Homemade Catalytic Converter Anti-Theft Device
Discussion in '2.5 Gen Tundras (2014-2021)' started by TruPatriot, Feb 7, 2022.
  1. Feb 7, 2022 at 1:46 PM
    TruPatriot
    TruPatriot [OP] New Member
    Lee
    Northeast Texas
    2020 TRD Pro MGM Mall Crawler & Trail Riding Queen
    Is there anyone on this forum that has created a cat anti-theft device? I’m thinking of wrapping a cable and securing it somehow and painting the cable with a bright paint. If I can create something myself versus buying someone else’s product, I will.
  2. Feb 7, 2022 at 1:48 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Go to a muffler shop and sometimes they will install a little cage for cheap, but it still wont stop a sawzall blade.
  3. Feb 7, 2022 at 1:51 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The basic plates that knock off the Desert Eagle design are pretty basic and could be made in a garage with basic metalworking tools. I bought one locally because I don’t have any of that cool stuff.
  4. Feb 7, 2022 at 1:57 PM
    Plates are still your best option. Anything homemade on the smaller scale will just allow them to cut it all out and separate it later. With plates, they will most likely move on.
  5. Feb 7, 2022 at 4:55 PM
    TruPatriot
    Lee
    Northeast Texas
    That’s not what I’m looking for. It’s not the money, If I can do something myself that’s as effective if not more, I will. If that can’t be achieved, I’ll buy what works best.
    Ohannon7 likes this.
  6. Feb 7, 2022 at 4:56 PM
    TruPatriot
    Lee
    Northeast Texas
    If I only had a cutting torch & welder…lol.
    Txexplorer23 likes this.
  7. Feb 7, 2022 at 4:59 PM
    TruPatriot
    Lee
    Northeast Texas
    Agreed…The more I think this out, I believe that plates are most likely the best option!
    831Tun likes this.
  8. Feb 7, 2022 at 5:07 PM
    Yes they are honestly. Valhalla has the front and rear.
    DoMoToyota likes this.
  9. Feb 7, 2022 at 5:18 PM
    TruPatriot
    Lee
    Northeast Texas
    Thanks for the tip of Valhalla. Are there any others that cover front and rear like Valhalla that I could compare?
  10. Feb 7, 2022 at 5:26 PM
    Valhalla is the only one that makes front and rear with the steel option, as well as the aluminum. Desert Eagle only makes a front plate. I went with steel as it is harder to cut. Some like aluminum because it is lighter, but it does cost more. These trucks don't even notice the weight addition. Install security bolts to make it even more of a deterrent.
  11. Feb 7, 2022 at 5:55 PM
    TruPatriot
    Lee
    Northeast Texas
    :thumbsup:
  12. Feb 7, 2022 at 5:57 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    several members here have installed the cat security shield by ccm, including myself.
    if time is an issue do your due diligence on product lead times. i chose not to wait 8 weeks. ordered and received my cat security shield in one week.
    https://www.tundras.com/threads/i-went-with-the-ccm-cat-shield.100836/
    https://www.tundras.com/threads/anywhere-i-can-get-cat-protection-in-10-days.100715/
    RCwyoming and Mike59 like this.
  13. Feb 7, 2022 at 6:15 PM
    TruPatriot
    Lee
    Northeast Texas
  14. Feb 7, 2022 at 6:23 PM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    I made a plate that covers the front and rear. Didn’t take really any special tools. I used an angle grinder and a drill to put in vent holes.
    Gravy and Ohannon7 like this.
  15. Feb 7, 2022 at 7:29 PM
    dpirazzi
    dpirazzi New Member
    Dave
    NorCal
    2021 MGM Limited Crew 4wd
    I'm waiting for someone to come up with something small, light, and that attaches directly to the cat and pipes that would significantly slow down a sawzall. Make if difficult enough that the thieves pass and move on to the next vehicle. Because cutting the pipes makes so much noise, these guys are are all about getting in and out quickly.
  16. Feb 7, 2022 at 7:42 PM
    TruPatriot
    Lee
    Northeast Texas
    Cool…can you post some pics?
  17. Feb 7, 2022 at 8:22 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I made mine from a 4x4 sheet of 3/16 steel. Made the cuts with an angle grinder, after I fit it up I saw I needed side shields on it for extra protection, so I welded those on. I kept the plate 4ft long to cover both cats, and the transfer case. It makes it really heavy too, a little over 100lbs, I used a floor jack to get it installed. I haven't drilled or cut out vent holes yet, but my trans temps have been the same, even when towing.
    vtl, Mike59, Patch999 and 8 others like this.
  18. Feb 8, 2022 at 3:55 AM
    TruPatriot
    Lee
    Northeast Texas
    Great job…that some serious armor, almost IED proof!:D Thank you for posting the pics!:thumbsup:
    Sumo91[QUOTED] likes this.
  19. Feb 8, 2022 at 4:09 AM
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
    Dang that's stout
  20. Feb 8, 2022 at 6:19 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    As requested.
    Taironey, kevine0001, Zebruaj and 7 others like this.
  21. Feb 8, 2022 at 10:31 AM
    TruPatriot
    Lee
    Northeast Texas
    Great job…looks professionally made!
    Kbar691[QUOTED] likes this.
  22. Feb 8, 2022 at 4:45 PM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    Thank you!
  23. Feb 8, 2022 at 4:57 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Went with front plate from Desert Eagle , and purchased diamond mesh and bolted up for rear cats. Main reason purchased front was steel plate now would have cost me almost as much as a finished pre-made plate , and the rear mesh ,a pc 52"wide and 18" long fit perfect and bolted up easy,but the mesh still cost me 180.00 . So I still have almost 500.00 for all, but sure feels safer.Went with Desert Eagle because only 3-day wait.IMG-1627.jpg IMG-1626.jpg
  24. Feb 9, 2022 at 4:07 AM
    TruPatriot
    Lee
    Northeast Texas
    I like this and the security bolts you used near the rear of mesh. Didn’t realize diamond mesh was so high!
  25. Feb 9, 2022 at 8:19 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Not really a security bolt , just a grade 8 socket head cap screw, and I put landscape cement around hex bolts on plate. Can't just put socket on , but able to chip off pretty easy if I need to remove them.
  26. Feb 9, 2022 at 8:41 AM
    DoMoToyota
    DoMoToyota New Member
    Donald
    Monroe, Louisiana
    22 Tundra Limited 4x4 CM Black
    RC 1.75" Leveling Kit Cooper Rugged Trek 275/65r20 Pro Grille Diode Dynamics Grille Lightbar Rave OR Amber Grille Marker Lights GoRhino Dominator DSS Extreme step bars UnderCover Ultraflex bed cover
    It’s a win-win, if your truck rolls over you can throw on some burgers and brats
  27. Feb 9, 2022 at 9:54 AM
    TruPatriot
    Lee
    Northeast Texas
    I’ll take a burger, dry, no onions with cheese, please!:D
    DoMoToyota[QUOTED] likes this.
  28. Feb 9, 2022 at 11:06 AM
    DoMoToyota
    Donald
    Monroe, Louisiana
    Boom Life Hack
  29. Feb 14, 2022 at 9:03 PM
    Tundraction
    Tundraction New Member
    Duane
    Minnesota
    2014 SR5 DBL MGM 4x4 5.7
    Phone Charger
    You don't need a cutting torch, just use an angle grinder with a cutoff wheel, and you can get a cheap welder from HF for $150. Teach yourself to weld, snag some cool tools all for less then $200
    I did mine here https://www.tundras.com/threads/home-made-cat-shields.98885/
  30. Feb 14, 2022 at 10:11 PM
    TruPatriot
    Lee
    Northeast Texas
    That’s awesome…I like everything you did!
