Talk me out of 285/70's
Discussion in 'Wheels & Tires' started by Danimal86, May 15, 2023.
  1. May 16, 2023 at 7:29 AM
    PermaFrostTRD
    Northern NY
    I'm pretty sure @Terndrerrr runs 285/75r18 on TRD pro suspension (2" lift) and TRD Pro wheels and only had to remove the front flap.
    285/75 appears to be more readily available than 285/70 if you have a blowout "out of town" etc.
    And the obvious, bigger is always better.
    Tripleconpanna and Moe2o4 like this.
  2. May 16, 2023 at 7:30 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
  3. May 16, 2023 at 8:40 AM
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    The golden rule!
  4. May 16, 2023 at 3:25 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    17A37032-8264-4719-969A-5611FA3C6B7F.jpg I’m on 285/70/18’s. I stayed with this size cause I’m happy with the power and gas mileage.
    PermaFrostTRD and AZBoatHauler like this.
  5. May 16, 2023 at 3:31 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Oh, and this… sometimes you just need that extra 3/4” of sidewall :boink:
  6. May 16, 2023 at 3:34 PM
    AZBoatHauler
    So.Arizona
  7. May 16, 2023 at 3:35 PM
    AZBoatHauler
    So.Arizona
    Everyone knows I just wanted to touch Colton with my electric rope.
    Here is your hot tails pic @memario1214.
    BillyB and TRDFerguson[QUOTED] like this.
  8. May 16, 2023 at 3:37 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I feel like a broken record. Fully OEM setup—UCAs, wheels, suspension (TRD Fox 2” lift up front), bumpers, cab mounts, all of it.
    285/75R18s fit. Just add 2” up front, and remove the little mud flap in front of the front wheel.
    Also, hot take: 285/75s ARE 35s. They’re basically just 35x11.5 for an 18” rim.
    Double also: I do better on mpg than pretty much everyone running 12.5” wide 35s.
  9. May 16, 2023 at 3:47 PM
    AZBoatHauler
    So.Arizona
    I agree with you and planned to run the 285/75 until I saw @TRDFerguson go down this obstacle and all the sudden 12.5” didn’t seem so wide. Still not sure what I’ll end up with - I have about 10k miles to figure it out.
  10. May 16, 2023 at 4:54 PM
    Terndrerrr
    Music City
    6UR-FE
    Is that the top of Hells Gate? You can do that in a bone stock TRD Pro with the factory Michelins. https://www.dailymotion.com/video/x3vgvtx
    I'm not saying you shouldn't do 12.5" wide tires...go with what you like, and post pics!
    For me, the absolute bolt-on workability of the narrower 285/75s is a no-brainer. If I'm gonna cut stuff up, it's going to be for 37s lol
    Tripleconpanna and PermaFrostTRD like this.
  11. May 16, 2023 at 4:57 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’s “the crack” near the Devil’s Staircase at Broken Arrow in Sedona - a stock Pro could probably do it, with the right spotter, but it’d be sketchy.
  12. May 16, 2023 at 6:05 PM
    AZBoatHauler
    So.Arizona
    I’m not sure about a tundra pro but I’ve watched a modded Taco crunch itself falling down the crack.
    TRDFerguson likes this.
  13. May 16, 2023 at 6:10 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I do like a crunchy taco.
    BillyB, Tripleconpanna and Terndrerrr like this.
  14. May 16, 2023 at 8:58 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    ohhh... that would be me right now!!!!
    What do you mean by 'sketchty'??
  15. May 16, 2023 at 10:53 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    285/75r18s are actually taller than 35s (34.8 vs 34.5-34.6)... which are just a couple 10ths taller and wider than 295/70r18s.
    Fond of the fat 35s (325/65r18... 34.6" tall) myself...
  16. May 16, 2023 at 11:31 PM
    AZBoatHauler
    So.Arizona
    A lot of semantics on 35’s - my main distinction for “35s” vs a metric equivalent is for some reason when you get the 35x12.5, you get additional tread depth.
  17. May 17, 2023 at 7:47 AM
    rruff
    rruff New Member
    Which tires? It seems pretty random to me, with small differences.
    Just checked Toyo AT3s in 295/70 (16.6/32), 285/75 (16.5), 35 (16.9), and 325/65 (17.0).
    Looked at Falken AT3W in 285/75 (18.0), 35 (19.0), 325/65 (20.0)
    And Cooper AT3... 295/70 (17.0), 285/75 (17.0), 35 (16.5), 325/65 (16.5)
    Inch measurements not only exaggerate diameter, they exaggerate width also. 35x12.5s are always measured on a 10" wide rim which is rarely used. 8.5" is allowed, and 9" is typical. Usually they will be 12.5" wide (but sometimes less) on a 10", but this drops to ~12.1-12.2" on a 9" rim... basically the same as a 295/70.
    Metric tires seem to be very close to their spec (+ or - 1/10"), using appropriate rim widths. 325/65s are the easily the widest "35" at 13.0" on a 9.5" rim typically, and are the same diameter as 35s at 34.6". 285/75s are the skinniest at 11.2-11.5" on a 8" rim (would be .3-.4" wider on a 9" rim). 295/70 are 11.8-12.0" on a 8.5" rim.
    Typical actual size normalized to a 9" width rim:
    295/70= 34.3 x 12.0
    285/75= 34.8 x 11.7
    35x12.5= 34.6 x 12.1
    325/65= 34.6 x 12.8
    35s are usually higher priced than the others as well. I can't see any reason for that other than marketing to "Mericans" who like measurements in inches, rather than foreign commie metrics.
    It's worth noting that 295/70s and 285/75 are spec'd to fit a 8" wide rim so they can be put on stock Tundra rims, while 35s usually want 8.5" and 325/65 want 9" minimum.
    At any rate, I think it's pretty awesome that we have so many choices in tires around this size... just wish they weren't so damn expensive!
    545moose likes this.
  18. May 17, 2023 at 8:16 AM
    AZBoatHauler
    So.Arizona
    Nitto RGs are what I’ve been running.
  19. May 17, 2023 at 9:24 AM
    #49
    rruff
    rruff New Member
    Those seem to be an outlier, even for Nitto. Checked their Rekon... plus BFG KO2, and Yoko X-AT, Grabber ATX, and Hankook AT2, and they don't show that trend.
  20. May 17, 2023 at 12:17 PM
    #50
    Tripleconpanna
    I think you're missing the boat here...
    You need to throw some Mickey Ts into the discussion, just know they are a big larger (more true to size) than many of the competitors. So, while a 295/70 may work for your setup in a Wildpeak, it probably won't in a Mickey T....
    PermaFrostTRD likes this.
  21. May 17, 2023 at 12:20 PM
    #51
    PermaFrostTRD
    Northern NY
    This was my experience (they were super wide for a 295). They "worked" for me, but they barely cleared ¼" on the UCA with the stock TRD OR wheels. Also rubbed the front sway bar at full lock. Still an awesome tire I think other than their weight.
  22. May 17, 2023 at 12:35 PM
    #52
    rruff
    rruff New Member
