oregon. I have most of the year mapped out and the Truck is gonna be ready to go...
    ColoradoTJ, Ace402, TheBeast and 10 others like this.
  27. May 3, 2019 at 5:14 AM
    #147
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    "A" notch, we're here for you brother. Truck looks good I don't think I have ever seen a picture of it that clean.
  28. May 3, 2019 at 5:18 AM
    #148
    osidepunker
    Alex
    2013 Tundra DC 4x4
    haha thats the good side. You should see the other side...
    Hey man I can't wait for you to get that truck out here and go wheeling with us! We're planning a week long trip in Baja for October. Camping the beaches every night, exploring the missions, and eating fish tacos! Oh and a class 5 truck is gonna guide us through all the GOFAST trails...
    papasmurf likes this.
  29. May 3, 2019 at 5:29 AM
    #149
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    Definitely in for Baja, that's always been my dream trip. Working on getting it out there this summer and do some final tweaking.
  30. May 3, 2019 at 5:30 AM
    #150
    osidepunker
    Alex
    2013 Tundra DC 4x4
    keep me posted homie
