Tell me about your lift kits
Discussion in '1st Gen Tundras (2000-2006)' started by Beefnbread, Apr 24, 2021.
  1. May 5, 2021 at 2:17 PM
    #61
    TundraDude42
    TundraDude42 New Member
    2011 Red Tundra SR5
    3.5” Rough Country Lift, it’s solid as a rock and will last year for quite a long time. They back it with a lifetime warranty and the price is around $800 w/ rear N3 shocks and coil overs for the front.
  2. May 5, 2021 at 6:16 PM
    #62
    Campshaine
    Campshaine New Member
    Do you have to do anything to the leaf springs for that lift kit? I've been looking at that.
  3. May 17, 2021 at 4:57 PM
    #63
    Finnbear
    Finnbear New Member
    Leslie
    Did you have to upgrade the needle bearings for your CV's? Do you drive regularly on the highway? Any issues with vibrations?
    I really like your setup. Really like it, that is why I am curious.
  4. May 18, 2021 at 7:37 PM
    #64
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    Nope I didn’t. I will if i have issues. Yep all the time. It’s my daily. No issues.
  5. May 20, 2021 at 6:56 PM
    #65
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    I have a little questionably-useful experience:
    I have a 2003 access cab. I put 5100s on 2 years and 25,000 miles ago. Since the official word is "don't go above the 3rd notch" and the unofficial word is "don't tell me what to do" I split the difference and put it on the 4th notch. IIRC I got about 1 5/8in lift.
    It worked, and at least for a while I was happy. Oh, and originally I dropped the diff, and that was not good. Got weird pulsating vibrations around 45mph, etc. Investigated, was told with such a modest lift it shouldn't be necessary, so I removed the drop kit and sold it on craigslist.
    I am currently less happy, but I can't say for certain it is because of the 4th notch, or if it is because of myriad other possible issues.
    A local mechanic suggested lowering it back to the 3rd notch and adding a small spacer (1/2 inch) to make up the lift difference, and I would be happier with the ride.
    I'm going to try that, and use the opportunity to inspect the rest of the assembly to see if there are other problems. I'll try to remember to report back when how I feel after lowering it a notch.
    For one thing, my coil isolators look scrunched and cracked, so I'm going to at least replace those.
    QUESTION re coil isolators: Most people I've seen use relatively generic rubber isolators like these, around $12 each. Is there any use in getting fancy polyurethane ones? For a while I thought polyurethane was just better, but lately I've learned this material tends to squeak, and needs to be lubed regularly, and some people really think the rubber is better.
    ANOTHER QUESTION: the Toyota parts site says this about their Strut Mount part:
    "Strut mounts or strut bearings are often service with the strut assembly, and when they fail they can make a squeaking noise while turning or a metallic clunk noise when going over bumps. If your 2003 Toyota is noisier than usual on bumpy roads or under braking, you may need new strut mounts."
    Anyone have experience with that part, and how to tell if it needs to be replaced? I have squeaking AND clunking, and it drives me bonkers. Since they are $120 each, would like to diagnose for sure first.
    My experience isn't harshness, per se, but just a sense that things rattle and...lope too much. Like my truck gallops as it goes over seams in the pavement, or rattles like stuff is loose when off-road. And again, not at all sure this is even related to the Bilsteins and not something else I'm still chasing.
  6. May 21, 2021 at 5:01 AM
    #66
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Does it squeak/groan when you're sitting still and turn the wheel? That would be strut bushings. And if you get the graphite impregnated poly it won't squeak, but I've never seen poly strut mounts.
  7. May 24, 2021 at 4:34 PM
    #67
    NomadicFrog
    Mark
    Flagstaff, Arizona
    I finally remembered to do this, and no, I could not get the squeak to happen when sitting still. I have not been able to find any way to reproduce the squeak, other than it happening constantly while I'm driving.
