Switchpro Mounting place?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ghost Rider, Nov 29, 2021.
  1. Dec 23, 2021 at 6:58 AM
    #61
    Ghost Rider
    Ghost Rider [OP] Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    That is a nice and clean photo to follow, thanks!
    alb1k[QUOTED] likes this.
  2. Dec 23, 2021 at 7:32 AM
    #62
    coTony
    Tony
    Montrose, CO
    Anybody mounted the RCR Force 12 switch panel in the 2.5 Gen Tundra? I am still looking where I will be mounting it
  3. Dec 23, 2021 at 7:36 AM
    #63
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    It doesn't interfere with the mirror at all. When I'm driving around I don't notice it. I'm 6'0" but I don't think height matters. It does block the sunglasses holder in this position, but can be adjusted out of the way pretty easily.
    Wallygator, FrenchToasty and PG94 like this.
  4. Jan 7, 2022 at 11:32 AM
    #64
    klfrnia22
    klfrnia22 New Member
    Daniel
    Hampton, VA
    2019 Cavalry Blue SR5 CM
    Did you have to get another (longer) wiring harness besides the one included with the 9100 to run it to the overhead mount? Was it hard to route it up there?
  5. Jan 7, 2022 at 11:38 AM
    #65
    alb1k
    Left Coast
    It's good
    No, I had plenty of cable. My switch pro is in the back corner of the engine bay above the brake booster. On the fuse box would also reach it seems. I came through the firewall in the factory grommet by the parking brake, up the pillar and into the space above the headliner. I don't have pillar air bags, but I think plenty of Gen 2-2.5 route up to the overhead console as well.
  6. Jan 7, 2022 at 3:27 PM
    #66
    juice77
    juice77 New Member
    Sacramento, Ca
    2019 SR5 CM TRD 4x4
    no, the wiring was long enough
  7. Jun 7, 2022 at 9:09 PM
    #67
    Ghost Rider
    Ian
    Cypress, Texas
    Hey all, I know this is an old post, but I am "FINALLY" getting the final wiring done, hopefully this weekend.
    Question for you, what battery terminal billet did you use? I think I saw SDHQ ones?
    Also, as far as tapping into the fuse box, online YouTube said to just tap into the main fuse box in the engine bay but @alb1k said to tap into the cabin one, doesn't that require to re-route it through wherever you routed the wires through the firewall (that was a whole different nightmare for me...)
  8. Jun 7, 2022 at 9:11 PM
    #68
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Yes I have sdhq terminals(unfortunately, but that’s a different story) I tapped in to the main fuse box. The one in the cab is a smart idea but running the cables is a pain for me. Fuse box it was. Easy peasy
  9. Jun 7, 2022 at 9:12 PM
    #69
    alb1k
    Left Coast
    It's good
    For me, since I had to run the switch plate / control panel in the cab, it only made sense to run the other wires with that harness. I see others do it differently. SDHQ battery terminals.
  10. Jun 7, 2022 at 9:16 PM
    #70
    Ghost Rider
    Ian
    Cypress, Texas
    I guess I have no choice but to go with SDHQ products then. Not that I don't like them, just seems a bit expensive.... Buy once cry once I guess? LOL
    It took me close to two week of lunch time to get it through the firewall, and honestly, if I can't get that damn truck on a full lift, I would ditch the truck than go through the firewall again.....lol
    I cheated on that, too, I ended just pushing it in from the side of the rubber gasket, and pray that it does not create a leak point into the cabin, so far, so good....
  11. Jun 7, 2022 at 9:19 PM
    #71
    fisherman951
    Tony
    2017 crewmax 4x4
    You didn’t see the nipple in the grommet? Just need to lube it up lol
  12. Jun 7, 2022 at 9:21 PM
    #72
    Ghost Rider
    Ian
    Cypress, Texas
    I did, but the way it was stuck behind, it was super hard to get it in there without breaking my arm.....lol
  13. Jun 7, 2022 at 9:23 PM
    #73
    alb1k
    Left Coast
    It's good
    This. Cut the nipple and use a good pull setup and lube. You may have to push the grommet back into place.
  14. Jun 7, 2022 at 9:24 PM
    #74
    Ghost Rider
    Ian
    Cypress, Texas
    I guess.... I do need to re-run the whole cab setup again so might as well...... (welp....
  15. Jun 7, 2022 at 9:24 PM
    #75
    fisherman951
    Tony
    2017 crewmax 4x4
    I used one of these and lube lube lube lol trust me it wasn’t easy as I have big hands but it worked
  16. Jun 7, 2022 at 9:26 PM
    #76
    Ghost Rider
    Ian
    Cypress, Texas
    Don't think we need the whole 40ft but yea, a good piece of wire to do the pull through..... I have been sitting on this for way too long....
  17. Jun 7, 2022 at 9:33 PM
    #77
    alb1k
    Left Coast
    It's good
    I ran some 12ga solid copper wire. I taped it a long way, but without good cable pull lube or something similar, no way. Good news is it's watertight once it's through. I didn't pull the pins, so the plug was the challenge.
    Booney likes this.
  18. Jun 7, 2022 at 9:35 PM
    #78
    Ghost Rider
    Ian
    Cypress, Texas
    That's why I cheated, because I couldn't get the plug head to come off.....
  19. Jun 7, 2022 at 9:35 PM
    #79
    alb1k
    Left Coast
    It's good
    Looks like I started with 12ga wire to some pull cable.
    https://www.tundras.com/threads/1st-gen-2wd-dc.86734/page-10#post-2548322
  20. Jun 12, 2022 at 4:14 PM
    #80
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Just seeing this as I'm away at work, but SDHQ Billet Terminals for the win! Pricey but good quality. Engine compartment fuse box mount, running the cable inside was a bit of a pain with my big hands but I went through the nipple using a cable puller and some lube. SDHQ billet mount on the console for me as it's a good accessible, unobtrusive spot for the SwitchPro control pad.
    alb1k likes this.
  21. Jun 12, 2022 at 5:09 PM
    #81
    ConcordCarlos
    ConcordCarlos New Member
    Carlos
    2021 Tundra SR5
    I used the metal plate that came with the Switch Pro . Routed the cable from the brain to the switch panel behind the side curtain airbag , up from behind the dash. Org plan was up the B pillar (sounds dirty lol) , but the connector was too large to go over a roof support. I ended up buying a new longer cable since the stock one was not long enough for my org plan. $68 oops . Need more pics , lemme know .
    67BBE7F8-88D3-4FD5-A671-131A29903EC5.jpg 18CABDC0-68AB-4EE4-BA89-9307086083E1.jpg
  22. Jun 12, 2022 at 5:12 PM
    #82
    alb1k
    Left Coast
    It's good
    Looks great. Way to go with the heat shrink terminals. I've thought about the panel cover - but sometimes I slide my finger to hit multiple switches. Good job.
    ConcordCarlos[QUOTED] likes this.
  23. Jun 12, 2022 at 6:08 PM
    #83
    ConcordCarlos
    Carlos
    2021 Tundra SR5
    thank you. The pic reminds me I need to pull that one wire and put it in the expanded / braid wire protector. Side note, I ditched the Amazon craptastic terminal/shrink tube and bought from polar wire instead. It’s about 3 times the price, but it’s rapidly apparent that the quality is better. Side side note, took me some fiddling to fire out how to release the trim piece that covers the side curtain airbag. Small tab that has to be pressed in to get the bolt cover door open. Yup found that bolt behind the SRS oval from a write up on a 2008 Highlander…
  24. Jun 12, 2022 at 6:11 PM
    #84
    alb1k
    Left Coast
    It's good
    I love my Amazon 3X shrink w/ adhesive. The shit is bullet proof. But not all Amazon is the same.
    https://www.amazon.com/gp/product/B08W9TJYWV?ie=UTF8
    FrenchToasty likes this.
  25. Jun 12, 2022 at 7:07 PM
    #85
    ConcordCarlos
    Carlos
    2021 Tundra SR5
    This may require a YouTube heat shrink face off. Hahaha.
  26. Jun 12, 2022 at 7:13 PM
    #86
    alb1k
    Left Coast
    It's good
    Lol, you know what you are dealing with when you go to cut it off for a change of lighting. I do that a lot it seems. Challenge accepted. Not that we need one...or...do...we?
  27. Jun 12, 2022 at 7:15 PM
    #87
    alb1k
    Left Coast
    It's good
    Here's my last challenge/example. Open beer with a ring. It's fast because my camera man wasn't ready, lol.
    https://youtu.be/Lo53-QA83Kk
    ConcordCarlos likes this.
  28. Jun 12, 2022 at 7:31 PM
    #88
    ConcordCarlos
    Carlos
    2021 Tundra SR5
    I picture rigging up heat shrink’ed wire and hanging weights off of it. Let’s just convince Project Farm from YouTube to do it for us…
  29. Jun 12, 2022 at 7:34 PM
    #89
    alb1k
    Left Coast
    It's good
    Ha! If he did heat shrink, he would probably have it underwater, pee on it, try to drag a tree...
  30. Apr 21, 2024 at 3:52 PM
    #90
    Born-Riding
    Born-Riding New Member
    Barrett
    2021 Tundra crewman TRD PRO
    Hey Guys, I mounted mine on the fuse box cover, but i guess it's a little more back than center. My switchpro wires are touching the ABS lines. The switch wires are sheathed to protect from rubbing, but do you think the ABS line temp will be a problem and i should redial the fuse box cover and mover it more forward? been debating myself on this for days!
    thanks
