Tail light tint ? Anyone tried anything like this? Results?
Discussion in 'Lighting' started by Tundra$, Mar 27, 2019.
  1. Mar 31, 2019 at 3:19 AM
    Bongskie
    Bongskie Mucho LOCO
    2016 Black Crew
    6" Pro Comp Kit, Mayhem 20" rim, Toyo M/Ts
    Followwing. I did try Vvivid
    Following. I bought VViVid smoke but I failed,. Those small two "shark pins" on the taillight giving me a hard time. I ended up removing it an decide to save some money on Winjet smoke tailghts. Still have the stocks and I will wait for the results when you're done. Plspost some pix. Thanks
  2. Mar 31, 2019 at 5:24 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Here’s the original article, it’s not PD, it’s a bad prep and application of VHT-N:
    https://www.gencoupe.com/exterior-2...le-scratches-through-tint.html#/topics/256129
    No ill to those who do it right, it’s just not forgiving if it’s done wrong, you can’t just peel it off, claybar, clean and start again, or leave it be shiny stock again.
    I’d play with the 3rd using any method including VHT, it sits high and is always seen at a reasonable distance, at worst it’s cheap to replace the cover.
    For the tails, I’d get Recons, Winjets, Spyders, or those Amazon ones that look OEM. Anything spray or wrap needs professional application. If it wasn’t for those damn fins I’d be following this like for other vehicles:
  3. Mar 31, 2019 at 11:36 AM
    3rdGenTundraDC
    3rdGenTundraDC New Member
    MGM
    Central Florida
    14 Tundra DC
    305/50/20 Nitto Terra Grappler G2 Stock, stock, stock.
    You're right. Not sure why he used paint tinner which is kryptonite to paint without catalyst.
  4. Mar 31, 2019 at 3:57 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    So after 3 hours and many little pieces of tint I threw in the towel. Those little fins are no joke!
    I am contemplating night shades, but I need to get my motorcycle on the road first. Just so I have a mode of transportation.
    4 light coats followed by 24-48 hours to dry followed by a wet sand, a few coats of clear, drying time, and a final wet sand will have them looking nice.
    I'll need about a month though. Way to much going on right now.
    JoshuaA and Bongskie like this.
  5. Apr 1, 2019 at 12:49 PM
    Bongskie
    Bongskie Mucho LOCO
    2016 Black Crew
    Same here. I gave up.
  6. Apr 2, 2019 at 12:40 PM
    Tundra$
    Tundra$ [OP] White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    did you try a heat gun?
    Mine is on the way.
  7. Apr 2, 2019 at 1:06 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    (did same, swore a lot and gave up, used heat gun too)
  8. Apr 2, 2019 at 1:12 PM
    Joe Dirt
    Joe Dirt New Member
    Don
    Sunriver, Oregun
    Silver 2018 SR5 4X4 DC
    To the future "Darwin Award winners" Nobody will see you and plow right into you.
    I worked at Corcoran State Prison, every year Officers died driving to work in the fog. Tell me you never ever plan on driving in the fog?
    JoshuaA likes this.
  9. Apr 2, 2019 at 1:17 PM
    Tundra$
    Las Vegas
    Don’t really get too foggy here in dry ass 10000 degree Las Vegas
    JoshuaA and flynbyu2 like this.
  10. Apr 2, 2019 at 5:26 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    If you read my post I specifically stated that if light output was bad I would put LEDs in.
    Thank you for what you do though, it's not an easy job.
    JoshuaA likes this.
  11. Apr 2, 2019 at 5:28 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    Sounds about right. I used a heat gun and tried several techniques I found on YouTube. If the fins werent there it would have been pretty easy.
    JoshuaA[QUOTED] likes this.
  12. Apr 2, 2019 at 8:21 PM
    CAM1794
    CAM1794 New Member
    Chad
    2017 MGM 1794
    Went to a local wrap shop today and they quoted me $60 to wrap the tail lights. I got on their list about 2 weeks out.
  13. Apr 2, 2019 at 8:27 PM
    Overwatch91
    Overwatch91 Initial Success or Total Failure!!
    Michael
    East Texas
    2013 White Tundra TSS
    If you get it to dark, some places won't inspect your truck. I had a truck with dark lenses and TXDPS wrote me a ticket...
  14. Apr 2, 2019 at 8:27 PM
    Tundra$
    Las Vegas
    Be interesting to see how much trouble they give the pros
    CAM1794[QUOTED] likes this.
  15. Apr 2, 2019 at 8:46 PM
    CAM1794
    CAM1794 New Member
    Chad
    2017 MGM 1794
    Luckily here in SC there are no vehicle inspections. I also plan on replacing all tail light bulbs with led from Vled. Getting the headlights wrapped as well but they will not be near as dark as the tail lights.
  16. Jan 30, 2020 at 9:16 AM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    So did this ever end up working out??
  17. Apr 30, 2020 at 10:23 PM
    LLHoops
    LLHoops New Member
    2019 black Tundra SR5 4x4
    3-2 lift, rear air bags, AMP steps, Retrax tonneau, 18" HD rims w/ 33" tires, large 3" Bullbar, murdered out - future plan to tint headlights & tail lights, CAI, and aggressive muffler w/ no hwy drone.
    Sounds complicated and not many options in San Antonio, TX. Has anyone tried the AVS tail light covers? How do they look?
