Tail Gate Pop & Lock , Tailgate
Discussion in '2.5 Gen Tundras (2014-2021)' started by brandostundra, Jun 24, 2021.
  1. Jun 24, 2021 at 10:51 AM
    brandostundra
    brandostundra [OP] New Member
    tried to do a search on this but didnt see much.
    I have a 2016 limited, considering purchasing and installing an electric lock-unlock product for the tail gate, to work with my factory key fob on the door circuit.
    spent 10 min on youtube seems pretty easy to install
    are there various brands available.
    could have sworn I say one that actually comes with wiring with harness ends so you dont have to tap into existing wires.
    basically what options are out there , pros and cons
  2. Jun 24, 2021 at 11:03 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  3. Jun 24, 2021 at 11:42 AM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    I just installed the OEM Toyota power tailgate lock last night on my 2017 Limited Crewmax.
    https://www.tundras.com/threads/2018-power-tailgate-lock-new-toyota-accessory.52150/
    https://www.tundras.com/threads/oem-toyota-power-tailgate-lock.60010/
    https://www.tundras.com/threads/oem-power-locking-tailgate.16097/
  4. Jun 24, 2021 at 12:16 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
  5. Jun 24, 2021 at 4:59 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I have Pop n' Lock Posi-taped as well. Easy install. Works great.
  6. Jun 24, 2021 at 5:04 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
  7. Jul 12, 2021 at 9:50 AM
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
  8. Jul 12, 2021 at 4:44 PM
    Black
    This is the module you need.
    POP & LOCK - Power Tailgate Lock for 2016-2021 Toyota Tacoma and 2007-2021 Toyota Tundra, PL8547HD (for Tailgate with OEM Lock) https://smile.amazon.com/dp/B00LST3022
    You can use this without the adapter harness I linked but there is cutting and splicing to factory wiring to make it work.
    The harness makes it plug and play.
  9. Jul 12, 2021 at 5:23 PM
    KotaStyle
    KotaStyle New Member
    2015 Tundra CrewMax
    None...yet
    So, I put the pop & lock version in my 2016 Tacoma and the actuator "pop" was so loud it was embarrassing to lock in public. I think the hallow tailgate didn't help but something to consider. I ended up lining the inside with dynamat and stuffing it with insulation. It helped. I will definitely being going with OEM on the Tundra.
  10. Jul 12, 2021 at 8:00 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    I actually just installed this one after I installed a soft bed cover.
    DEF Power Tailgate Lock Replacement for Toyota Tundra Tacoma 2007-2019 https://www.amazon.com/dp/B08KXVLM1Q?_encoding=UTF8
    Almost half the price of the pop lock, took 45 minutes or so between raindrops to install. I soldered the connections in the cab. I also have 2 extra actuators on hand (was going to fabricate on my previous truck but got aggravated) should the provided one give me trouble. Easy to do and well worth the price.
  11. Jul 12, 2021 at 9:04 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    OEM is better quality for about same price
    ejes and W3agle like this.
  12. Jul 14, 2021 at 2:40 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    Agreed. If you search enough, you can find them a little over $100. The quality, the perfect instructions and the plug and play parts make it worth the little it extra. Probably one of the easiest installs I've done. Last I heard on other boards, even though the Toyota OEM parts kit PK3B6-35JS0 says it is for 2019-2021, it fits and works 2016-2021.
  13. Jul 15, 2021 at 6:37 PM
    Trap Master
    Trap Master New Member
    2014 White Tundra SR5
    46 gallon tank Super springs 1600lb Tow mirrors Interior/Exterior LED lights
    ordering one today, we'll see how it goes. I have a 2014 so i don't think the OEM version will work for me
  14. Jul 15, 2021 at 6:44 PM
    French Avocado
    Utah / Wyo
    Fairly certain that the OEM works on all third gen Tunnies
