Tailgate open latch.
Discussion in '1st Gen Tundras (2000-2006)' started by MrFeldman, Apr 17, 2024.
  1. Apr 17, 2024 at 2:20 PM
    MrFeldman
    MrFeldman [OP] New Member
    Mr
    ‘05 Tundra Limited Crew Cab
    Upgraded Stereo
    I’ve noticed over the past 6 months or so, that my tailgate latch handle requires two hands to open. Anyone buy an aftermarket unit and install it? I’m a regular user at Partsgeek, and have had good luck with them. Although I discovered a tailgate latch handle with a built in reverse cam, if anyone has used one of those give me a full report.
  2. Apr 17, 2024 at 2:24 PM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    I like my tailgate handle with reverse cam.
    Before my old handle was flopping around and only engaging at the end of its full range of motion. Turns out my rear panel was indented really good and was pressing on the inner arms that go from handle to latches. Hammered it flat and fixed my issue. Turns out I didn't need to replace the handle at all. Happy I did though. I love having a back up camera. If you already have a touch screen, it's a no brainer.
  3. Apr 17, 2024 at 2:28 PM
    MrFeldman
    Mr
    Upgraded Stereo
  4. Apr 17, 2024 at 2:32 PM
    MrFeldman
    Mr
    Upgraded Stereo
    I actually do have an aftermarket Kenwood touchscreen multi app stereo in my truck already, and the license plate frame cam has failed. So you’re implying the “handle with reverse cam” will work with my existing touchscreen? I’ll go for it.
  5. Apr 17, 2024 at 2:32 PM
    shifty` In South Dakota Trouble ain't hard to find
    You may be fucking yourself if you get an aftermarket handle (maybe not the tailgaters handle, that seems to be stout). Your issue likely has nothing to do with the factory handle, and everything to do with the fact you're not doing (or haven't done) any maintenance to the mechanisms at all. You may have broken clips inside the handle assembly because you haven't done maintenance.
    If I were you, I would start here: https://www.tundras.com/threads/how...gate-clip-repair-overhaul-beef-up-lube.94180/
    Take whatever you see inside, check all the plastic bits, make sure everything is working as expected, then lube the shit out of things before re-assembling.
    Thing is, an aftermarket handle probably won't handle two-handed opening. It'll break. At least that's what others have found.
  6. Apr 17, 2024 at 2:48 PM
    this
    shifty`[QUOTED] likes this.
  7. Apr 17, 2024 at 4:14 PM
    GXPaycheck
    GXPaycheck New Member
    Central NC
    I found a thread in the forums that shows what parts to clean, lube, and sand down a bit id necessary. Made a world of difference with mine. Sorry I don't have the link.
  8. Apr 17, 2024 at 5:40 PM
    MrFeldman
    Mr
    Upgraded Stereo
    Thanks, I’ll skim through and track that thread down before I disassemble my tailgate.
  9. Apr 17, 2024 at 5:47 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I bought a tailgate handle from Napa and it was made by Dorman. Works ok but has more flex than the. OEM handle. Yeah it was 1/4th the price but I’d recommend the OEM one.
    shifty` likes this.
  10. Apr 17, 2024 at 5:48 PM
    If the thread I dropped in reply #5 above doesn't strike your fancy, there's another option here.
  11. Apr 17, 2024 at 6:28 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Lubing the tailgate mechanism takes maybe 15 minutes start to finish, and it is like working at the bench, no contortions required. More than 2 fingers to open, maintenance needed, before something breaks.
    JasonC. likes this.
  12. Apr 18, 2024 at 11:02 AM
    Squeakyduck4
    Squeakyduck4 New Member
    Santa Barbara
    06 DC 4x4 V8 TRD
    mine was horrible, barely opened and made a lot of noise, i doused everything with wd-40 and it works great now
  13. Apr 18, 2024 at 6:16 PM
    bfunke
    South Carolina
    WD-40 is not a good lubricant.
    Weagle likes this.
  14. Apr 18, 2024 at 11:43 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Only get an OEM handle, it’s about $120.
    Mine barely opened the tailgate and eventually broke and almost cut my hand opened. Turned out the back side was completely covered with Bed Liner and it was jamming everything up. With the new handle I can open the tailgate with my pinky.
  15. Apr 19, 2024 at 6:13 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Weagle and shifty`[QUOTED] like this.
  16. Apr 19, 2024 at 6:15 PM
    Don't you tread on me, blaksnek
  17. Apr 19, 2024 at 6:16 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
