Tail light tint ? Anyone tried anything like this? Results?
Discussion in 'Lighting' started by Tundra$, Mar 27, 2019.
  1. Mar 27, 2019 at 10:58 AM
    Tundra$
    Tundra$ [OP] White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
  2. Mar 27, 2019 at 11:06 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
  3. Mar 27, 2019 at 11:07 AM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    If you reply to this in about 4 hours I will buy some and give it a shot next week if nobody chimes in.
  4. Mar 27, 2019 at 11:07 AM
    Tundra$
    Las Vegas
  5. Mar 27, 2019 at 11:08 AM
    Tundra$
    Las Vegas
    Ok. Remind me in 4 hours lol
  6. Mar 27, 2019 at 11:17 AM
    801Tundra
    UTAH
    Oracal 8300 light/dark gray is widely used in the window tint and vinyl wrap industry. I can vouch for the longevity of the film - on a well maintained, garaged vehicle I've seen it look great 5 years after install.
  7. Mar 27, 2019 at 11:29 AM
    Tundra$
    Las Vegas
    I have a well maintained outdoor driveway vehicle. Wonder how bad sun fades it ?
  8. Mar 27, 2019 at 12:09 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    My only concern is going to be wrapping where that little fin is. I am sure I'll be able to do it, but I better attack there before I open my beers.
    @Tundra$ remind me in 3 hours
    Tundra$[OP] likes this.
  9. Mar 27, 2019 at 12:23 PM
    801Tundra
    UTAH
    Eh.. Sun fade will be minimal. Oracal 8300 is manufactured to withstand the elements.
  10. Mar 27, 2019 at 12:27 PM
    KLLVMDCL
    KLLVMDCL New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
    Like 801 said, Vivvid is the premier film. And the fins on the light arent that big of a problem. Id glass the vinyl in between finned area first with no heat, then heat with no tension over the fins, and then stretch with heat over the rear most section.
  11. Mar 27, 2019 at 4:14 PM
    Tundra$
    Las Vegas
    The time has come
  12. Mar 27, 2019 at 4:18 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    Want me to try the $6 or 13$ stuff?
    @Tundra$
  13. Mar 28, 2019 at 10:01 AM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    Grabbed the $13 dollar stuff. I'll update this thread next week or Sunday.
  14. Mar 28, 2019 at 12:21 PM
    Tundra$
    Las Vegas
    You the man. Sorry didn’t get back. On a road trip
  15. Mar 30, 2019 at 4:15 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    There's a teaser. I may wake up before my kids tomorrow and knock it out.
  16. Mar 30, 2019 at 4:28 PM
    Just curious, you just covering the reverse section?
  17. Mar 30, 2019 at 4:34 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    I plan on doing the whole thing. I'll take some before pictures with the lights and blinkers on tonight. Then I'll compare tomorrow night with the tint on. Or whichever night I do it.
  18. Mar 30, 2019 at 4:36 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I think I would do everything except the reverse light section meaning I would tint all the red section
  19. Mar 30, 2019 at 4:48 PM
    KLLVMDCL
    KLLVMDCL New Member
    Brandon
    Austin, Texas
    Get some knifeless tape if you plan to do that. Itll come out way cleaner
  20. Mar 30, 2019 at 4:48 PM
    Oh ok, there a company called TCT wraps they make exact cut out of reverse light
  21. Mar 30, 2019 at 4:55 PM
    Tundra$
    Las Vegas
    I planned on doing the whole thing as well but if I cut out anything it be the white part. The red is what bothers me. I just don’t want it too dark to where brake lights aren’t visible enough. Might mess around with a few different shades
  22. Mar 30, 2019 at 5:13 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    If I like it and the light output isn't enough it will give me a reason to get LEDs
  23. Mar 30, 2019 at 5:20 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    The tail lights are hard to wrap because of 2 protruding nibs on the side. Whether you do whole or part, up close it'll look DIY.
    These look tinted OEM and are only $126 (someone here has them):
    https://www.amazon.com/dp/B07CFPT6Z...olid=2SAF21V3HP9UU&psc=0&ref_=lv_ov_lig_dp_it
    The 3rd light you could remove and wrap like me, or Plastidip the inside with a few passes, keeping the outside glossy. Either way, if you don't like, peel it off.
  24. Mar 30, 2019 at 5:26 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    That was my initial concern. If it looks like poo I'll take it off and tint it myself with VHT nightshades.
    Worst case scenario is I wasted 13 bucks. Definitely wasted more on some bad dates
  25. Mar 30, 2019 at 6:56 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I tried and just couldn't get it to stretch right over the nibs. I'd be weary using VHT and not getting it to look nice, it's kind of a one shot deal. Most VHT jobs I see look like this:
    I ended up not doing anything, installed LED bulbs, and a Putco bar, erring on better visibility instead of darkening things out:
  26. Mar 30, 2019 at 7:23 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    I've done several sets of tails and my worst was a run. The secret is really light coatings with it. Do a few practice runs on cardblard to get the distance and nozzle squeeze down.
    If you mess up you can take it all off with rubbing alcohol.
    That Genesis just has way to many coats on it. Almost looks like plasti-dip.
  27. Mar 30, 2019 at 8:50 PM
    CAM1794
    CAM1794 New Member
    Chad
    2017 MGM 1794
    Curious to see how this turns out. Good Luck!
  28. Mar 30, 2019 at 9:04 PM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    I did the third light with VHT nightshade and it looks good and has held up fine. It was easy because it is so small. Replacement LED ones required dropping the headliner, so I went the easy route. I also replaced the bulbs with LEDs while I had it apart. It is still plenty bright. I’d bet getting a consistent coating with the full tails would be tougher, but doable with enough patience.
    4FA5ACBD-7A9E-4AC6-95FE-51CCDE5970F1.jpg 2BA84C37-6055-4847-A5B4-8B466ACE5451.jpg
    JoshuaA likes this.
  29. Mar 30, 2019 at 9:14 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    After mid smoke vinyl.
    JoshuaA likes this.
  30. Mar 30, 2019 at 11:52 PM
    3rdGenTundraDC
    3rdGenTundraDC New Member
    MGM
    Central Florida
    14 Tundra DC
    305/50/20 Nitto Terra Grappler G2 Stock, stock, stock.
    FYI... That is not night shade. That's is smoked Plasti Dip. Night shade comes out shiney and see though even when sprayed by novice sprayers. Night shade comes out real nice when done proper and cleared with spray max 2k. Wet sand before and after clearing. Then buff out after 24 hours and they can look very professional. I sent spray max and Eastwood a YouTube message the other week for them to put out a 2k blackout line. Perhaps if everyone ask them enough times, eventually they will come through.
